Old 10-31-2013, 10:27 PM   #127
nelsmar
Originally Posted by Mersd View Post
Another belt broke today. I was doing some spirited driving with the defrost on because of heating issues. I forgot the defrost activates the ac compressor causing more resistance on the belt. Going to try a gatorback belt this time.
ive got a good 4k miles or so on my current gates (non racing) belt. It has been holding up quite well to horrid abuse. My ac has been on most of the time I have owned my vehicle (up until about 3 weeks ago when it finally started cooling down).
Are you on the stock pulley? Verify your alignment of pulleys. There is a lot of play in angle. A few degree's can cause too much tension. Unbolt the two bolts on the top of the alternator bracket, they are slotted so that you can slide the top of blower forward / back away from the firewall.
Personally I never broke a belt on the stock pulley, only my smaller one and this was also related to over-sized belt. I put a good 8k miles or so on the standard 3.48" belt with fairly "spirited" driving sessions of 30+ minutes that rarely hit lower than 4,500RPM
My flickr - Canibeat
Local magazine scout
The Following User Says Thank You to nelsmar For This Useful Post:
Mersd (11-01-2013)
Old 11-01-2013, 07:48 PM   #128
Mersd
Drives: Scion FS-R
You have part numbers for gates belt and pulley? Also where did you purchase?
Mersd is offline   Reply With Quote
Old 11-01-2013, 08:42 PM   #129
nelsmar
For which pulley, and which belt, the standard or racing?
Old 11-03-2013, 01:00 AM   #130
MATTrocity
Winter Is Coming
Drives: 2013 Scion FR-S Ultramarine
http://www.raceseng.com/revo-pulley-...r-s-subaru-brz
anybody know if the idler pulley in this kit would work? thought I might just replace all and make it look clean if I had to get a new idler anyway
MATTrocity is offline   Reply With Quote
Old 11-03-2013, 10:00 PM   #131
blubrz
Drives: WRB BRZ
Vortech idler pulleys seizing and belts breaking
The idler on the vortech SC is the issue.
blubrz is offline   Reply With Quote
Old 11-18-2013, 04:31 PM   #132
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
So wanting to know "now" latest kits, assuming a guy does a great install, doesen't deciat from stock goods meaning no other pulleys etc, straight 91 gas tune, is this now a reliable no fuss kit? No cutting or modding needed and all bolt in?
Old 11-18-2013, 05:48 PM   #133
DJCarbine
Thupercharged
DJCarbine's Avatar
You still need to file a nub down when installing the bracket for the alternator, and a few minor plastic parts need modifying for the intercooler piping as far as I know. I would read over the manual to see exactly what needs to be done, its very simple/easy with a file.
If you want added insurance, get the gates racing belt and a new pulley for the supercharger bracket.
Never had issues with my kit until the pulley went bad, and it just squeaked a lot... 10 dollar fix
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 11-19-2013, 03:13 PM   #134
Philly758
Drives: GMC
Should I have any additional concerns about running my Kartboy lightweight crank pulley pulley with the supercharger? I've noticed people sell off their lightweight pulleys when they go FI claiming that "the difference would be negligible", but would I have any added risk of ruining my belt? I've had the pulley on my car for about 6 months.
Philly758 is offline   Reply With Quote
Old 11-19-2013, 04:59 PM   #135
Foobar
SLO NO MO
Foobar's Avatar
I've had the Perrin pulley along with the Vortech and have not had to replace any belts or tensioners.
Old 11-19-2013, 05:03 PM   #136
DJCarbine
Thupercharged
DJCarbine's Avatar
If the pulley dimensions are the same and the only difference is weight, there shouldn't be a problem. You could contact the pulley manufacturer if you are paranoid.
If it's the same diameter/fitment as oem you should be good to go.
2013 FRS
Vortech V3 11psi
Old 11-20-2013, 06:53 AM   #137
Mersd
Drives: Scion FS-R
I sent vortech a message about other belt replacement and they said to use gates k060970 which is different then what comes in the kit, k060975. It seems to be a half inch shorter.
Old 12-22-2013, 07:16 PM   #138
p00mba
p00mba's Avatar
Drives: FR-S :)
where did you purchase the replacement pulley? i think mine is going bad.
p00mba is offline   Reply With Quote
Old 12-22-2013, 07:37 PM   #139
DJCarbine
Thupercharged
DJCarbine's Avatar
Gates 38006
Autozone/amazon/rockauto
2013 FRS
Vortech V3 11psi
The Following User Says Thank You to DJCarbine For This Useful Post:
p00mba (12-22-2013)
Old 12-25-2013, 03:29 AM   #140
HRTROB
HRTROB's Avatar
Drives: Toyota 86
I have a Vortech on order and now I'm getting nervous with all these belts snapping and breaking can somebody post some links on where I can buy spare belts and idler pulleys online for the stock 9psi pulley?
HRTROB is offline   Reply With Quote
The Following User Says Thank You to HRTROB For This Useful Post:
ZionsWrath (12-25-2013)
Kartboy Crank Pulleys 95.00 tom@kartboy Engine, Exhaust, Bolt-Ons 16 06-11-2013 01:06 PM
Crank,Alternator,Waterpump Pulleys etc..? fareastbrz Engine, Exhaust, Transmission 6 05-28-2013 08:46 PM
Titan Performance second batch of pulleys Amalgamo User/Vendor/Sponsor Reviews, Feedback, Comments 0 07-30-2012 09:57 PM
