Old 10-25-2013, 12:25 PM   #15
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
I don't understand what you mean by high/low beam. Arent all fog lights llow beam ?
ucsmfu is offline   Reply With Quote
Old 10-25-2013, 02:08 PM   #16
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Yes... but not all (practically none actually) have a high beam as well.
This is akin to a bixenon projector where a cut off shield moves to expose the "high beam"
Old 10-25-2013, 02:31 PM   #17
infinite012
Drives: 13 DGM BRZ Ltd
Looks possibly like a Morimoto Matchbox projector?
Edit: I may be in if you will convert it to a low beam projector with straight cutoff. And no, don't tell me you can just leave the high beam wires disconnected. That's lazy.
infinite012 is offline   Reply With Quote
Old 10-25-2013, 02:32 PM   #18
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
will the high/low fogs need extra wiring ? or do you think it'll be plug and play as well ?
It would be crazy bright, high beam HID headlights and high beam projector fogs, loll
I'm definitely in
Old 10-25-2013, 08:23 PM   #19
Andrew025
Andrew025's Avatar
You're asking them to create another product to do the same thing?
Old 10-25-2013, 10:12 PM   #20
PhastekSport
PhastekSport's Avatar
Send a message via AIM to PhastekSport Send a message via Yahoo to PhastekSport
Sounds like it, but there is already one available fortunately.
I'll make the thread tomorrow to put these on pre-order.
Sent from my SAMSUNG-SM-N900A using Tapatalk
PhastekSport is offline   Reply With Quote
Old 10-26-2013, 05:15 AM   #21
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Excellent...I know I'm in for a set with high beam function!
Also, for those with frs', can you get together a package to make it completely plug and play?(basically including the new housings to hold the fog lights since we got shafted from factory lol).
If not, where can we pick them up?
Old 10-26-2013, 05:20 AM   #22
continuecrushing
Just kidding, pretty sure I found it...phastek
Old 10-26-2013, 10:15 AM   #23
PhastekSport
Bezels, two sets of splitters, relay harness and possibly a switch.
We have those items available.
My question is will most people want to wire a switch into the cabin or just have them turn on with the headlights?
Old 10-26-2013, 10:22 AM   #24
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
I'll take one with 4300k pending price. Just the housings.
post_break is offline   Reply With Quote
Old 10-26-2013, 11:50 AM   #25
Andrew025
Andrew025's Avatar
I prefer a switch.
Old 10-26-2013, 01:07 PM   #26
ucsmfu
ucsmfu's Avatar
Drives: BRZ Limited
i prefer to have them turn on with the headlights. Will it be plug and play if we have stock BRZ fogs ? thanks
Old 10-26-2013, 03:55 PM   #27
continuecrushing
I'd prefer a switch as well
Old 10-26-2013, 06:05 PM   #28
PhastekSport
I can setup the relay to plug into the 5202 socket.
I'll have to research the high beams on the BRZ though.
fog lights, hid, projector
FS: FRS fog light housings and glass lense fog lights. Alliedforces86 Exterior Parts (Aero, Lighting, Etc.) 6 10-11-2013 10:18 AM
Anyone personally painted inside of tail light housings? BMHumanic Cosmetic Modification (Interior/Exterior/Lighting) 4 03-11-2013 12:44 AM
Rear fog light/ reflector bdanisi Cosmetic Modification (Interior/Exterior/Lighting) 3 12-16-2012 12:37 PM
Curiosity on White Headlight Housings Prava FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 12-02-2012 04:55 AM
Body-Color Headlamp Housings lopro25 Cosmetic Modification (Interior/Exterior/Lighting) 38 08-22-2012 12:05 PM
