Old 10-25-2013, 12:00 PM   #2423
jpit
Drives: Subaru BRZ
The relay is much easier to install next to the control box in the engine compartment. That's why we are looking there for a power source.
jpit is offline   Reply With Quote
Old 10-25-2013, 12:03 PM   #2424
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by HunterGreene View Post
I know the cig lighter is switched
I like this idea as well. Plus the relay would be in a dry spot.
Installed Mods:
Old 10-25-2013, 12:06 PM   #2425
rusty959
Drives: DGM BRZ limited
Aren't those wires just the ones that go from the control box to the voltage display?
rusty959 is offline   Reply With Quote
Old 10-25-2013, 12:08 PM   #2426
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Gary,
I show circuit 28 to be an EFI fuse. Is this the one you are referring to?
Yes, that's the one. Damm acronyms.
The advantage of using the switched lighter is that you wont need to pass the relay through the firewall opening. I'm thinking that I like that location too. But from a manufacturing standpoint, close to the connector is easier.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 10-25-2013, 12:12 PM   #2427
jpit
Drives: Subaru BRZ
But I'm showing voltage there with the ignition off.
Old 10-25-2013, 12:15 PM   #2428
Robftss
Drives: VW
- 12V+ switched on headlight socket when car running and DRL? Some cars run lower voltage ~4v during DRL.
- you could run a single 20-24Awg ~ 6'-7' from the relay following my harness back to the glove box switched socket(hard wired), ground in engine bay.
Both these sources are fused lines/ and the relay is low current signal.
Robftss is offline   Reply With Quote
Old 10-25-2013, 12:17 PM   #2429
Sojhinn
Sojhinn's Avatar
Yeah I think this is easiest. and we can run the wire through the loom.
Installed Mods:
Old 10-25-2013, 12:20 PM   #2430
Gary in NJ
Gary in NJ's Avatar
Gary,
When I test #28 I get 12V readings from both sides with the ignition off.
Can't be. How can you have both sides of a fuse circuit hot? I just double checked it, it's switched.
Old 10-25-2013, 12:38 PM   #2431
CajunFRS
Drives: Challenger R/T, CRX SI,
What's the weight of this kit I've looked and haven't seen anything yet.
CajunFRS is offline   Reply With Quote
Old 10-25-2013, 12:51 PM   #2432
mid_life_crisis
Drives: FR-S 10 #103 AT
Considering that it adds half a turbocharger, a small electric motor and a couple of not too large batteries, the relevant answer to that question is: a hell of a lot less than any other supercharging system.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 10-25-2013, 12:56 PM   #2433
jpit
Drives: Subaru BRZ
The added weight is from the batteries. I went with a bigger starter battery so I guess the added weight is about 20 lbs. The actual compressor weighs very little.
Old 10-25-2013, 12:59 PM   #2434
s2d4
s2d4's Avatar
Originally Posted by rusty959 View Post
Is the cigarette lighter outlet in the glove box switched? I'm guessing it is, and the glove box/behind the glove box would be a fine place to stash a relay.
Yeap, 99.99% this would work.
But I wouldn't have the relay so far away from the control box.
A small gauge wire to feed the switching through the sound tube hole = money.
Old 10-25-2013, 12:59 PM   #2435
jpit
Drives: Subaru BRZ
I don't know why circuit #28 can have both sides with a 12v reading but that is what I am getting. Sojhinn got the same reading but his post is gone. Don't know why.
Old 10-25-2013, 01:02 PM   #2436
Robftss
Drives: VW
Compressor ~4 lbs
Control/charger module ~ 2lbs
All cables/harness ~ 1lb
Battery swap (stock 29.6 lbs) (using 21Ahr or PC-680 as starter and 24V dump pack 37.8 lbs) + 8.2 lbs
removing snorkel & resonator ~ - 0.5lbs?
= 15 lbs.
Rob.
The Following 3 Users Say Thank You to Robftss For This Useful Post:
CajunFRS (10-25-2013), DAEMANO (10-25-2013), fenton (10-25-2013)
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
