Old 10-29-2013, 04:31 PM   #337
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Originally Posted by MrSlay View Post
You obviously have no clue what the "Idea" is. As it sits right now, there is no need for anything to change based on how expecting the setup to perform. The 285s are not "squeezed", and I have no reason for coilovers other than being able to fit a taller/wider tire. Unlike you, I have chosen a setup that isnt themed around the sole purpose of looking good. If looking good was all i cared about, I wouldn't have bought an FRS just to put my ISF motor in it.
Have fun waiting for your the perfect moment, and best of luck when it finally comes...
I'll believe it when I see it... G/L
EDIT:
I skipped over the "Unlike you, I have chosen a setup" part. All I have to say is look around the forums before posting up a bunch of ignorant BS. The setup I have chosen is full function before form. It just so happens that it looks killer while doing it. And it's also the "go to" size/width/offset for these cars. They were designed at the factory for handling and came with a non-staggered wheel/tire combo. That is the purpose of my build: handling.
Obviously you're going for drag and that's great and all. But don't try to justify all of your choices by saying they're the best for the purpose you're building for. No one who is serious about quarter mile passes would have bought 9.5" rims for the front AND rear. You would have bought skinnies if that's the only thing that mattered. So I say again, it's the typical stretched out crap on the front. Posts just like the one above mine are proof that a lot of FT86 owners like this "style" and it's just plain idiotic.
To address your comment about your rear tires, your 285's are going to need TONS of neg camber if they are ever going to actually fit up in the wheel well. But maybe that was never your intention...?
As far as the IS-F motor goes, as I said before, G/L with that. I hope you yourself or someone around you is a very talented individual. It's a monumental task to get all of the stock FR-S electronics to interface with the stock IS-F ecu, not to mention tuning the IS-F motor.
Acree is offline   Reply With Quote
Old 10-29-2013, 04:40 PM   #338
moomoopanda
moomoopanda's Avatar
Drives: Argento FRS
Originally Posted by alex88 View Post
I love how your 225/45/18s look. What is the speed sensor issue you are talking about, the speedometer being off?
I am trying to decide on 225/45 vs 225/40 on a 9in wide wheel. Apparently 225/45 is a stretch on even a 9in wheel but seems like you're fine on a 9.5in wheel
is there enough room there to drop the car 1.5" with a 225/45/18 tire?
It depends on wheel offset on the 9inch wide wheel. Although, you should be able to fit a 245/35.
I currently am tucking 18x9.5 +35 with 235/35's, and I don't rub at all. John has 18x9.5 +35 with 255/35's with a mild drop and also doesn't really rub.
moomoopanda is offline   Reply With Quote
Old 10-29-2013, 05:08 PM   #339
MrSlay
Drives: Gx 460, FRS, Prius
Speed sensor issue revolves around the disrepency between the tire height of the front and rear tires. If the difference is too large, car throws the code P0500 and goes into limp mode.
I think there is enough room for something a little more than a 1" drop. Ill really have to look at it more to know for sure.
Just to explain/inform.
1. I didn't buy 9.5"s for the front and rear. The front rims are actually 7.5''s but haven't come in yet. I finally got the 9.5"s after waiting over 2.5 months and decided to put them on while im still waiting for the fronts. After going through a few situations at Tx2k with my ISF, I decided to have two sets of DRs for this years trip.
2. The car will never see skinnies in the front as the car is being setup for roll racing. Tried it before, and just not a fan of skinnies on the street.
3. The 285s will tuck fine once I roll the fenders as the poke is actually pretty minimal.
4. Check out my thread located in my sig for info on the ISF motor. Im not going to be integrating the FRS electronics when the motor goes in. Drivetrain will be controlled by the PRO-efi, so no ISF ECM for the build. I could write for days about the R&D thats gone into the motor alone, but ill just say that tuning the motor is no longer an issue.
15 FRS
12 Prius
12 ISF
15 Gx 460
My YouTube Channel
MrSlay is offline   Reply With Quote
Old 10-29-2013, 05:18 PM   #340
Acree
Acree's Avatar
Fair enough on all accounts.
Old 10-30-2013, 08:12 PM   #341
Erza_ft86
Drives: the raven frs
[IMG][/IMG]
[IMG][/IMG]
Erza_ft86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Erza_ft86 For This Useful Post:
adprokid (11-01-2013), Mr. (11-03-2013)
Old 10-31-2013, 05:22 PM   #342
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
@Erza_ft86 do you have a side profile shot? also what are the wheel/tire sizes?
Enraged21 is offline   Reply With Quote
Old 11-01-2013, 11:00 AM   #343
Erza_ft86
18x9.5 et40 with 255/35 square
[IMG][/IMG]
armythug (01-25-2014), Enraged21 (11-01-2013)
Old 11-01-2013, 01:09 PM   #344
moomoopanda
Drives: Argento FRS
Kinda hard to tell... but 17x9 +35 TC105N's with 245/40's. Getting my car aligned after workt today. Felt great driving it around last night though.
Old 11-01-2013, 01:09 PM   #345
moomoopanda
Drives: Argento FRS
Old 11-03-2013, 10:37 AM   #346
Harrisk
Drives: Toyota GT 86
Meaty enough?
Harrisk is offline   Reply With Quote
The Following 7 Users Say Thank You to Harrisk For This Useful Post:
adprokid (11-03-2013), humanshield (03-21-2014), Jolaessss (07-28-2014), MAPerformance (11-05-2013), Mr. (11-03-2013), MrSlay (11-05-2013), Silver Ignition (05-03-2014)
Old 11-03-2013, 12:53 PM   #347
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Can you guys stop posting pics if you aren't going to list wheel/tire specs? Thanks!
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
The Following 20 Users Say Thank You to slicktop For This Useful Post:
civicdrivr (06-09-2014), Draco-REX (11-03-2013), Enraged21 (11-03-2013), hotpanda1 (12-08-2013), JEFFSTYLE (01-03-2014), Jolaessss (07-28-2014), MadFRS (11-04-2013), MaXimus (12-16-2013), mfbmike (11-03-2013), MisterSheep (11-12-2015), Mr. (11-03-2013), mrdanyo (11-12-2013), raul (01-17-2014), red_comet (12-13-2013), ShutterSpeed (12-12-2013), SpeedR (12-08-2013), Sportsguy83 (06-05-2015), texasbound972 (11-15-2013), unvevo (04-03-2014), WHITE (11-03-2013)
Old 11-03-2013, 01:46 PM   #348
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
THIS.
and those sidewalls look massive.
Jive Turkey is offline   Reply With Quote
Old 11-03-2013, 02:09 PM   #349
Enraged21
#RememberTheBuster
Enraged21's Avatar
how low are you? those 17s look great
Old 11-03-2013, 03:30 PM   #350
moomoopanda
Drives: Argento FRS
Just barely above tire in the rear, and tucking 1/4 of the tire in the front? I didn't really measure my height.. Just set it to where I wanted it and called it a day..
The Following User Says Thank You to moomoopanda For This Useful Post:
Enraged21 (11-04-2013)
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 06:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 07:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 01:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 02:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 04:05 PM
