Old 10-24-2013, 09:27 AM   #2395
rusty959
Drives: DGM BRZ limited
Originally Posted by Gary in NJ View Post
You will need a 100A continuous duty 24V Contactor (relay) like this model from White-Rogers, model 124-114111
White Rodgers 124-114111 Solenoid, SPNO, 24 VDC Isolated Coil, Continuous Duty, Normally Open Continuous Contact Rating 100 Amps, Inrush 400 Amps - Amazon.com
You would put this on the positive from the 24V battery pack to the controller. This is an active low device so you would need to find a circuit that goes low (-) when the ignition is active.
With this in place you can leave the ESC in ARM without fear of discharging the battery.
I don't see why you are wanting to add resistance on a high current line when you already have a method to control it that requires only a tiny slide switch.
At the worst and no one can figure out how to trick it from the wires going to the volt meter, just open the thing up and wire a small relay across the switch contacts. Atleast then you won't possibly be affecting system performance.
Also, depending on how constant these things can pull 3.5 and 4.5kw, that relay wouldn't be strong enough anyways.
rusty959 is offline   Reply With Quote
Old 10-24-2013, 09:48 AM   #2396
mtimney
mtimney's Avatar
Drives: 2013 BRZ Limited
Fenton or Rob...
Is there a way you might get an ESC to Unichip so they can make a map for the system? This would help me out...as well as open up a new potential market for both Rob and Unichip.
mtimney is offline   Reply With Quote
Old 10-24-2013, 10:09 AM   #2397
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
A few times I have forgotten to disarm (switch to off) the ESC. Luckily both of these times I was only out of the car for less then an hour, but there is potential to have the batteries drain overnight or longer. A solenoid would make battery management idiot-proof.
Rob will have to comment on the suitability of a 100A continuous duty contactor. 3500watts @ 24VDC equates to 145A. However I don't know if that is inrush power or duty cycle. The contactor I linked has a 400A inrush capability.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 10-24-2013, 10:21 AM   #2398
fenton
Originally Posted by mtimney View Post
Fenton or Rob...
I believe he has talked to unichip but right now it isn't the best option due to some of its limitations. Can it datalog?
Currently you have the option of ecutek or brz edit which is a great start. These are the two most powerful software options that allow full data logging to make sure everything is running right.
Now there is always options for people to go to different platforms.... I think someone is working with open flash tablet right now to get a base map.
As time goes on there will be more and more options but you want to make sure the choice you make is going to be a safe one. If it isn't designed for FI with data logging you would be taking a risk.
Rob hasn't sent any kits to any vendors.... He wants the everyday people to get a chance to test it, beat on it and make mistakes that all humans do.
Sent from my HTC One using Tapatalk
fenton is offline   Reply With Quote
Old 10-24-2013, 10:42 AM   #2399
Robftss
Drives: VW
Name:  DPDT switch.JPG
All who are running the system:
The green an yellow wire need to be open for 100% shut down.
A DPDT relay, 12V/2-5 Amp, can be soldered in as shown.
The relay coil can be activated by a switched 12V (Best to find a switched 12v+ in the fuse box next to the controller.)
@Pug did something similar, but integrated it into his LCD screen.
@GaryNJ, no need for the heavy contactor
Rob
Robftss is offline   Reply With Quote
The Following 2 Users Say Thank You to Robftss For This Useful Post:
DAEMANO (10-24-2013), s2d4 (10-24-2013)
Old 10-24-2013, 10:56 AM   #2400
Thatruth2001
Drives: Raven FR-S
Gotta love Rob's proactive nature to improve the product.
Thatruth2001 is offline   Reply With Quote
The Following User Says Thank You to Thatruth2001 For This Useful Post:
Old 10-24-2013, 11:11 AM   #2401
jpit
Drives: Subaru BRZ
Rob,
Do you have a part number for the relay? Is that something that is readily available?
jpit is offline   Reply With Quote
Old 10-24-2013, 12:26 PM   #2402
Robftss
Drives: VW
Originally Posted by jpit View Post
Rob,
http://www.radioshack.com/product/in...ductId=2062483
Or....you could go old school...mounted on the dash
http://www.radioshack.com/product/in...ductId=2062538
Old 10-24-2013, 12:29 PM   #2403
Gary in NJ
Gary in NJ's Avatar
As always, very good info.
So we need jump a fuse in the fuse box for something that is always on when the ignition is on...say the instrument cluster or the HVAC fan. Using a multimeter I can determine which side of the fuse socket is the protected side.
Yeah, if you have a part number of a suggested DPDT I'll solder this in to the wire harness.
The Following User Says Thank You to Gary in NJ For This Useful Post:
Robftss (10-24-2013)
Old 10-24-2013, 07:46 PM   #2404
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Quick response: System is now working. Feels great. More later.
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
Old 10-24-2013, 09:50 PM   #2405
Sojhinn
Sojhinn's Avatar
Just as a quick reference to Rob and anyone else. An easy way to tell if one of your batteries is bad is when the batteries charge quickly. I.e they hit full charge within a couple of seconds after a long wot.
Also I'm hitting the cel like crazy. Any luck with toma rob?
Installed Mods:
Thatruth2001 (10-24-2013)
Old 10-24-2013, 10:00 PM   #2406
Thatruth2001
Drives: Raven FR-S
Only a matter of time..... Have fun and don't burn through a tank of gas too fast. You will now have a new appreciation of the FA20.
Old 10-25-2013, 01:33 AM   #2407
jpit
Drives: Subaru BRZ
Installed the relay but haven't been able to find a switched 12v supply in the engine fuse
block. Most of the fuses have power all the time or not at all. Anybody else try it?
Old 10-25-2013, 01:34 AM   #2408
Sojhinn
Sojhinn's Avatar
Any chance you have An aftermarket radio?
Installed Mods:
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
