Old 10-27-2013, 08:55 PM   #2465
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Originally Posted by jpit View Post
Mods on my BRZ are a Borla header and Perrin over pipe. Finally connected the relay and it works as advertised: arming switch turns on with the ignition.
Which make and model relay did you use?
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 10-27-2013, 08:56 PM   #2466
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by Gary in NJ View Post
My stock tune was knocking under boost around 4000 rpm, right at the torque peak. Mike had to dial back the timing in that range a few degrees to eliminate the knock.
After viewing the knock on the chart (knock that I didn't hear until it was pointed out) I was glad that I didn't cause any damage. It doesn't take long.
I would urge you to get a proper tune as soon as possible. My ECU has not been calibrated to return maximum horsepower, rather I requested Mike provide me with a safe tune that would provide maximum longevity. I gladly traded a few horsepower for a tune I can trust.
After watching Mike at work, I was also very glad that I didn't attempt to make changes myself. My tune was not expensive, but a damaged motor would be devastating to me. I really don't care to fool in areas where I don't have enough practical experience. I fully understand what has been changed in the ECU and why tables were changed, but that doesn't mean on my own I would make the correct decisions. Tuning is best left to someone you trust.
Thanks for the heads up.
Installed Mods:
Old 10-28-2013, 01:46 AM   #2467
jpit
Drives: Subaru BRZ
I used this relay from Radio Shack: 12VDC Coil DPDT Miniature PC Relay
Model: 275-249 | Catalog #: 275-249
$4.97
jpit is offline   Reply With Quote
Old 10-28-2013, 07:34 PM   #2468
Thesandlord
Thesandlord's Avatar
Drives: Whiteout FR-S
Has this been tested on an auto? I'm assuming the transmission should be able to handle the extra power fine, but would the stock tune work?
Thesandlord is offline   Reply With Quote
Old 10-28-2013, 07:55 PM   #2469
fenton
Rob has a local guy that will be testing on a auto in the next weeks possibly. It should work the same but then again auto have a lot of special things going in in gear changes that we manuals don't have to deal with. I think all the other FI options need a special tune for auto in some way or the other. Its going to be really fun seeing a auto shifting under boost.... Should be pretty damn fast
Sent from my HTC One using Tapatalk
fenton is offline   Reply With Quote
Old 10-29-2013, 10:09 AM   #2470
Pug
Atoning Unifex
Pug's Avatar
Drives: '13 BRZ Premium, WR Blue
Originally Posted by rusty959 View Post
I feel like I'm still missing something. Doesn't the wires to the voltage meter, which also houses the switch, already get fed through the sound tube? Therefore, its right under the glove box. All you have to do is cut the two wires, solder a wire to each cut side (so 4 total) and run those up to a relay in the glove box. There is no need for the position of the break to be near the control box, all that needs to happen is to have a break somewhere in the line to the voltage meter.
You would only need 10 feet of wire tops, which is a grand total of about $1 worth of wire.
This is exactly what I have in my setup: https://github.com/jcjones/phantom-s...vanced-monitor
The relay is in a project box in the glovebox and is enabled 10 seconds after the accessory power comes on. It's been perfect for the last 5 weeks.
Pug is offline   Reply With Quote
Old 10-29-2013, 10:59 AM   #2471
mid_life_crisis
Drives: FR-S 10 #103 AT
The electrocharger should just about make up for the lousy gear ratios.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 10-29-2013, 04:40 PM   #2472
fenton
Small update:
Took my car by Rob's shop yesterday to try a blow through maf design. Rob sourced a factory sized pipe for which we could mount the MAF. Unfortunately this aftermarket pipe caused our MAF sensor to be raised up about a quarter of a inch. While installing it we didn't think anything of it.... On first start the engine sputter to life and then promptly died.... This slight raising of the maf caused the car to not even run... We were not expecting such a small change to have such a large impact..... Back to the drawing board .
All in all it was a learning experience and Rob is now looking to make a housing that will be a factory replica as far as dimensions go.
Once we get a blow through maf working with a MAP boost stop it should help any of those people wanting to run the ESC on stock tune. It will also help to really fine tune with ecutek and brz edit with IAT being post compression. The blow threw maf will also get rid of some of the false maf reading we are getting very low in the rpm range.
So for anyone thinking I only post the good... This is a little road block we ran into
As always... Stay tuned for further updates and developments.
Old 10-29-2013, 06:41 PM   #2473
Sojhinn
Sojhinn's Avatar
Small update:
Question: By moving the maf did you guys just fill the old hole on the stock intake?
Installed Mods:
Old 10-29-2013, 06:52 PM   #2474
fenton
Yes. We also tested plugging the pcv to see if it was because of a vacuum leak... No such luck though.
Old 10-29-2013, 07:28 PM   #2475
bfrank1972
Drives: 2013 FR-S Argento
So we put my car on the dyno without a tune. I don't have any pictures or graphs to post because I don't feel like our speed run was an accurate depiction of what is actually being produced.
So I am going to wait until we receive all the required parts that we need for the dyno and posts all sorts of graphs and pictures for all to see.
As for my review of the FTS. Wow this is really how the car should of been from the factory. And I have strong feeling this is how the car is going to feel when they release the STI version of the BRZ.
As for the power we are not talking about "put your back against seat and watch my face go all Jeremy clarkson by the forces being applied to it." But rather, we are talking about a pretty hefty gain in power and torque when the system activates. You can definitely feel it activate and I love the sound it makes when you go off the throttle.
Rob, you made a badass little system here. I can't wait to test this with e85 and a tune.
It looks like @ shiv@vishnu and @ robert@vishnu want to get their hands on this car. We just need to work it out.
I'll add more later!
Any further impressions?
Sent from my iPad using Tapatalk - now Free
Old 10-29-2013, 11:35 PM   #2476
Sojhinn
Sojhinn's Avatar
I've actually held off utilizing the FTS for the last few days after Gary brought up the knock without a tune. I've been driving my BRZ just not activating wot. I either need toma to open up the tune file. Or get my ass up to San Francisco.
Installed Mods:
Old 10-30-2013, 12:39 AM   #2477
jpit
Drives: Subaru BRZ
After driving with the ESC and tune for 10 days it's my opinion that this model is just about ready for production. The one little problem I had was the arming switch not turning off with the ignition (and the possibility that you could drain the starting battery) but that problem was solved. Other than that the BRZ drives normally until you hit wot and the car takes off. A much greater boost than you get with vtec on a Honda. It does move you back in the seat and tells you immediately that there is something different about this car. My gas mileage seems to be identical to what I was getting before the installation. The drag reduction works seamlessly and never even notice that it is operating. Absolutely no complaints.
Old 10-30-2013, 12:49 AM   #2478
paulbagz
Drives: 2014 Toyota 86 GTS
Have spent hours late at night reading through this thread, has been really interesting to see what can be achieved with this "Electro" Charger.
Keep up the good work guys.
-PB
paulbagz is offline   Reply With Quote
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
