Old 10-25-2013, 11:27 AM   #43
Bach415
Bach415's Avatar
Drives: Whiteout FRS
@shiv@vishnu My cousin who got the tablet from you @ the NorCal meet is getting the CEL P0700 after installing catless headers and flashing 1.3. Any ideas? It's an AT FRS.
Bach415 is offline   Reply With Quote
Old 10-25-2013, 02:20 PM   #44
jeebus
That's a transmission code...I can't imagine it's related to the tune at all.
jeebus is offline   Reply With Quote
Old 10-25-2013, 02:26 PM   #45
cnk
Drives: '13 DGM BRZ Limited
Just to add, here's the DTC explanation of that code:
(DTC) CODE # P0700....Transmission Control System (MIL Request) Translation: Transmission Control Module (TCM) Malfunction or Failure. P0700 Information Code The Transaxle Control Module (TCM) monitors the malfunction of sensors and actuators relating to transaxle control. If any malfunction is detected, the TCM informs the PCM by sending a signal (P0700 code). P0700 means that a code has been set in the TCM. This code is for information ONLY. If this code is present, check for transaxle codes. So basically, the P0700 code is telling you to check the TCM for a transaxle DTC. The TCM can not turn on the check engine light so it has the PCM do it.
Old 10-25-2013, 03:27 PM   #46
Bach415
Bach415's Avatar
I know it's the transmission code but the weird thing is that it wasn't there until after the flash.
Old 10-25-2013, 03:49 PM   #47
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Have you tried reflashing back to stock, then the tune again ?
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 10-25-2013, 04:03 PM   #48
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Sounds like a connector on the transmission was unplugged when the header was installed.
Shiv@Openflash is offline   Reply With Quote
Old 10-25-2013, 07:35 PM   #49
RSH
Drives: 2014 BRZ Limited
Picking up BRZ tomorrow. OFT in hand. Catless EL header ordered, no ETA.
Upon install of the latter my question is whether an O2 spacer is necessary with this tune to avoid the CEL or whether it must/can be turned off safely with Tuner Pro?
RSH is offline   Reply With Quote
Old 10-25-2013, 07:39 PM   #50
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Welcome fellow South Carolinian. You should not need the spacer. I plan to get rid of mine once my OFT arrives.
Old 10-25-2013, 08:11 PM   #51
RSH
Thank you. reading these threads reminds me once again why I am thankful I do not live in California. Octane and emissions just a small part of that equation.
Does that mean that this build has already turned off the 2nd sensor?
Old 10-25-2013, 08:47 PM   #52
Bach415
Bach415's Avatar
He was on 1.2 prior to this. Will have him downgrade to 1.2 then to stock before back to 1.3 to see if CEL still exist.
We will check on that tmr but we didn't take any connectors off except for the o2 sensors. I'll have him flash back down to 1.2 to see if the CEL pops up again then back to 1.3 if it doesn't. But if it does pop back up, do you know where exactly the connectors would be located? All we did was loosen the bolts on the front pipe/overpipe to get the headers off. I doubt we hit anything to break off or loosen when uninstalling/installing the headers.
It turns off the error code for the o2 sensor.
Old 10-25-2013, 08:57 PM   #53
SloS14
SloS14's Avatar
Not sure it turns the sensor off (i.e. heater), but keeps the CEL from coming on in relation to at least catalyst check (possibly heater malfunctions too).
Old 10-25-2013, 10:45 PM   #54
Shit Luck
Drives: red frs
stage 2 test drive tomorrow.
also on a side note the tuner pro update solved my no start issues when adjusting the launch control.
Shit Luck is offline   Reply With Quote
The Following User Says Thank You to Shit Luck For This Useful Post:
Shiv@Openflash (10-25-2013)
Old 10-26-2013, 11:51 AM   #55
jeebus
Hmm, maybe it's just me but 1.3 feels more sluggish than 1.2. I did some comparisons and ignition advance looks to have been adjusted significantly in the low rpm range. I know you did this in the interest of knock prevention, but what does it look like on a dyno?
For comparison, here is stock vs 1.2 vs 1.3
Old 10-26-2013, 01:38 PM   #56
Shiv@Openflash
Drives: 2013 FRS
From the testing we have done, dyno looks the same. But with the earlier map, the brief MAF voltage spikes would make ecu follow the high load cells that had big ignition correction values. This caused the knock activity in the 2500-3200rpm area. The new map just accounts for the MAF spike and limits total timing under load.
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 FRSTEVE Software Tuning 105 08-04-2017 04:48 AM
anyone trying to use the openflash tablet with forced induction? FRSTEVE Software Tuning 69 12-07-2014 04:07 PM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 10:03 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
