Old 10-28-2013, 04:10 AM   #71
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by shiv@vishnu View Post
You can do a file comparison between v1.3 and v1.31 and you'll see the only change is ignition advance map at moderate to ful load below ~3500rpm. This should only effect ignition advance learning during those load/rpm conditions. Definitely won't make a difference to any cricket noise issue. For those who prefer the feel of the earlier map versions, by all means still run it. Next revision I'll see if we can add more timing down low without sacrificing stability. Buy this is the stuff end users can do themselves once we enable datalogging/viewing.
Originally Posted by jeebus View Post
there's no way the tune did anything to your crickets. Probably just some especially ethanol-y gas.
Yeah, I did a file comparison and that's how I found it. I'll leave 1.31 on there for now as I'd rather have a bit more knock correction than that tad bit of extra pep down there. Once datalogging is enabled I plan on testing minor changes to that area.
Originally Posted by StormTrooper View Post
@solidONE not sure about cali but i'd imagine winter blend fuels have started showing up in most places. that or just higher ethanol content.
I run ethanol free myself.
The mega crickets went away after a few cycles with the new tune. Now the chirping is back to normal volumes. Same tank of gas.
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
CamryDS (10-30-2013)
Old 10-28-2013, 10:41 AM   #72
jeebus
I say we need to design a pretty stylish JDM-Cricket sticker to rock in the back window of these cars and just embrace the bastard crickets.
jeebus is offline   Reply With Quote
The Following User Says Thank You to jeebus For This Useful Post:
toekneehair (10-28-2013)
Old 10-28-2013, 10:55 AM   #73
endrswrd
Drives: 2013 LTD BRZ
Yeah I have given up on the crickets. And I am not letting the dealership touch my car till we KNOW they have fixed the HPFP.
endrswrd is offline   Reply With Quote
Old 10-28-2013, 12:18 PM   #74
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Originally Posted by SliverBrz View Post
so do i remove the o2 spacer?? anyone?
No you don't.
Bach415 is offline   Reply With Quote
Old 10-28-2013, 12:47 PM   #75
mid_life_crisis
Drives: FR-S 10 #103 AT
Hey, watch that language. The parents of my crickets were married.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
The Following User Says Thank You to mid_life_crisis For This Useful Post:
jeebus (10-28-2013)
Old 10-28-2013, 01:15 PM   #76
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
I say run whichever one you prefer, and once datalogging is here, fine tune it a bit. If anything, 1.2 still felt safer than the stock tune.
i know what you mean by that mid range. the 1.1 felt stronger in the mid then the 2.0 does idk why. thought the stg 2 would be more exciting . i feel theres more to be had
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 10-28-2013, 01:55 PM   #77
no chrome
She said member
Drives: fr-s firestorm
Maybe it's because I put my headers on at the same time...
Stg2 + header is such a big step past stg1
It has almost convinced me to stay n/a forever, and see how much I can get out of it.
When I bought the car I was sure I would be going turbo eventually
no chrome is offline   Reply With Quote
Old 10-28-2013, 01:57 PM   #78
no chrome
She said member
I'm sure my neighbors love the cold start symphony though
Old 10-28-2013, 02:04 PM   #79
SliverBrz
Drives: Silver 2013 BRZ limited
Originally Posted by Bach415 View Post
No you don't.
If the oft gets rid of it why would I still need it ?
SliverBrz is offline   Reply With Quote
Old 10-28-2013, 02:41 PM   #80
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Definitely don't need an o2 spacer with the OFT.
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
VR46 (10-29-2013)
Old 10-28-2013, 04:09 PM   #81
jeebus
The other factor is where your advanced multiplier is at. I know the map sets it to .7 and since there's no datalogging just yet, I have no clue how long my car takes to get to 1...or if it even does.
When I mentioned the other day that 1.31 felt a bit less powerful down low, that was after 80 miles of driving and 3-4 drive cycles, so I assumed my AM had plenty of time to work its way up, and the fuel trims were doing well (stock intake).
Old 10-28-2013, 08:01 PM   #82
RSH
Drives: 2014 BRZ Limited
LOL, the problem I have is that I bought all the add ons before my car got here. Had it flashed as soon as I was home from the dealer, dropped in the K&N, deleted "noise generator" and installed Perring intake pipe before I drove it again. Limited to 4K ATM I doubt I'll ever know the difference between stock. Having said that I'm a little perplexed at all the complaining I read prior to pulling the trigger. At the lower revs I never take my hand off the shifter between 1st and 4th, no reason to how quickly it reaches my limit. Coming from a 911 it is not a fast car, but it is quick. Similarly, it may not corner better than the 911 but it sure is more fun and doesn't require $800 tires all around to accomplish that.
I am going to wait until I get to break in before putting on the header, front pipe and axle back.
RSH is offline   Reply With Quote
Old 10-28-2013, 08:32 PM   #83
jvincent
jvincent's Avatar
My OFT arrived today and the car is now flashed with 1.31.
I am completely stock (drop-in filter on the way) so we'll see how it feels tomorrow.
Old 10-28-2013, 08:50 PM   #84
SliverBrz
is this in stock and ships right away? the oft that is
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 FRSTEVE Software Tuning 105 08-04-2017 04:48 AM
anyone trying to use the openflash tablet with forced induction? FRSTEVE Software Tuning 69 12-07-2014 04:07 PM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 10:03 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
