Old 11-02-2013, 01:58 AM   #1
Jolaessss
Jolaessss's Avatar
Drives: SWP FR-S
Cracked Oil Pan?!
So I changed my oil about a week ago and everything seemed fine. Today, I back my 86 out of the garage to clean her up when I notice a puddle of oil on the floor, directly under where the oil pan was.
I jack up the car to find that the drain plug was pretty snug.
After reading a couple reviews, what are the chances of the leak being a result of a cracked oil pan? Thoughts? Thanks!
Jolaessss is offline   Reply With Quote
Old 11-02-2013, 02:09 AM   #2
whataboutbob
AutoX-10/10ths every run
There is a crush washer that goes under the plug. If it doesn't seat right when tightened it can leak. Check it.
Build thread:Here
The Following 3 Users Say Thank You to whataboutbob For This Useful Post:
DAMotorsports (11-02-2013), Muaddib (11-02-2013), NYCsubaruBRZ (11-20-2013)
Old 11-02-2013, 03:35 AM   #3
ft_sjo
Drives: GT86
The OE crush washer is a crap design. Replace it with a suitable dowty washer.
The Following User Says Thank You to ft_sjo For This Useful Post:
Old 11-20-2013, 03:17 AM   #4
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
what is the size of the plug? i need a new one
NYCsubaruBRZ is offline   Reply With Quote
Old 11-20-2013, 08:05 AM   #5
Mikem53
Drives: FR-S 6MT
I doubt the pan is cracked unless u hit something.. If it was ur first oil change.. Did you remove the crush gasket first? The one that comes with the car is painted black and looks like its part of the drain bolt. I had to use a razor to seperate it before putting on a new one.. That's probably your leak...
Mikem53 is offline   Reply With Quote
The Following User Says Thank You to Mikem53 For This Useful Post:
Jolaessss (11-20-2013)
Old 11-20-2013, 01:41 PM   #6
Jolaessss
Jolaessss's Avatar
Drives: SWP FR-S
This was my second oil change. I didn't have this problem after my first oil change, which is weird. My problem is solved now, hopefully, no more leaking. I had to slightly unscrew the drain plug and re-tighten it. I hope i didn't lose the crush gasket during my first oil change!
Old 11-20-2013, 01:49 PM   #7
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I know when I get my filters from my Subuar dealer they include a new crush gasket with the filter. If you plan to do lots of oil changes on your own hit up the dealer and get 5 or 10 of them so you have them on hand.
Old 11-20-2013, 01:53 PM   #8
Jolaessss
Jolaessss's Avatar
Drives: SWP FR-S
Are you serious?! I've been getting my oil filters from Subaru (over here Toyota/Scion are asking $20 for a filter!!) and never got a crush gasket. I'll ask them for one before my next oil change, thanks for the tip!
Old 11-20-2013, 02:40 PM   #9
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
It's a crush washer. Replace it every oil change or it can leak over time.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
Old 11-21-2013, 03:41 AM   #10
Fast_Freddy
Drives: Passat
Fast_Freddy is offline   Reply With Quote
Old 11-21-2013, 09:39 AM   #11
d1ck
Drives: Black 2013 FRS
At my dealer they charge 2.95 for that gasket. I'd be surprised to find out that the cost is over $0.15...
d1ck is offline   Reply With Quote
Old 11-21-2013, 12:17 PM   #12
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
When I bought a filter at Capitol Subaru they gave me a new crush washer.
The Following User Says Thank You to BlaineWasHere For This Useful Post:
Jolaessss (11-21-2013)
Old 11-21-2013, 02:28 PM   #13
Kostamojen
Seriously guys, NEVER re-use those washers! They WILL leak if you try to re-use them. Get new ones EVERY time.
Subaru's have had these washers forever... Its always been this way with these motors.
leak, motor oil, oil, oil leak
Cracked windshield baadshah Issues | Warranty | Recalls / TSB 11 09-17-2013 08:09 PM
Cracked taillight Drftfan Issues | Warranty | Recalls / TSB 2 07-12-2013 06:58 PM
Am I the First BRZ/FRS w/ a Cracked Windshield?!?!?! NYC BRZ BRZ First-Gen (2012+) — General Topics 65 05-04-2013 12:14 AM
Has anyone cracked the OEM rotor yet? ayau Tracking / Autocross / HPDE / Drifting 10 04-22-2013 04:41 PM
Cracked Rim SmsAlSuwaidi Issues | Warranty | Recalls / TSB 29 04-02-2013 01:30 PM
