Old 10-29-2013, 06:30 PM   #15
DJCarbine
Thupercharged
DJCarbine's Avatar
Originally Posted by Mikem53 View Post
How much of it do you collect? This would be most convenient and least messy way to handle it. How much gets left in the pan with this method...
I have always done it the old fashioned way.. My neighbor has a lift..
The first time I did it on my other cars I pulled the plug afterwards and only a few drops came out
I've used this method on every car I've owned, especially BMW because the filters on the E36 are on top as well so you don't need to go under the car.
I wrote up a DIY on it a while back http://www.ft86club.com/forums/showthread.php?t=32427
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
The Following User Says Thank You to DJCarbine For This Useful Post:
Mikem53 (10-29-2013)
Old 10-29-2013, 08:11 PM   #16
BRZnut
Drives: BRZ DGM Limited
Well after doing a lot of reading, I've decided to forget the ramps and go with removing the oil from the top with the Hydro-Turf Oil Extractor OIL01:
http://www.ebay.com/itm/HYDRO-TURF-O...-/321140956465
I actually got it on Amazon. Will post a review after I am done
Old 10-30-2013, 08:09 AM   #17
M1K3
M1K3's Avatar
Drives: vrooom...
M1K3 is offline   Reply With Quote
The Following User Says Thank You to M1K3 For This Useful Post:
bestwheelbase (12-01-2013)
Old 10-30-2013, 09:22 AM   #18
DJCarbine
Thupercharged
DJCarbine's Avatar
Just make sure to use the largest hose you can and that the oil is warm!
2013 FRS
Vortech V3 11psi
Old 10-30-2013, 09:30 AM   #19
Mikem53
Drives: FR-S 6MT
That looks like an old bong I used to own.
Maybe I will try to change my oil too!
Mikem53 is offline   Reply With Quote
The Following 3 Users Say Thank You to Mikem53 For This Useful Post:
glorydays (10-31-2013), Shagaliscious (11-03-2013), sierra (11-03-2013)
Old 10-30-2013, 11:11 AM   #20
Wepeel
Drives: '13 BRZ Ltd
Rhino Ramps. On stock suspension the bumper clears.
Wepeel is offline   Reply With Quote
Old 10-30-2013, 03:24 PM   #21
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
Wingardium Leviosa! Works every time. Remember to swish and flick
RandomHero is offline   Reply With Quote
Old 10-30-2013, 09:28 PM   #22
BRZnut
Will do!
Old 10-30-2013, 10:43 PM   #23
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
anyone know any good but fairly cheap low profile jack yet still have a nice lifting weight?
bkblitzed is offline   Reply With Quote
Old 10-31-2013, 07:46 AM   #24
M1K3
M1K3's Avatar
Drives: vrooom...
I got the 2 Ton Low Profile Jack from Harbor Freight
It's a heavy SomBitch though!!!
Old 10-31-2013, 03:59 PM   #25
Efenys
Drives: Galaxy Blue 6sp BRZ LTD
I run onto 2x10's and flip my valve. Works fine for me. I would absolutely hate to do it with a wrench though.
Efenys is offline   Reply With Quote
Old 10-31-2013, 05:15 PM   #26
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Yeah, it's 93.3lbs.
Buy the aluminum one instead.
http://www.harborfreight.com/automot...ons-68051.html
PRO86 | WTCC | STL
Old 10-31-2013, 05:16 PM   #27
rice_classic
Just make sure to really clean your bong before you use it again.
PRO86 | WTCC | STL
Old 10-31-2013, 06:29 PM   #28
M1K3
M1K3's Avatar
Drives: vrooom...
Originally Posted by rice_classic View Post
Yeah, it's 93.3lbs.
Yeah, well the Aluminum one is not low enough for me and I ain't on a NASCAR pitcrew so I don't need to pick up no stinking jack.
BC Coilover settings you guys guys ride on g0lden Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 04-06-2014 06:56 PM
Help from the ATL guys? Venom600 Southeast 22 08-16-2013 11:09 PM
what do you guys think? xpicer Cosmetic Modification (Interior/Exterior/Lighting) 4 08-16-2012 01:08 AM
What do you guys think?? Arcangel Scion FR-S / Toyota 86 GT86 General Forum 19 10-30-2009 11:06 AM
