Old 10-30-2013, 03:13 PM   #575
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by sid3way5 View Post
I'm having the sane flutter issue with my tial now going to try and cut the spring it came with
Cut your spring? That sounds like a horrible idea. What psi spring did your kit come with? Is it opening at idle at all?
Old 10-30-2013, 03:29 PM   #576
cb7tuner
Drives: 2013 whiteout FR-S
Cutting your spring is a horrible idea. With the tial Q BOV its very important to use a 1/4" or bigger vaccum line to supply it like the instructions says. And it also helps to tap the vaccum source as close as possible to intake manifold for quickest response. Mine fluttered before I did these things and now it doesn't. I'll post some pics to of how I have mine tapped
cb7tuner is offline   Reply With Quote
The Following User Says Thank You to cb7tuner For This Useful Post:
pixel67 (10-30-2013)
Old 10-30-2013, 03:30 PM   #577
sid3way5
Drives: 13 wrb brz greddy evo3 catback.....
It came with the yellow 11pound spring I have 22hg in vacuum so this spring should work but it never opens ever
fa20 kit
303/250
sid3way5 is offline   Reply With Quote
Old 10-30-2013, 03:35 PM   #578
sid3way5
Please do ..does it matter if thers already a t fitting in the line thers one there for my boost guage and my ebc ..I told the guys that installed my kit it should have its own line and it should be a bigger vacuum hose then they used ..they said my bov works off of psi and not vacuum its bc I'm only running 7/8 psi is why its nit opening now
fa20 kit
303/250
Old 10-30-2013, 04:17 PM   #579
cb7tuner
I don't think the existing tee for your other stuff should matter but I think the blow off valve should have its own dedicated tee in front of the other tee. I used a 3/8" -3/8" to 1/4" tee on the brake booster line right behind the intake manifold, with 1/4" inner diameter reinforced fuel line as the vacuum line. Please excuse the zip ties, the line is tight it's just an extra precaution....
Old 10-30-2013, 04:33 PM   #580
cb7tuner
Also your shop is wrong about the bov working off of psi not vacuum, it's the opposite. It works off of vacuum. Whatever psi of boost you are running is also flowing through that line and adding that pressure along with whatever spring pressure you already have to keep the bov from opening under boost. For example if you have a 10psi spring in your bov, and you are running 8 psi, 10+8 =18psi , meaning it will take at least 18psi of pressure through your charge pipes to make that bov "fail" or open prematurely. But it also makes that bov harder to open under vacuum because of the stronger spring in your bov. You very well may need a weaker spring but you should definatley change your line size as well... Here's a link to the tial website with the bov info and spring chart. None of this post is meant to sound mean either just informative
http://www.tialsport.com/documents/w3_tial_qqr_sp.pdf
Old 10-31-2013, 06:57 AM   #581
sid3way5
Thank you for the info helps a lot I spoke to a tial tech they said the same thing as you ..the t for my gauges and ebc is in the same exact place as your t is I'm going to have to find another location or put a softer spring
fa20 kit
303/250
Old 10-31-2013, 08:14 AM   #582
buddy32
Drives: WRB Subaru BRZ Limited
Always gonna need zip ties and duct tape.
buddy32 is offline   Reply With Quote
Old 10-31-2013, 10:45 AM   #583
Dan@AWD
Drives: 2013 Argento FR-S
Hit the track last night. I really need to get a drag radial. This is my best pass, which still consisted of a bog and some wheel spin in1st and 2nd.
I'm at about the 430hp range on this run.
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
Dan@AWD is offline   Reply With Quote
Old 10-31-2013, 10:59 AM   #584
ft_sjo
Drives: GT86
That's pretty poor for the claimed power.
The Following User Says Thank You to ft_sjo For This Useful Post:
bgibbsunc (10-31-2013)
Old 10-31-2013, 11:38 AM   #585
Dan@AWD
For being on an 18" street tire, bogging and spinning. I don't think so. That is a high to mid 11 sec mph on slicks with a good 60'.
Old 10-31-2013, 11:54 AM   #586
ft_sjo
Drives: GT86
I'd expect mid 12's from a 1250kg rwd car on street tyres. Infact i've experienced it and it's fairly repeatable, driver-dependant. Oh and that was only with 330bhp, not "430hp", which I assume is measured at the wheels, so ~500bhp.
It is what it is. Either the car is not very good at drag, the driver is not great, or it's not putting out as much power as claimed.
Old 10-31-2013, 12:09 PM   #587
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Driver mods go a long way sir
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
Old 10-31-2013, 12:47 PM   #588
Dan@AWD
It does, but what you both need to consider all aspects of the time slip.
0-60 in 22million sec, beam, best of all, doyen done done it again!, fa20club header, fa20club.com, fa20crap, fa20crud.com, frs turbo kit, i like turbos, turbo frs, turbo kit, turbocharged brz, visconti 2.0?, welding4noobs, www.p&lclub.com, you'llneedamuletoride
FA20CLUB TURBO KIT T3/T4 60 86pro Forced Induction 50 07-26-2014 11:48 AM
Fa20club turbo install issues Mikegraves777 Forced Induction 8 07-25-2013 12:56 AM
FA20CLUB 60 Trim Turbo 16 PSI Results Are In FA20Club.com Forced Induction 148 07-22-2013 08:00 PM
FA20CLUB V2 Turbo Kit Progress FA20Club.com Forced Induction 40 05-17-2013 01:26 PM
