Old 11-02-2013, 06:33 PM   #1
karma003
auto-crosser/drifter
karma003's Avatar
Drives: 2013 scion FR-S black M/T
Exclamation ksport coilovers. need help. advise.
I put them on last night, set the ride heigh & alignment & all now about the preload settings. Idk how ur suppose to adjust it or what adjustments r ok, so tighten them as much as I could ny hand then just set them in place. Did autocross today, did ok but feels kinda off & unpredictable. My buddy told me u gotta measure it & set it all the same. Is this true? If so, can I do just the preload & be ok or will I need an alignment again
karma003 is offline   Reply With Quote
Old 11-02-2013, 08:48 PM   #2
utekineir
blowhard
Drives: frs, project forester
As somebody that once made the ksport mistake I'd like to offer My condolences
utekineir is offline   Reply With Quote
Old 11-02-2013, 08:51 PM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
Corner balance sounds like you need.
And by set the alignment you mean on an alignment machine not by your eye right>?
Old 11-02-2013, 08:52 PM   #4
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Not to be a ****, but if you weren't sure on how to install/adjust them, you should have had somebody else do it.
That being said, have somebody who knows how to do it all take a look at it and have them help you.
Old 11-02-2013, 09:23 PM   #5
KKaWing
KKaWing's Avatar
Drives: Nissan Versa
[ame="http://www.youtube.com/watch?v=HlqOA35NmAw"]BC Racing Coilover Spring Change and Preload Adjustment on Vimeo.mp4 - YouTube[/ame]
Made at the same factory so here's a primer on how to do preload on those coils.
KKaWing is offline   Reply With Quote
The Following User Says Thank You to KKaWing For This Useful Post:
karma003 (11-03-2013)
Old 11-03-2013, 09:54 AM   #6
karma003
karma003's Avatar
Wow. Thanx a lot. Lol almost had it. Just didnt tight the extra 4mm's
Old 11-05-2013, 01:57 AM   #7
Xauterus
Drives: GTS 86 Galaxy Blue
Did you get an alignment done after you fitted them?
Xauterus is offline   Reply With Quote
The Following User Says Thank You to Xauterus For This Useful Post:
karma003 (11-05-2013)
Old 11-05-2013, 07:44 AM   #8
karma003
karma003's Avatar
Yes of course. Figured out it felt off cuz the lug nuts were a little loose had to wait til I got my wheel lock back from my friend to tighten them. It feels great now.
COILOVERS- RSR- TANABE- KW- KSPORT- D2RACING F-T Brakes, Suspension, Chassis 152 03-22-2016 10:37 PM
FS: Ksport Kontrol Pro Coilovers Ocho-Seis Brakes, Suspension, Chassis 1 10-31-2013 08:46 PM
KSport Coilovers - Another Coilover Option FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 08-15-2012 02:38 PM
KSport Coilovers for the BRZ/FRS at Redline360 now available! Redline360 Brakes, Suspension, Chassis 1 08-01-2012 01:30 PM
