Old 10-30-2013, 01:45 AM   #15
Hawk77FT
Drives: GTS 86
Originally Posted by FT-86 SpeedFactory View Post
Agree SPC arms are the easiest install and very affordable, plus offer a nice range of adjustment. http://ft86speedfactory.com/spc-rear...e-kit-891.html
Price for a set to Australia, Brisbane?
Hawk77FT is offline   Reply With Quote
Old 10-30-2013, 09:16 AM   #16
ML
ML's Avatar
Drives: 13 White MT FR-S
Originally Posted by Hawk77FT View Post
They look good but it looks like a PITA to have them installed.
you have no idea...I did it myself with a lift and it was still a huge PITA.
Old 10-30-2013, 09:35 AM   #17
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Originally Posted by FR-S Matt View Post
You will want the SPC LCA's for a daily driver if you want your toe to be back at 0. Otherwise, it will eat your tires. The camber is not so big of a deal. It's the toe that is the the problem. The SPC LCA's allow both to be adjusted. I'm at -0.9 and -1.3 in the back, 0 toe with these LCA's.
If I'm lowering 30mm, will I still get to 0 toe all round by just adjusting stock toe links?
Fizz is offline   Reply With Quote
Old 10-30-2013, 10:59 AM   #18
FR-S Matt
If I'm not mistaken, I didn't think anything in the rear was adjustable without swapping out?
Old 10-30-2013, 11:15 AM   #19
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I don't know....I thought I saw someone mention that the toes can be adjusted? I just wanted to know what are the adjustment limits on stock suspension, and whether it's possible to get the toe setting back to (or as close to) zero?
And what about adjusting rear camber on stock suspension...is it possible?
Old 10-30-2013, 12:51 PM   #20
CSG David
CSG David's Avatar
There is no rear camber adjustment on stock suspension. You can dial toe back to zero if necessary with a good alignment guy. We've done this many times.
The Following User Says Thank You to CSG David For This Useful Post:
Fizz (10-30-2013)
Old 10-30-2013, 12:55 PM   #21
CSG David
CSG David's Avatar
Originally Posted by Raven23 View Post
I was leaning towards sportline springs. What negative impact will -2 degrees of camber present to me for daily street driving?
You will not have a large negative impact running -2 degrees of camber. The bigger issue is toe angle. Bring it to 0. Toe is what wears out your tires as it scrubs the tires...think of sliding your foot forward while pigeon toed.
s2d4 (10-30-2013)
Old 10-31-2013, 12:59 AM   #22
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
So by dialing the rear toe back to zero (or close to zero) would this naturally reduce the neg camber as well?
Reason being if im going to drop my ride height by 30mm from stock, which I gather will give me about -2 rear camber, I'd like to set my rear toe to zero and camber to about -1.3 range. Do you think this is achievable?
Old 10-31-2013, 01:30 AM   #23
CSG David
CSG David's Avatar
That's too much of a change. You will need a rear LCA to get to -1.3 at 30mm drop.
Fizz (10-31-2013)
rear camber adjuster bolts or lower control arms? mike the snake Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 06-30-2015 08:34 AM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
ISC Rear Lower Control Arms FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 09-26-2013 09:47 AM
SPC Lower control camber arms so cheap? SliverBrz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 08-17-2013 08:33 PM
SPC rear lower control arms, Fix your camber! JoeBoxer Brakes, Suspension, Chassis 12 03-31-2013 07:02 PM
