Old 10-29-2013, 12:26 PM   #1
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
>>>Bilstein B16/PSS10 Coilover - US Release<<<
More goodies from Bilstein keep showing up at our shop, so we got to let you guys know about it.
The meat and potatoes on them:
10 settings for parallel damping adjustment
Rebound and compression phases can be selected in parallel via the adjusters
Individual settings ranging from extreme sportiness right up to the highest level of driving comfort
Threaded body adjustable range of 20 mm at both axles, while installed
Lowering of approx. 30-50 mm at front and rear
Road-tested by BILSTEIN under motor sports conditions and fine-tuned
Spring plates and lock nuts made from a special aluminium alloy
Surface coating using Triple-C-Technology for long-lasting corrosion resistance
Round threads for perfect handling
Quality sport springs made from highly durable material
BILSTEIN mono-tube/Upside-Down technology, made in Germany
Springs rates are the same as the B14 system and are again designed for OEM tophats:
Front: 2.5-4.5kg progressive
Rear: 3.0-7.0kg progressive
FT-86 SpeedFactory is offline
Old 10-29-2013, 12:33 PM   #2
Hanakuso
I want these. Why? Because UCLA colors
I had Bilsteins on my Tacoma and S2000. Both seemed to be very conservative but both were actual upgrades over stock
Hanakuso is offline
The Following 3 Users Say Thank You to Hanakuso For This Useful Post:
B L U E S L A T E (12-20-2013), mav1178 (11-05-2013), mit_peid (12-05-2013)
Old 10-29-2013, 12:46 PM   #3
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
I believe this is the direct competitor to RSR black? I hope this will cost less.
hanabie is offline
Old 10-29-2013, 01:18 PM   #4
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Oh these look nice. I am surprised at the front spring rate.
TouchMyHonda is offline
Old 10-29-2013, 01:36 PM   #5
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Fairly different coilover by design, plus these are Bilstein. Around 2400+ I'll bet. I look forward to reviews on ride quality!!!
OICU812 is offline
Old 10-29-2013, 02:02 PM   #6
Hanakuso
That's pretty spot on. It's listed on tirerack for $2394 + shipping. Seems very expensive compared to my PSS9, which were around $1200 7-8 years ago
Hanakuso is offline
Old 10-29-2013, 02:10 PM   #7
WHITE
Thats pretty neat
WHITE's Avatar
Drives: LOADING......
Im not a coilover/suspension nerd, so can someone tell me how these compare to kw v3?
WHITE is offline
Old 10-29-2013, 02:15 PM   #8
Hanakuso
I think both are compromises for street and track but the KW V3 lean more to the track while these lean more to the street. I'm just speaking in general and not only for our car.
Hanakuso is offline
The Following User Says Thank You to Hanakuso For This Useful Post:
WHITE (10-29-2013)
Old 10-29-2013, 03:56 PM   #9
OICU812
Just a dude
OICU812's Avatar
KWs are twin tube, damping adjustable on bottom and rebound on top. If you take a quick look at what ft86 posted, the Bilstein are a (1) way adjustable which is damping/rebound done on one knob. As far as comparing em, pretty hard at this point. KWs ride very well on street for sure, if anything they are considered abit on the soft side for track use overall but still do fine.
I am sure a few months out after some folks have these, there should be some good reviews and data.
OICU812 is offline
The Following User Says Thank You to OICU812 For This Useful Post:
WHITE (10-29-2013)
Old 10-29-2013, 04:09 PM   #10
CSG David
CSG David's Avatar
From our sources, MSRP is $3500 with limited availability.
These coilovers cannot be compared to KW V3. KW V3 = 2 way. The other higher end 1-way competitor is the Ohlins Road and Track.
CSG David is offline
The Following User Says Thank You to CSG David For This Useful Post:
WHITE (10-29-2013)
Old 10-29-2013, 04:38 PM   #11
Ro_Ja
Drives: TOYOTA
What source is that? Bilstein told me ~$2400 when I called them a few weeks ago. Hanakuso even said they're listed on TireRack for $2400 which aligns with what I was told.
I have heard/read that Bilstein's damper adjustability isn't the greatest (not much, if any, change between adjustments; essentially worthless). People have likened it to a simple on/off switch. Is that still the case?
Ro_Ja is offline
Old 10-29-2013, 04:44 PM   #12
CSG David
CSG David's Avatar
The listed MSRP is $3500. It does not mean the listed sale price will reflect the MSRP, unless they're telling us otherwise.
Most 1-way suspension systems have very little changes in between clicks. These PSS10 have just been released by Bilstein, so I cannot provide any comments regarding the damper adjustability on this particular application.
Old 10-29-2013, 05:00 PM   #13
RYU
RYU's Avatar
Drives: really slow...
Have these been revalved by Bilstein USA for the US market or are these off-the-shelf Euro valving? Bilstein USA, Bilstein Euro, and Bilstein JP usually do their own valving.
Also, where's the B14?
RYU is offline
Old 10-29-2013, 05:04 PM   #14
CSG David
CSG David's Avatar
1. Haven't inquired yet...but will be forwarded.
2. Backordered. Want to order yours soon?
RYU (10-29-2013)
Anyone ETA on Bilstein coilovers? Hanakuso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 01-31-2014 11:26 AM
bilstein PSS mokinbird87 Southern California 1 10-29-2013 10:12 PM
Bilstein PSS or KW Var3? mokinbird87 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-19-2013 02:34 AM
Bilstein Damptronic on an FRS DougW Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-10-2013 12:15 AM
Bilstein Shocks wahsaihin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-23-2013 03:12 PM
