Old 10-24-2013, 07:30 PM   #43
PhastekSport
PhastekSport's Avatar
Send a message via AIM to PhastekSport Send a message via Yahoo to PhastekSport
The picture above, posted by Tim shows a setup that many will use. You can use the cans in various locations, but that one would be really common. It is under the tiny engine cover in the center.
You can cut it close to where it goes in, or give yourself a little space in case you want to easily reattach that cover.
That multi pack of adapters is available at Auto Zone like he mentioned. In the Vortech setup, everyone will have a check valve and you will not need additional adapters.
If we have a local customer with a simple NA setup that wants this, I'll try to get more media together. I apologize for the lack of it.
PhastekSport is offline   Reply With Quote
Old 10-24-2013, 11:37 PM   #44
fc3s_johnny
Brap Brap
fc3s_johnny's Avatar
Drives: 1986 FC3S RX-7, 2013 FR-S
So... when looking at the can (wherever mounted) from the front of the car, the LEFT most hose under the cover should be cut and routed into the RIGHT barb of the catch can. Correct?
Where does the other hose route to?
My car is NA, for reference.
fc3s_johnny is offline   Reply With Quote
Old 10-25-2013, 03:21 AM   #45
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
Originally Posted by fc3s_johnny View Post
Can someone please do a mini DIY of sorts and show me where exactly the supplied hoses connect to and where things need to be cut?
Also, is the adapter that's needed a 3/8 to 1/2 inch?
One hose goes from the PCV valve to the can and the other hose goes from the can to the cut factory hose that is connected to the intake manifold.
Sent from my iPhone using Tapatalk - now Free
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 10-25-2013, 11:16 AM   #46
PhastekSport
It is the hose on the left. You can connect it to either side of the catch can. The direction of flow through the can does not matter.
The right house routes to the brake booster.
Old 10-27-2013, 02:12 PM   #47
fc3s_johnny
Brap Brap
PCV Valve or brake booster???
Old 10-27-2013, 02:51 PM   #48
PhastekSport
Okay I misunderstood what you were asking. The other side goes back into the crank case. You're putting the catch can in line with the hose and not modifying where it ultimately ends up.
Sent from my SAMSUNG-SM-N900A using Tapatalk
The Following User Says Thank You to PhastekSport For This Useful Post:
normancw (11-29-2013)
Old 10-27-2013, 03:29 PM   #49
fc3s_johnny
Brap Brap
Alright i've finally got it. Thanks everyone for the help!
The Following User Says Thank You to fc3s_johnny For This Useful Post:
PhastekSport (10-27-2013)
FA20CLUB.com Billet Battery Tie Down Sale FA20Club.com Engine, Exhaust, Bolt-Ons 1 11-26-2012 10:14 PM
Billet Stubby Antenna for BRZ/FR-S Mach V Dan Exterior Parts - The Rest 6 11-14-2012 11:52 AM
T1R Billet Titanium Shift Knob FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 6 10-03-2012 09:07 PM
Forged pistons and billet rods paraguin Engine, Exhaust, Transmission 0 09-25-2012 10:55 PM
Billet Key Housing trackmagic Electronics | Audio | NAV | Infotainment 9 05-24-2012 12:18 PM
