Old 10-26-2013, 09:20 AM   #15
neurokinetik
neurokinetik's Avatar
Drives: 2013 Scion FR-S Firestorm
Did those bolts need to be changed because of clearance problems with the stock overpipe heat shield?
neurokinetik is offline   Reply With Quote
Old 10-26-2013, 09:40 AM   #16
FR-S Matt
Originally Posted by m.wood0213 View Post
Quick question, does this header get in the way of any components in the engine bay,and are you able to use the OEM splash guard with it? Otherwise Im very impressed.
JDL took the header back to the jig and adjusted it because the few initial ones rattled against the guard. It is no longer happening and the flex braid sections do not rattle or crack either.
The Following User Says Thank You to FR-S Matt For This Useful Post:
m.wood0213 (10-26-2013)
Old 10-26-2013, 09:49 AM   #17
ft_sjo
Drives: GT86
Bob
Please can you post a graph also comparing before/after to your best pump tune on a stock car?
Old 10-26-2013, 12:21 PM   #18
xxscaxx
Drives: 2013 SWP BRZ
Originally Posted by Drift-Office View Post
^^^ I just changed the bolts in this last picture and it was all gravy...
Bob @ Drift-Office, LLC
Did you swap out the bolt, or just put a washer on it? Mine were like that too...and I was a little concerned but didn't really feel anything when checking for leaks.
I need to replace my JDL UEL header anyways since i'm the one with the old flexes that make noise, and also running the one that hit the skid plate, so I can swap it out when I finally get the new header.
xxscaxx is offline   Reply With Quote
Old 10-26-2013, 01:42 PM   #19
chrisagu28
chrisagu28's Avatar
Drives: 2013 Subaru BRZ
Wink
Hey guys. I am the owner of the car and I am very happy with the results.
The car should have came with this kinda power stock plus I get that true Subaru sound like my old wrx had. It's fantastic.
chrisagu28 is offline   Reply With Quote
The Following 4 Users Say Thank You to chrisagu28 For This Useful Post:
DocWalt (09-19-2014), Drift-Office (10-26-2013), niceguy21 (02-10-2014), ThatAsianBradah (02-16-2018)
Old 10-26-2013, 03:20 PM   #20
fenton
I am not paid by JDL, nor am I affiliated with them in any way. I'll have my thoughts on this in a few days in the 3 Way Shootout.
Ref : http://www.ft86club.com/forums/showthread.php?t=37225
Nothing in the install process needed any modifications. Pretty perfect fit IMHO. I also checked the flanges against a straight edge and it was dope.
Attachment 55333
Attachment 55334
Attachment 55335
Bob toss one of these on with the Phantom ESC I would be really interested to see the results
Sent from my HTC One using Tapatalk
fenton is offline   Reply With Quote
The Following User Says Thank You to fenton For This Useful Post:
Old 10-26-2013, 03:25 PM   #21
Diode Dynamics
Diode Dynamics's Avatar
I'm looking forward to seeing some vids...are there any available yet?
That header looks amazing!
Nick C.
John C.
Diode Dynamics
Old 10-26-2013, 03:54 PM   #22
chrisagu28
chrisagu28's Avatar
Nick C.
Bob took some vids for whiled we dyno'd my car all for viewing purposes and i am pretty sure he will be putting them up soon.
The Following User Says Thank You to chrisagu28 For This Useful Post:
Diode Dynamics (10-27-2013)
Old 10-26-2013, 04:37 PM   #23
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
Coming soon Nick!
See OP :
Installation was pretty straight forward - other than making sure you're on a lift to do it properly, there weren't any issues... until we started up. The supplied bolts weren't cutting it and a small exhaust leak resulted where the header flange met with the stock overpipe. No biggie. Went to the bolt bin, sourced out another 2 smaller ones and the issue was rectified in minutes.
Here you go!
^^^ 4th Gear Pull : Alleviates (not eliminate) the torque dip from 3200RPM but gives you the top end to red line! Almost 190WHP and 150#s TQ! To date, this has been the highest performing UEL that we've tested (between Borla / RevWorks) and all this on a STOCK exhaust system too!
Cheers!
Drift-Office is offline   Reply With Quote
Old 10-26-2013, 04:58 PM   #24
peebking
Drives: BRZ limited
Great header, but way too far from my budget, I hope to get one
peebking is offline   Reply With Quote
Old 10-26-2013, 05:49 PM   #25
stockysnail
Just the tip
stockysnail's Avatar
I'm glad the dyno did so well because I also purchased one. I love the sound and as soon as I have time to get it tuned I'll post my numbers in my build thread.
The Following User Says Thank You to stockysnail For This Useful Post:
Old 10-27-2013, 03:02 AM   #26
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
@stockysnail - Take that thing up to Bod @Drift-Office. The conversation will be worth the gas and only cost $100 more for a guy who has tuned more 86's than anyone. He will do it on ECUTEK but at least you can buy a cable and log on a laptop. BRZ Edit will leave you at the mercy of PRE. Just sayin...
digital_assassin is offline   Reply With Quote
The Following 2 Users Say Thank You to digital_assassin For This Useful Post:
Drift-Office (10-27-2013), Touge_ninja (10-27-2013)
Old 10-27-2013, 06:04 AM   #27
ft_sjo
Drives: GT86
@Drift-Office
I think you may have misunderstood, I already saw that graph in your first post. Can you please confirm if the baseline/before run was 100% stock or running your tune?
If completely stock, did you try one of your tunes on it before fitting & tuning the new exhaust manifold?
Thanks.
Old 10-27-2013, 02:18 PM   #28
Drift-Office
@Drift-Office
Thanks.
The header was installed right after we got done with the baseline and was 100% stock. Outside the header, the final run had the AVO Panel Filter in it.
In regards to putting one of my NA tunes on it, I already know the results of that. I'll be doing a UEL that way soon - baseline stock, then stage 1 tune and then header install and tune.
Regards,
The Following 2 Users Say Thank You to Drift-Office For This Useful Post:
ft_sjo (10-27-2013), StormTrooper (10-27-2013)
Drift-Office : HKS EL Header Tuned! Drift-Office Engine, Exhaust, Transmission 84 05-05-2014 12:34 AM
Drift-Office : Rev Works UEL Header... Tuned! Drift-Office Engine, Exhaust, Transmission 21 11-05-2013 08:45 AM
Drift-Office : Borla UEL Header... TUNED. Drift-Office Engine, Exhaust, Transmission 41 10-26-2013 11:54 AM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 09:51 AM
Got my stock BRZ tuned at Drift Office over the weekend... edocura Engine, Exhaust, Transmission 46 05-23-2013 08:05 AM
