Old 02-08-2012, 10:47 AM   #113
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
Originally Posted by bambbrose View Post
I'm actually quite impressed with the group of guys and our knowledge here at ft86. Great minds think alike?? :happy0180:
yeah, the fact that there are really smart gear heads in here gives this forum a big edge, interesting character, and more topics.
Even im pushed to learn more, and i haven't been this active on a forum since 02-04 when i had a s14 i was trying to build.
WingsofWar is offline   Reply With Quote
Old 02-08-2012, 11:55 AM   #114
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Originally Posted by val_lixembeau View Post
Exactly the opposite. HP is a measure of how "quickly" the torque can be applied.
Think of it this way, torque is a measure of force, but instead of measuring how hard you can push, it measures how hard you can twist.
In a straight line, you've heard that work=force*distance right? What power measures is how fast you can do that work.
Now let's translate that to circular motion...
Work is now torque applied over a certain number of revolutions. So power is torque times revolutions over time. That's why we sometimes say that power is just a number derived from torque.
Imagine two engines with the same peak power, but one with low torque and one with high torque. We'll use perfectly flat torque curves for simplicity. That would mean that the low torque engine needs to rev at higher rpm to produce the same power as the high torque engine.
In theory, these engines placed into the same car could produce identical acceleration if they were geared appropriately. The low torque engine would just need to rev higher. The problem is, people don't like to rev their engines, and manufacturers don't like to gear that way because of cost, mileage and reliability.
And that's why most people think of torque numbers as being responsible for the acceleration that you feel. Because low torque engines aren't geared low enough to produce the same acceleration as high torque engines, and even if they were they might not be able to rev high enough to take advantage of that gearing.
I feel very much like this. I always feel when I high rev a 4banger that the car is in so much pain that something will break and I would be SOL. I hope the FR-S doesn't feel this way but I wonder if flat 4 engines feel buttery smooth like a V8 or I6?
SUB-FT86 is offline   Reply With Quote
Old 02-08-2012, 01:45 PM   #115
Homemade WRX
Pro Subie Engine Nerd
Homemade WRX's Avatar
Drives: BRZ has a reserved space
Originally Posted by old greg View Post
That's about how old I thought he was, because of how much he thinks he knows.
Originally Posted by 7thgear View Post
and you're the smartest one here, right?
I think he simply meant that 'the more you know, the more you realize you don't know'...I'll be the first to admit this and I've been eating, breathing and sleeping engines for the last seven years...on the engineering level (two of which college/internships and the rest in the field).
Homemade WRX is offline   Reply With Quote
Old 02-08-2012, 02:32 PM   #116
86'd
86'd's Avatar
Drives: 2012 WRX Sedan
The curve looks similar to this
(I know there are some big differences between the engines though...)
Yet the TQ on the BRZ engine doesn't seem to drop off, which makes me think there's some room up top.
86'd is offline   Reply With Quote
Old 02-08-2012, 03:12 PM   #117
Dimman
Kuruma Otaku
Dimman's Avatar
Originally Posted by Levi View Post
Why join the right and left side of the headers together? Could not they be completely seperate?
So some of the exhaust energy can be transferred to other cylinders to assist in scavenging.
Because titanium.
Old 02-08-2012, 05:20 PM   #118
serialk11r
Drives: '06 AM V8V Coupe
:P I'll take that lightheartedly. I have reasonable proficiency with physics, but that's about it, and I think I make that pretty clear when I post about stuff? Everyone has lots to learn afterall, and discussing things is a good way to learn. I get bored a lot and rant on about stuff.
As a general disclaimer, everything I say is based on empirical evidence I have seen and extrapolated using basic mechanics/thermo, I have no actual experience with this stuff, but hopefully that'll change someday soon.
And SUB, 2010 would be the last time I was in a physics class, but not the last time I was in high school.
Old 02-08-2012, 05:24 PM   #119
Exage
GL 86!
Exage's Avatar
Drives: Maybe FR-S... maybe not
Chicken $*** hahaha.
What engines really really hate is lugging. This is where the engine is very low on RPM and fuel delivery is high under load. The engine is trying to increase engine rpm to an acceptable level so there is actually power and or avoid stalling.
You find that after ignition the forces on the piston are extremely high because it's [the piston] not moving at the speed the engine is designed to run at. The 2ZZ makes a particular knocking noise when it's lugged, some but not all engines do.
In addition it's harder on engine and drivetrain components on (lets say) a SUV with a trailer heading up a steeply (20%) graded hill highway on a high cruising gear. If the engine does manage (by some miracle) to keep a stable low rpm then you may face cooling issues with a long enough hill because the water-pump isn't going to be rotating at an acceptable rate to provide the quantity of coolant that will needed to be circulated (same with the automatic transmission fluid). So in this circumstance it's actually advisable to drop down a gear or two and make some noise because it will cause less wear on the drivetrain. Most people are too scared of destroying their engines to do this, instead the auto tranny will overheat and possibly pop... their loss.
In addition you have something designed like the 2ZZ that makes it's maximum 131 lb-ft torque at 6700rpm (127@4400 is stated), it's "not happy" below 4000rpm (especially at WOT) under load. It's funny because it's an NA engine which means it responds instantly but is lazy in the low rpm range.
Exage is offline   Reply With Quote
Old 02-08-2012, 05:29 PM   #120
serialk11r
I hear this "lugging" thing a lot, but I can't decide whether it actually makes sense or not. The friction in an engine doesn't start going up until well below idle speed, and at higher speeds the components are definitely under a lot of stress. Efficiency does go down near 1000-1500rpm typically but I think this is probably because the burning charge has too much time to cool down. The only thing I can see is that the rods are under max compression for a longer period of time but I don't think this is much of an issue especially for naturally aspirated engines.
old greg do you mind sharing your wisdom? :P
Old 02-08-2012, 05:48 PM   #121
Calum
That Guy
Drives: 2013 asphalt FRS MT
It has more to do with oil delivery to the journal bearings. As engine speed lowers it's harder for the hot oil to develop a hydrodynamic wedge. This leads to metal on metal contact which as Im sure you know is bad. There are some things that can be done to extend the low rpm performance of the bearing but all to my knowledge negatively effect the high rpm performance, in one case even causing the bearing to pump oil against the oil pump.
Old 02-08-2012, 06:12 PM   #122
Kostamojen
Originally Posted by WingsofWar View Post
oOo you and Dim might be right. Im looking at other dyno comparisons of the EJ251 with different headers. Never really paid attention to acoustics until now.
FYI, that dyno chart I posted is comparing stock headers to some JDM equal length headers that I installed between runs.
The headers/exhaust don't get rid of the dip.
Old 02-08-2012, 06:17 PM   #123
Exage
GL 86!
Exage's Avatar
That's a good point, usually oil pressures are decent at idle rotation. I'm a little skeptical on the metal on metal contact point. It could be possible with the exerted force, especially with the oil viscosity at temperature.
I've never seen a document on any engine lug tests. So this will interest me.
Old 02-08-2012, 06:18 PM   #124
ZDan
ZDan's Avatar
Drives: '23 BRZ
At low engine speeds, the hydrodynamic wedge that supports the conrod bearings isn't as strong. Consider the film strength of the oil in the bearing gap with no relative motion. Weak. Applying full torque is a bad idea at low engine rpm...
At high rpm when inertial loads dominate, the high speed gives a MUCH stronger hydrodynamic wedge to support the conrod.
Old 02-08-2012, 06:35 PM   #125
serialk11r
How relevant is this? If BMW feels safe giving their engines full boost at like 1200 rpm or something then it's probably safe to say these effects only exist around 1000 or below right?
I guess it makes sense that the oil would get squished out of the bearings more easily at low speeds, thanks for the info. Didn't think of that.
Old 02-08-2012, 06:38 PM   #126
Exage
GL 86!
Exage's Avatar
I understand what he is saying. However you used "isn't as strong". This begs the following question: At which RPM point is the hydrodynamic wedge not able to support the forces?
Obviously this depends on many factors of the engine during lugging (including the engine itself). RPM conversely affects both oil pressure and forces on the bearings and respective journals.
I would be interested to see at what rpm and parameters the hydrodynamic film breaks down, throw in some different oils, different temperatures...
2013 Porsche Boxer is revealed early DIG1992 Other Vehicles & General Automotive Discussions 62 09-05-2012 12:26 PM
Next Gen Boxer Engine 4U-GSE WingsofWar Engine, Exhaust, Transmission 33 12-10-2011 12:04 AM
Toyota Reconfirms Production 2012 FR-S / FT-86 Boxer Engine, 6MT, 6AT, LSD Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 30 05-02-2011 03:30 AM
Could this be the base FT-86 boxer engine? iff2mastamatt Engine, Exhaust, Transmission 2 02-10-2011 10:55 PM
More proof of FT-86 Boxer engine appears in logo Hachiroku Engine, Exhaust, Transmission 33 01-03-2011 01:47 AM
