Old 10-24-2013, 01:40 PM   #15
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by cjsporl View Post
Question: how do I activate launch control?
It is active be default. It is just set to rev limit (7600) minus 2500, or 5100rpm. So if you rev it with the clutch down and with the car stationary, the revs will hold there. You can change the value from the current default of 2500 to whatever works best for you. But IMHO, launch control is somewhat of a gimmick in a car that makes less than 175lbft
Shiv@Openflash is offline   Reply With Quote
The Following 3 Users Say Thank You to Shiv@Openflash For This Useful Post:
cjsporl (10-24-2013), flippy (08-13-2014), JPxM0Dz (10-24-2013)
Old 10-24-2013, 01:41 PM   #16
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by CamryDS View Post
Any plans on making a stg 2 for catted aftermarket headers?
The Stage 1 maps will be fine for such a setup.
Old 10-24-2013, 02:01 PM   #17
Shiv@Openflash
Drives: 2013 FRS
Does Open Flash support any other features like RaceRom and if so how do I activate them. Also you did not reply to my previous post. Oh, and I like the stage 2 flash a lot but the dip is still their from my experience.
The only other feature the OFT supports is flat foot shift. You can activate it by replacing the default value of 0 (in Flat Foot Shift parameter) with a larger value like 2500rpm. This value dictates how much revs are allowed to drop when the clutch goes in while the throttle is wide open.
As for your previous post, I made no mention of a Stage 3 map. Not to say that it won't come but it's not under development at this time. E85 map will come next.
As for the dip, no amount of tuning will get rid of it completely. Certain headers may help move it around a bit but it will always be there to some degree. The only thing that will eliminate it completely is boost (turbo/sc).
Shiv
Old 10-24-2013, 02:09 PM   #18
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Hey Shiv, is there any difference in fuel trims between the stock map and the stage 1 map?
Installed Mods:
Old 10-24-2013, 02:10 PM   #19
Shiv@Openflash
Drives: 2013 FRS
Hard to say, I didn't test the stock map for very long
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
brn12345 (10-24-2013)
Old 10-24-2013, 02:12 PM   #20
Sojhinn
Sojhinn's Avatar
Only reason I ask is the Electric Super Charger is safe to run on the stock map, because it will run rich at high rpms. I'm not sure if it would be safe to run your map with it.
Oh well. Thanks for the quick response!
Installed Mods:
Old 10-24-2013, 05:42 PM   #21
Wepeel
Drives: '13 BRZ Ltd
Thanks for showing the dynos down to 2000 rpm.
If I'm reading this right - the difference between the Stage 1 (completely stock hardware) and Stage 2 tune (catless header only) is about 3-4 ft-lbs from 4500 and up?
Wepeel is offline   Reply With Quote
Old 10-24-2013, 06:26 PM   #22
RC51ed
RC51ed's Avatar
Drives: 2013 Scion FRS
Idk if the butt dyno is off, but I defiantly felt a difference. It usually takes me 2-3 start/drive cycles to get the full potential of the tune. I am defiantly enjoying this update version.👍
RC51ed is offline   Reply With Quote
Old 10-24-2013, 06:32 PM   #23
overlookedx
overlookedx's Avatar
Drives: 2015 WRB Limited
Do you have aftermarket headers Ed? Or are you talking about Stage 1?
Superfast Jellyfish
overlookedx is offline   Reply With Quote
Old 10-24-2013, 06:34 PM   #24
RC51ed
RC51ed's Avatar
I'm stock besides a cat back that was on the car when I bought it. Stock air filter also.
The Following User Says Thank You to RC51ed For This Useful Post:
overlookedx (10-24-2013)
Old 10-24-2013, 06:37 PM   #25
Shiv@Openflash
Drives: 2013 FRS
I recommend sticking with Stage 1 if you are running stock headers. Especially on the 91oct we get here in CA. Stage 2 will likely be too aggressive.
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
CamryDS (10-24-2013), RC51ed (10-24-2013)
Old 10-24-2013, 06:48 PM   #26
RC51ed
RC51ed's Avatar
Defiantly, just updating from1.2-1.3 and pleased with the results.
Shiv@Openflash (10-24-2013)
Old 10-24-2013, 06:50 PM   #27
VR46
are you Jeff Vader?
VR46's Avatar
Drives: Black BRZ Limited
Just flashed 1.31 stage 1 for ZA1JA01D - no issues on my end. Stage 2 couldn't come at a better time, I have my header and overpipe in hand and the catted downpipe should be arriving on saturday.
Thanks Shiv!
VR46 is offline   Reply With Quote
The Following User Says Thank You to VR46 For This Useful Post:
Old 10-24-2013, 08:10 PM   #28
Norkoastal
Never on Time Always Late
Norkoastal's Avatar
Drives: #silenced crickets
@shiv@vishnu Shiv, when you get a chance can you show us an example of the snorkel mod you are recommending? Thx!
CO>CA Cartel
Norkoastal is offline   Reply With Quote
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 FRSTEVE Software Tuning 105 08-04-2017 04:48 AM
anyone trying to use the openflash tablet with forced induction? FRSTEVE Software Tuning 69 12-07-2014 04:07 PM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 10:03 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
