Old 10-27-2013, 06:50 PM   #1
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
intermittent parking brake light
So yesterday at the track, my car started giving me an intermittent parking brake warning light (red "BRAKE" light on the dash). Parking brake is definitely down, and now it comes on pretty much every time I press the brake pedal and it stays on until I accelerate. Any ideas?
trippinbillies40 is offline   Reply With Quote
Old 10-28-2013, 01:19 AM   #2
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Brake fluid level a tad low? When your pads wear, this can happen.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
The Following 4 Users Say Thank You to Bristecom For This Useful Post:
normancw (10-19-2014), Razzle (11-22-2014), shortcut (05-02-2016), trippinbillies40 (10-28-2013)
Old 10-28-2013, 01:50 AM   #3
Yep, sounds strange ...... but, it can be real.
Try topping off the fluid tank.
Good tip, Bristecom ....
Old 10-28-2013, 10:16 AM   #4
trippinbillies40
Drives: '22 WRB
Yeah, just busted out the manual this morning and saw it could be a brake fluid thing... I'll top it off tonight after work and see what we get. Thanks!
Old 10-28-2013, 01:33 PM   #5
Bristecom
Bristecom's Avatar
Just be very careful not to get air in there... Or else your pedal will be squishy. I found out the hard way and had to bleed it all out.
Toyota + Subaru =
Old 10-28-2013, 09:01 PM   #6
trippinbillies40
Drives: '22 WRB
Was indeed brake fluid. Was right at the min line. Probably had it close to min when I put high temp fluid in, and pad wear lowered it after a couple track days.
Thanks for the advice!
Old 03-14-2016, 01:13 PM   #7
speeddemon
Drives: Scion frs
hate to bring this back from 2013 lol but the e-brake light was going on, then off, then on, and now it stays on. I will take a look at brake fluid and top off if necessary. What is the best way to do this while preventing air to get in?
speeddemon is offline   Reply With Quote
Old 03-14-2016, 01:18 PM   #8
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
If it didn't get low enough to run dry, you should be able to put fluid in without issue, just open the cap and top it off.
Be sure to check for leaks, but it's probably just your pads getting thin.
Just know that when you do replace your pads, if you do it yourself, you'll have to remove some fluid from the master cylinder or it will overflow when you push the pistons back in.
murdoc is offline   Reply With Quote
The Following 2 Users Say Thank You to murdoc For This Useful Post:
roddy (03-14-2016), speeddemon (03-14-2016)
Old 03-15-2016, 03:59 PM   #9
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
This, you don't need to worry about air in the system unless the the master cylinder is empty completely. You only really need to bleed the system, when changing pads, rotors or the fluid entirely.
4th Brake Light/Rear Fog Light Kit FRS/BRZ/GT86 - $59.95! Vicious LED Groupbuys 58 01-05-2014 05:13 PM
For Sale: Smoked/Red/Clear Reverse Light + Brake Light Bars Brand New! Vicious LED Exterior Parts (Aero, Lighting, Etc.) 9 08-25-2013 07:26 PM
Parking brake clunk FRiSson Scion FR-S / Toyota 86 GT86 General Forum 4 06-28-2012 12:10 AM
Idling and parking brake markmatley Engine, Exhaust, Transmission 1 06-09-2012 07:20 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
