View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 10-30-2013, 08:55 PM   #3151
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Anyone else think that this new part number fuel pump is the same as the green dot pump?
The VIN specified in the new TSB is February 2013.
The green dot fuel pump started manufacturing in February 2013.
This makes me think that they just did "wait and see" for 8 months before changing the part number.
Old 10-30-2013, 09:25 PM   #3152
JSMIL
JSMIL's Avatar
Drives: FRS 10 series
I am not sure, but i will try every pump they put out. The only reason I disagree is that I don't know why they would go to the trouble of revising the TSB if the pump was the same. figures if they just changed the part number of the green dot pump they would have done it before now. Just my thought but I will let you know if this one works. I have one on hold for me ready t install when I bring my car in.
JSMIL is offline   Reply With Quote
Old 10-30-2013, 09:35 PM   #3153
sierra
Drives: Skoda Yeti DSG diesel 4x4
Huh, that article I linked is Australian and links a chirping video, here it is again:
http://news.drive.com.au/drive/motor...010-27cbu.html
I'll do my best to get the links across, should be able to copy paste these into google and get results:
gt86. com. au/forum/f16/all-gt86-owners-must-read-3164/index7.html#post39459
gt86. com. au/forum/f16/direct-injection-issues-coming-up-overseas-343/index2.html#post2136
I like how I'm linking to threads you've posted in. I guess I just haven't figured out how this is a 'fault' yet.
It gets the odd mention but it's very rare here and i've never seen it apart from by doing a search. Unlike the USA where it's a daily topic.
The first link is a year old and the other 2 refer back to this forum.
If you agree with the dealers who say it's normal, it's not a fault.
If you're pissed off because it wasn't there on the test drive and appeared after purchase, it's a fault.
sierra is offline   Reply With Quote
The Following User Says Thank You to sierra For This Useful Post:
strat61caster (10-30-2013)
Old 10-30-2013, 10:00 PM   #3154
JCasteli
Drives: Black FR-S
The new pump is the not the green dot pump, it is a now a sound insulated pump.
JCasteli is offline   Reply With Quote
Old 10-30-2013, 10:06 PM   #3155
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
New pump ordered today at subaru. I had crickets along with a butterly type fluttering sound that recently developed
abutterman is offline   Reply With Quote
Old 10-30-2013, 10:50 PM   #3156
sierra
They must be very confident it's not a symptom of friction and wear that will cause problems later?
You would like to think they had a good try at engineering a solution before giving up and wrapping it up to hide the noise.
Old 10-31-2013, 08:11 PM   #3157
twag4
Drives: frs
Originally Posted by sierra View Post
Insulated? Meaning they haven't fixed the fault but insulated the pump instead?
Why not issue insulation jackets to fit over the pump so that it can self destruct out of warranty without any symptoms?
My new pump is not insulated. It is definitely a different pump than was in the car originally. The black steel cover that is covering the pump and piping has insulation in it, but it had that with the old pump on my car. There is no green dot on my new pump. I took some pictures with the black steel cover removed, they aren't great. If anyone wants to see them, let me know. I can post them.
twag4 is offline   Reply With Quote
Old 10-31-2013, 09:30 PM   #3158
sierra
I would be interested in seeing the pics please.
As I've said many times, at 13,000km my pump is chirp free but I've followed this thread since it started and would be interested in comparing the new pump in case we start getting the chirps here one day.
Old 10-31-2013, 10:13 PM   #3159
twag4
Drives: frs
[QUOTE=sierra;1306481]I would be interested in seeing the pics please.
The first and third pictures are looking down at the top of the fuel pump from driver's side. The second picture is looking from the front. The yellow at the bottom left is the oil filter. The fourth picture is of the insulation stuck inside the black metal cover that is over the pump and piping. The cover is simply turned up on its side to view the insulation. I did not remove the fuel hose retainer that must be removed to get the black cover out from under the fuel hoses. The final picture is with the black cover installed as it always is - looking from driver's side. I took a few more, but they are really difficult to identify what you are looking at. Taking pictures of black stuff in a very dark and black field requires better photo equipment than I have, and more time than I have.
Old 10-31-2013, 10:18 PM   #3160
sierra
That's great.
Thanks for posting those.
Old 10-31-2013, 10:23 PM   #3161
twag4
Drives: frs
That's great.
You are quite welcome
Old 10-31-2013, 10:40 PM   #3162
Pscylo
Pscylo's Avatar
Drives: Raven FR-S
So did anyone have a link for it? I search the number and get the same old TSB from a year ago....where is this one that is supposed to have been a couple weeks ago?
Pscylo is offline   Reply With Quote
The Following User Says Thank You to Pscylo For This Useful Post:
EvilBeaverFace (11-03-2013)
Old 10-31-2013, 11:01 PM   #3163
twag4
Drives: frs
It is the same TSB. It just has a new revision, "Revision 2". The new revision is dated October 17, 2013.
Old 11-01-2013, 12:21 AM   #3164
Pscylo
Pscylo's Avatar
Drives: Raven FR-S
Still....anyone got a link to Rev2...everywhere I look its Rev1...even the link on the front page of this post.
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
