Old 10-25-2013, 10:27 AM   #1
swift996
swift996's Avatar
Brake Bleeder Hose?
I was wondering if someone had any ideas of where I could get a couple different diameter size hoses to bleed my brakes this weekend? I have OEM rears and Wiwoods in the front and they are both different diameter bleed screws. I figured maybe home depot but I don't even know what the tubing would be called.
I'm doing the two-man drill with it, so just need a tube to see the bubbles.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 10-25-2013, 11:26 AM   #2
M1K3
M1K3's Avatar
Drives: vrooom...
Home Depot, Sears or Lowes has an assortment of clear hose tubing in different sizes, in prepackaged rolls or sold by the ft (just cut to the length you need). Also if the hose is not perfectly snug on the bleeder, what I like to do is use a small zip tie as a clamp to make sure it stays on the bleeder.
M1K3 is offline   Reply With Quote
The Following 2 Users Say Thank You to M1K3 For This Useful Post:
dowroa (11-20-2017), swift996 (10-25-2013)
Old 10-25-2013, 11:27 AM   #3
celica73
Home depot/Lowes. It's in the plumbing section.
The Following User Says Thank You to celica73 For This Useful Post:
Old 11-19-2017, 06:01 AM   #4
radroach
Drives: car
Anybody know the size diameter hose to bleed OEM brakes on BRZ Toyota 86 FR-S? I'm ordering off amazon.
Old 11-20-2017, 11:44 AM   #5
wparsons
wparsons's Avatar
If you order silicone hose, the diameter doesn't need to be that exact since it'll stretch over the nipple.
flickr
Bleeder valves CB762 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 06-15-2022 11:38 PM
Motive Power Bleeder THEmailman Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 24 09-25-2017 11:13 PM
FS: Motive 1107 Brake Bleeder Adapter xman11 Brakes, Suspension, Chassis 5 09-19-2013 09:15 PM
Motive Brake Bleeder Adapter xman11 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 02-23-2013 10:24 AM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
