Old 10-31-2013, 07:01 PM   #113
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
@shiv@vishnu Ignore my voicemail I left for you this afternoon. I was getting repeaded error messages on my Windows 8 laptop when I first connected the tablet. It would do it's update, but would eventualy fail at the end and give me an error message. I uninstalled software and reinstalled with windows 8 patch both times with no success. So I finally said the hell with it and went over to my Windows 7 laptop and had no issues whatsoever.
I'll post a screenshot of the error message later if you wish ?
Anyhow, everything went great once I had a working laptop. Flashing updated tune went as planned, but I did notice how time consuming this was in comparison to flashing a file via EcuTek cable and laptop. I'm guessing this has something to do with the overall speed of the tablet and internal memory it uses ?
Thanks! Need to test out my tune now
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 10-31-2013, 08:04 PM   #114
Walla Walla
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
quick question: is it normal that it's kind of long before the gaz pedal adjust itself again?
after 4-5 start-up, + 40km, seems to still have a huge lag (i know i already had this situation, once when i disconnected the battery, but still)
can't wait to really enjoy it for real!
Walla Walla is offline   Reply With Quote
Old 10-31-2013, 08:25 PM   #115
cnk
Drives: '13 DGM BRZ Limited
It happens any time you flash the ECU irregardless of whether you use OFT or ECUTEK or some other software. You can either just drive it for a while and the ECU will relearn, or set the car to ON, but don't start the engine. Then just depress the gas pedal all the way and release about 10-20 times. Turn off the car, then start it up as usual and the deal pedal should be gone.
The Following User Says Thank You to cnk For This Useful Post:
Boofneenee (10-31-2013)
Old 10-31-2013, 08:57 PM   #116
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Glad everything worked out. Regarding flash times, the OFT writes the entire ROM, not just parts of it. This takes 4.5 minutes. From my experience, Ecutek dealer software also takes 4.5 minutes too when the entire ROM is written. Ecutek customers who report shorter write times likely are only writing part of the ROM (ie, just the bits that were edited). Apart from the extra time it takes to do a full ROM write, there are some potential safety advantages to do this (vs partial writes).
I've also reloaded the FA20 OTS maps on the website. Sorry about the earlier snafu!
Cheers,
shiv
Shiv@Openflash is offline   Reply With Quote
Old 10-31-2013, 11:11 PM   #117
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Cheers,
shiv
I just checked all my Ecutek files and each one is 1.25MB. Flashing these files took about 1 or 2 minutes max from start to finish.
Has anyone else reported issues running Openflash with Windows 8? I read in another thread that there were issues with Openflash manager crashing and it would be rectified with an update by tomorrow, just wondering if it was Windows 8 related.
I can post screen shots of my error message tomorrow if it will help. But maybe you guys already have it under control ?
Thanks!
2URGSE
Old 10-31-2013, 11:13 PM   #118
cnk
Thanks!
I've been running it on Win 8 and now Win 8.1 without any issues.
Old 10-31-2013, 11:22 PM   #119
Shiv@Openflash
Drives: 2013 FRS
Thanks!
The ROM file is always going to be 1.25mb. What is going to differ is how much of it (partial or full) is going to be written to the ECU. This will determine, for the most part, how much time the write process will take.
I'm running Windows 8 myself on my laptop (MacBook Pro with Parallels). Just make sure you are running OpenFlash Manager v1.03. The earlier versions will crash with the new OFT firmware. The new software is downloadable from our website as of earlier this morning.
Shiv
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
JPxM0Dz (10-31-2013)
Old 10-31-2013, 11:32 PM   #120
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Guess I should just update to 8.1, yeah my Windows 7 laptop had no issues whatsoever and will continue use it if need be. But would like to set things up on my Windows 8 laptop if at possible.
Here are the prompts and error message I end up with here...
The first two screens are update prompts, but each one looks a little different from one another and they come in that order
UPDATE: OpenFlash manager 1.02 is the problem, updated to 1.03
2URGSE
Old 10-31-2013, 11:35 PM   #121
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Shiv
Ok thanks, yeah I'm obviously running an older version of the OpenFlash manager 1.02
Damn I never even noticed 1.03 on my Windows 7 laptop verses the 1.02 on the Windows 8
Thanks again!
2URGSE
The Following User Says Thank You to JPxM0Dz For This Useful Post:
Shiv@Openflash (10-31-2013)
Old 10-31-2013, 11:51 PM   #122
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
i wanna see e85 FI tune with 16 psi
Old 11-01-2013, 12:19 AM   #123
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Why would you use windows 8? Are you a masochistic?
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 11-01-2013, 09:14 AM   #124
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Cuz I can
2URGSE
Old 11-01-2013, 10:15 AM   #125
sonnydelight
sonnydelight's Avatar
Drives: 2013 Scion FR-S - Whiteout
Thanks! Got it
What! I don't think I got a sticker.
I reflashed my car last night using the Stage 1 tune to compliment my Perrin CAI and Perrin CBE. 3-4k seems smoother. It gets pretty gnarly after 4k lol. My car def pulls harder on the top end. So far so good. Still trying to sort out this dead gas pedal though. I think I'll be pretty happy once that's gone.
sonnydelight is offline   Reply With Quote
Old 11-01-2013, 10:33 AM   #126
D18
D18's Avatar
Drives: Scion FR-S (Hot Lava)
Yea no problems here with Windows 8.1. I did have a problem with Windows 7 running on my Mac though... but I think that might have been tied to OFM 1.02.
The only major glitch I have had so far was a repeated "An error occurred while reading data from DME. Please try again." I got this every time I initially tried to read my ECU. I was making the error of turning my engine on though and not just turning the car to ON with the engine off. So to all other newbs out there, take my poor example as a lesson.
Has anyone else tried loading 2 maps onto the Tablet in addition to the Original? I first tried that, (to try out the difference between 1.2 and 1.3) but it seemed to cause the tablet to freeze with a white screen when plugging it into the OBD II port. I have since removed both and re-uploaded just the 1.3 and all works perfect, just curious if there is maybe a memory restriction on the tablet if we try to have multiple maps loaded on it.
All in all, love the package, awesome value. Thanks Shiv for becoming a solid part of the community!
D18 is offline   Reply With Quote
The Following User Says Thank You to D18 For This Useful Post:
Kids Heart (06-10-2014)
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 FRSTEVE Software Tuning 105 08-04-2017 04:48 AM
anyone trying to use the openflash tablet with forced induction? FRSTEVE Software Tuning 69 12-07-2014 04:07 PM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 10:03 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
