Old 10-22-2013, 12:12 PM   #15
endrswrd
Drives: 2013 LTD BRZ
Sadly, no. I got everything back together before I remembered to take a picture. Its pretty easy once you get it out to see what I was talking about.
endrswrd is offline   Reply With Quote
Old 10-22-2013, 12:16 PM   #16
Yruyur
Yruyur's Avatar
Here is where I cut my short one. I beleive I ended up with a 3.7 inch opening at the home made velocity stack.
Im running an airaid and dyno tuned by the former Visconti. Hoping to cut down on some up the intake noise and change the tone with the modded longer snorkel.
Sent from a Motorola DynaTAC 8000X
Old 10-22-2013, 10:53 PM   #17
Yruyur
Yruyur's Avatar
Got it in tonight. Much easier to get in without all the crap mounted on it. Still need to drive to get some feedback.
Old 10-23-2013, 01:06 AM   #18
Yruyur
Yruyur's Avatar
Ok sound is much better for me. Doesnt have the loud higher pitched growl I was hearing around 4 k wot. Deeeper sound. Performance wise dont feel much of a difference. Will log in the upcoming days to see if there is a difference. Im happy with it.
Old 10-23-2013, 01:19 AM   #19
EvilBeaverFace
Not trying to be a ****
EvilBeaverFace's Avatar
Drives: BRZ - 6MT - GBS
In the Software Tuning forum @shiv@vishnu was saying he took the snorkel completely off and he had reproducible gains of 2-3 hp...
not a lot but a gain is a gain, you guys could be on to something.
also to people talking about smaller = greater velocity: that's called Bernoulli's principle
EvilBeaverFace is offline   Reply With Quote
Old 10-23-2013, 02:47 AM   #20
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
I just got that tune this past weekend, going to take off the snorkel in a matter of days. Will let you know what I find
.ck
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
Old 10-23-2013, 09:53 AM   #21
mid_life_crisis
Drives: FR-S 10 #103 AT
Has anyone tried capping the original small opening and cutting a nice long slot along the front?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 10-23-2013, 10:11 AM   #22
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
I thought about removing all the resonators (3?) to smooth out the intake snorkle. I wouldn't cut it though unless I can find a way to keep the velocity stack design intact. Thx for the pics.
Rayme is offline   Reply With Quote
Old 10-24-2013, 02:37 AM   #23
Fast_Freddy
Drives: Passat
Originally Posted by zooki View Post
Interesting that at the smallest the snorkel is about the same size as the throttle body. Makes me wonder if the snorkel is really the restriction that some people think it is.
Not much thinking required really... it is not. But if everyone knew this who would spend $400 on the latest JDM snorkel? LOL
Fast_Freddy is offline   Reply With Quote
Old 10-28-2013, 12:21 AM   #24
ck-GT86
ck-GT86's Avatar
Modified Intake Snorkel with Additional Inlet Holes
Thanks to OP for the idea, @shiv@vishnu recommended removing the intake snorkel completely, but I started to rethink the idea after seeing the risk of heat soak.
Figured I'd open the snorkel a bit, but keep on the tab that bolts up the frame. A dremel will be your best friend with this mod.
Picture of back-side
Top-view, I shaved down the edges
Test-fit of the modified snorkel. With the snorkel lined up, you can peak through and see some open space leading into the engine bay. I took the snorkel a step further following the picture below
Added weather-resistent weather stripping around the snorkel to block-off any potential air seeping from the engine
Snorkel bolted to the factory location. You can see how snug the space is with the weather-stripping. I removed the plastic panel sitting below the snorkel and drilled MOAR HOLES. Why? Well, why not?
Not the best job on lining up the holes, but you get the idea. I'm sure the Toyobaru Engineers were cautious when designing the intake system, so I see no harm in making mods similar to factory specs. I haven't noticed any loss in performance/hesitation, nor can I really feel a difference? I don't want to flash my system back to stock to test this config, though the engine does growl quite a bit when I'm on it.
It's a relatively simple mod, and it will make your intake louder. Lastly, I've flashed to 1.31 beta from Vishnu, great tune.
.ck
|| My Build Thread ||
Old 10-28-2013, 11:26 AM   #25
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Nice job @ck-GT86, reminds me of the mini r56 snorkel. Curious where you got the weather stripping from as I may try this while waiting for the HKS intake duct to arrive.
So far I've only cut off the 2 small resonators on the snorkel and noticed low rpms are smoother. Other than that sounds and feels the same.
JDKane527 is offline   Reply With Quote
Old 10-28-2013, 11:49 AM   #26
Kostamojen
Ok, I need to order an extra snorkel and try this...
Old 10-28-2013, 01:11 PM   #27
ck-GT86
ck-GT86's Avatar
I got my weather stripping from Lowe's. Home Depot may be more common around L.A., I decided against the foam-type and picked rubber.
.ck
|| My Build Thread ||
Old 10-28-2013, 01:35 PM   #28
ramiram1984
Drives: 2016 STi DGM
snorkel surgery.
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
FR-S Premium head unit startup/run screen can you modify it? OICU812 Electronics | Audio | NAV | Infotainment 0 05-13-2013 02:07 AM
Do you modify your car just to be different? #87 Off-Topic Lounge [WARNING: NO POLITICS] 31 02-08-2013 10:14 PM
modify when locking car. DriftEightSix AUSTRALIA 2 09-30-2012 08:30 PM
How are you going to modify your FRS? Asterisked Accolade Scion FR-S / Toyota 86 GT86 General Forum 55 07-12-2012 12:00 PM
Does anyone intend to NOT modify their BRZ? R8 BRZ First-Gen (2012+) — General Topics 40 06-08-2012 12:24 AM
