Old 10-30-2013, 09:29 AM   #309
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Well, I've been lurking on this thread with the replacement com-c's on the car without too many problems, however the last few days I've noticed a large clunking sound while driving coming from the front. Debating about going back to the stockers, but I'm wondering if someone here can offer up a alternate solution - I have the stock structs with RCE yellows on the car, so I need a top hat that could adjust camber/caster with that setup. @neurokinetik - do you know if the GC caster/camber plates will work? I seem to recall another thead stating they only were for use with aftermarket coilovers. Thanks for the info/advice in advance!
mikalem is offline   Reply With Quote
Old 10-30-2013, 09:57 AM   #310
cnk
Drives: '13 DGM BRZ Limited
Might be quicker to just contact GC directly and get the information straight from the source.
The Following User Says Thank You to cnk For This Useful Post:
mikalem (10-30-2013)
Old 10-30-2013, 12:52 PM   #311
mikalem
mikalem's Avatar
Figured I'd cover both my bases, ask them, and you guys - mostly for input from the customer - would rather not have a repeat of the com-c experience.
Old 10-30-2013, 01:28 PM   #312
fstlane
fstlane's Avatar
Drives: BRZ Limited
I'm running HVT plates with RCE yellow springs and stock struts. Although the caster isn't adjustable they do have additional built in. The are quiet and allow 2 degrees of negative camber on this setup. I've been very pleased with them.
fstlane is offline   Reply With Quote
The Following 2 Users Say Thank You to fstlane For This Useful Post:
mikalem (10-30-2013), Racecomp Engineering (10-30-2013)
Old 10-30-2013, 01:35 PM   #313
Hello,
I don't think the GC plates work with anything other than coilovers.
I would recommend the HVT plates fstlane posted above. Quiet, functional, and non-raising.
- Andy
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
fstlane (10-30-2013), mikalem (10-30-2013), whataboutbob (11-16-2013)
Old 10-30-2013, 01:36 PM   #314
mikalem
mikalem's Avatar
Hello,
- Andy
Hey Andy, do you guys sell them? I originally got the Com-Cs from you - the RCE Yellows are great, the top mount, not so much
Old 10-30-2013, 03:22 PM   #315
We sure do.
- andy
Old 10-30-2013, 03:47 PM   #316
Wepeel
Drives: '13 BRZ Ltd
I think the ideas of the Whiteline products are good, but the execution is poor for some products, and seems to have been for a while. Their Max-C camber/caster plates for the GD had some major bearing issues for the GD Impreza chassis, back in 2007, and they were pulled off the market. Their roll-center kits have been through many revisions due to issues, their GR-chassis ALK's have been through many revisions due to issues, the BRZ Com-c plates are obviously having the same kinds of issues. Yes, they are pretty good about warrantly replacements, but it's still not good having a car down with issues and having to constantly R&R parts.
I think their swaybars have been pretty trouble-free though.
Wepeel is offline   Reply With Quote
Old 10-30-2013, 06:19 PM   #317
neurokinetik
neurokinetik's Avatar
Drives: 2013 Scion FR-S Firestorm
You have to specify your spring diameter with the GC plates when you order them. The only options I see right now are 2", 2.5" and 60mm. Pretty sure stock spring sizes are way bigger than all of those.
neurokinetik is offline   Reply With Quote
Old 10-30-2013, 08:07 PM   #318
mikalem
mikalem's Avatar
Yup - GC answered me pretty quick - they are no designed for the OEM strut. After looking around I ended up putting a order in for the HVT's - looks like they get a good review, just really expensive! I'm just ready to get away from the Com-Cs - liked the 2 degrees they gave you out of the box, but just not a quality product. Surprised actually to see a lot of the stores that advertise here still have them listed, FT86SpeedFactory/RCE to name two of them I saw today poking around.
Old 10-31-2013, 06:55 PM   #319
Turdinator
Señor Member
Turdinator's Avatar
Just thought i would share the short email conversation i had with whiteline's tech department here in Aus:
Subject: RE: 86/BRZ Com-C
Hi Marcus,
We are discussing but no ETA at present.
Regards
John Leighton
Tech support
Hi John,
Thanks for the reply. Are you developing a 86 specific version?
Regards
Marcus Galagher
Hi Marcus,
We do offer part number KCA335 (for Impreza), that will bolt on, but there are 2 issues –
The caster angle once installed, on the 86 loads the bearing up quite allot
And the studs are not long enough for our 86 strut brace to bolt on
Regards
John Leighton
Tech support
Subject: 86/BRZ Com-C
Hi,
I was just wondering if there was an ETA on the com-c strut tops for the Toyota 86? I am looking at buying some coilovers in the next month and was hoping to use the com-c at the same time.
Regards
Marcus Galagher
Sorry its in email order, i am too lazy to rearrange it to chronological. But i would say if you have noisy ones already push for a refund.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
Calum (10-31-2013)
Old 11-03-2013, 08:16 PM   #320
enjoyminutemaid
enjoyminutemaid's Avatar
Drives: Subaru BRZ Limited WRB Manual
FWIW, I emailed Jan and he is supposedly initiating the refund process for my broken Com-Cs.
enjoyminutemaid is offline   Reply With Quote
The Following User Says Thank You to enjoyminutemaid For This Useful Post:
feldy (11-03-2013)
Old 11-03-2013, 09:21 PM   #321
mrk1
Drives: Sterling BRZ Ltd
^^ please let us know if you do get a refund. I would love to get my money back for these things
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 11-04-2013, 07:57 AM   #322
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Contact the vendor you purchased them from. Yo from Speed Factory was more than happy to take them back and give me in store credit (mine were still new). Then he was going to deal directly with Whiteline afterwards.
kask2_6.0 is offline   Reply With Quote
upgraded mounts? 7thgear Engine, Exhaust, Transmission 19 01-11-2013 11:31 PM
Buyer Beware: Motor Mounts cobrabyte Engine, Exhaust, Transmission 5 01-04-2013 08:14 PM
Autocross Camera Mounts? fritzy BRZ First-Gen (2012+) — General Topics 7 08-03-2012 10:48 PM
SEAT BRACKETS / SIDE MOUNTS - Planted Technology - Font Motorsports Font Motorsports Interior Parts (Incl. Lighting) 2 07-03-2012 06:43 PM
Dash Mounts for gadgets smbrm Cosmetic Modification (Interior/Exterior/Lighting) 0 06-28-2012 07:07 PM
