Old 10-31-2013, 12:45 PM   #29
350matt
Drives: toyota mr2/ Toyota GT86
Bent rods owch!
how much boost was that then? and at what rpm?
350matt is offline   Reply With Quote
Old 10-31-2013, 01:01 PM   #30
xxscaxx
Drives: 2013 SWP BRZ
guess that means i'm out on this upgrade if its really going to be strongly advised you build the motor. Not going down that road again.
xxscaxx is offline   Reply With Quote
Old 10-31-2013, 01:16 PM   #31
tahoward
tahoward's Avatar
Drives: Firestorm FR-S
I'm considering doing a light lower build with a new base block; rods, bearings and studs.
What was your experience with a build?
tahoward is offline   Reply With Quote
Old 10-31-2013, 01:32 PM   #32
xxscaxx
Its not on the same platform so it doesn't hold value here, but I rather stay on a stock motor. I built an EJ and spent a lot of money only to have to pull it out again for a teardown. Don't ever really see high mileage motor builds rolling around.
Could be way different for this motor, but its just not something I'd personally go through again lol.
I was hoping this upgraded unit would be a step up in power but not to the motor build point. Maybe on lower boost I could pull it off, but we have to wait and see.
Old 10-31-2013, 01:52 PM   #33
sw20kosh
Drives: 2013 Black FR-S
I would just run a low boost pulley on the larger unit. Target the same boost that the small blower was putting out. The result would be less hot air and it wouldn't get winded up top as it isn't spinning anywhere near it's redline? All speculation at this point but it should make sense. Maybe the gains are not really worth all that trouble/$.
Old 10-31-2013, 02:44 PM   #34
diss7
Drives: AE86, 2x GT86, TE27
They are saying built motor to cover their ass. Based on what others have achieved with the motor, I would run it as is. But, with the knowledge I have signicantly increased the risk of engine/driveline failure; as you have with any FI kit.
I certainly wouldn't pre-emptively build the motor.
Big blower + built toda stroker motor = win
diss7 is offline   Reply With Quote
Old 10-31-2013, 03:10 PM   #35
cantholdanymore
cantholdanymore's Avatar
Drives: FR-S Very Hot Lava
People wants moar pawar
Kit provides moar pawar
Kit needs engine build to support moar pawar.
People call it fault
cantholdanymore is offline   Reply With Quote
Old 10-31-2013, 03:52 PM   #36
xxscaxx
Thats my intention if its possible
True, but this supercharger = instant power down low. I know turbos are making power down low but they still need to build boost and will place less stress on the motor. Someone correct me if i'm wrong here, but thats my assumption on it lol.
If this thing can make like 350whp without overstressing, I really think its going to get a LOT of attention.
Old 10-31-2013, 04:06 PM   #37
Ingen
Drives: Ultramarine FR-S 6MT
Why can't there be an interlock between the tach and a blowoff valve that prevents the excess boost at low RPM, and feeds it in at higher RPM?
that can't be that damn hard to engineer. Certainly it's cheaper than new rods!
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 10-31-2013, 04:35 PM   #38
Calum
That Guy
Drives: 2013 asphalt FRS MT
You could just limit the max throttle opening at low rpm, via the tune.
Old 10-31-2013, 04:46 PM   #39
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Remember, since an SC runs off the engine directly, it takes power to make power. 250HP at the crank might require 300HP worth of stress with 50HP going to run the blower. That plus lower rpm=engine problems. A larger blower will mean more friction, more mass, and more effort to spin for the same HP, at least much of the time. For most people, the smaller blower will probably be better, and remember, you can always twin charge!
Old 10-31-2013, 04:48 PM   #40
xxscaxx
Maybe because that defeats the whole purpose of a twin screw blower that makes instant boost? Lol
They make those, it's called vortech and rotrex.
Old 10-31-2013, 05:28 PM   #41
tech4pdx
Make love
tech4pdx's Avatar
Drives: H8R.. Not really
Bow down to the almighty TWIN SCREW.. Creator of POWAH. May it wet your undergarments and bring joy to those who use it!
tech4pdx is offline   Reply With Quote
Old 10-31-2013, 06:23 PM   #42
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
We can alter the boost down low with cam timing by letting the blower exhale with a partly open exhaust valve towards the end of the stroke. Reduces boost by several psi. We can also drop timing down low to cut down on power, so that portion is no big deal. But the big blower will eat HP and add weight, so any gains from the cooler charge will be lost. Stock motor I see no issues with 70mm and cooler or e85, or the 72.5 if you want to stay below the continuous redline of 15000 rpm at all times.
Xero-Limit is offline   Reply With Quote
Abbey Motorsport Sprintex SC updated Dyno plots Mark@Abbey m/s Forced Induction 49 02-15-2017 11:13 PM
Khorne's - AUDM Red 86 GTS Sprintex Khorne Member's Car Journals 53 08-31-2014 09:44 AM
Sprintex or Vortech, which setup has more potential? Turbowned Forced Induction 328 09-14-2013 11:09 AM
Abbey Motorpsort GT86 Sprintex installation Mark@Abbey m/s Forced Induction 18 09-07-2013 04:11 AM
Sprintex Supercharger Sneak Peak!!! invisage Forced Induction 52 03-03-2013 06:11 AM
