auto-crosser/drifter
Drives: 2013 scion FR-S black M/T
I put them on last night, set the ride heigh & alignment & all now about the preload settings. Idk how ur suppose to adjust it or what adjustments r ok, so tighten them as much as I could ny hand then just set them in place. Did autocross today, did ok but feels kinda off & unpredictable. My buddy told me u gotta measure it & set it all the same. Is this true? If so, can I do just the preload & be ok or will I need an alignment again
#2 |
blowhard
Drives: frs, project forester
As somebody that once made the ksport mistake I'd like to offer My condolences
#3 |
Thanks
Corner balance sounds like you need.
And by set the alignment you mean on an alignment machine not by your eye right>? |
#4 |
Drives: '24 GR86
Not to be a ****, but if you weren't sure on how to install/adjust them, you should have had somebody else do it.
That being said, have somebody who knows how to do it all take a look at it and have them help you.
#5 |
Drives: Nissan Versa
[ame="http://www.youtube.com/watch?v=HlqOA35NmAw"]BC Racing Coilover Spring Change and Preload Adjustment on Vimeo.mp4 - YouTube[/ame]
Made at the same factory so here's a primer on how to do preload on those coils. |
| The Following User Says Thank You to KKaWing For This Useful Post: | karma003 (11-03-2013) |
#6 |
Wow. Thanx a lot. Lol almost had it. Just didnt tight the extra 4mm's
#7 |
Drives: GTS 86 Galaxy Blue
Did you get an alignment done after you fitted them?
| The Following User Says Thank You to Xauterus For This Useful Post: | karma003 (11-05-2013) |
#8 |
Yes of course. Figured out it felt off cuz the lug nuts were a little loose had to wait til I got my wheel lock back from my friend to tighten them. It feels great now.
| COILOVERS- RSR- TANABE- KW- KSPORT- D2RACING | F-T | Brakes, Suspension, Chassis | 152 | 03-22-2016 10:37 PM |
| FS: Ksport Kontrol Pro Coilovers | Ocho-Seis | Brakes, Suspension, Chassis | 1 | 10-31-2013 08:46 PM |
| KSport Coilovers - Another Coilover Option | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 08-15-2012 02:38 PM |
| KSport Coilovers for the BRZ/FRS at Redline360 now available! | Redline360 | Brakes, Suspension, Chassis | 1 | 08-01-2012 01:30 PM |
