Old 10-22-2013, 10:51 PM   #1
Garstang
Garstang's Avatar
Drives: FRS
Windows freezing in the winter.
Has anyone had the problem of the windows not going back up. After opening and closing the door in the winter ??
Garstang is offline   Reply With Quote
Old 10-23-2013, 08:41 AM   #2
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Try Aerospace 303 protectant on the rubber door seals. The windows do freeze if water gets between the glass and the seals.
Suberman is offline   Reply With Quote
Old 10-23-2013, 08:43 AM   #3
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
We stand on guard for thee...
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
The Following User Says Thank You to Anthony For This Useful Post:
DarthNads (10-23-2013)
Old 10-23-2013, 08:53 AM   #4
ML
ML's Avatar
Drives: 13 White MT FR-S
What did the blue screen say? Probably a driver issue.
The Following 2 Users Say Thank You to ML For This Useful Post:
Anthony (10-23-2013), Migero86 (10-23-2013)
Old 10-23-2013, 09:06 AM   #5
tiz22
tiz22's Avatar
Drives: 2013 Scion FR-S (Raven) MT
I've ready a lot of people have had this problem during the winter (especially us canadians)
Apparently you can disable that feature...I saw a pretty easy DIY where you just put tape around the door sensor that tells the car when the door is open (also disables the door chime)
My Car Journal: Raven FR-S w/ TRD Flavour
Click for my AVIC Z150BH Head Unit DIY Install
tiz22 is offline   Reply With Quote
Old 10-23-2013, 09:12 AM   #6
thill
Have you actually used this and it works? I am tempted to try this.
Old 10-23-2013, 09:14 AM   #7
muffinz
Drives: 2013 DGM BRZ Ltd
YES. I had this problem specifically after it snowed or I washed the car in the winter weather.
muffinz is offline   Reply With Quote
Old 10-23-2013, 09:41 AM   #8
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
Yea, happened a few times. This winter, i'm going to try putting Aerospace and maybe disabling it.
Also, for those who don't know: If your windows aren't going up and down and your window buttons are flashing, hold them all the way up past the click (or down, I forget) for a few seconds until they stop flashing to reset them. IIRC You will need to go to the passenger side to reset that side.
Books is offline   Reply With Quote
The Following 2 Users Say Thank You to Books For This Useful Post:
frs_abq (10-23-2013), Garstang (10-23-2013)
Old 10-23-2013, 07:01 PM   #9
DJCarbine
Thupercharged
DJCarbine's Avatar
I would check that the window will clear the body/trim when you disable to coupe auto-down feature.
I had an E36 with the same problem, and if you tried to fool the sensor the glass would just slam into the body/trim.
Going to try the product mentioned in the thread...
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 10-23-2013, 07:07 PM   #10
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Subie guys have been treating their frameless window seals (and everything else plastic) with aero 303 for years. It might take a few applications if your are already saturated but it will eventually stop the problem. good luck
chulooz is offline   Reply With Quote
The Following User Says Thank You to chulooz For This Useful Post:
Garstang (10-29-2013)
Windows freezing in the winter. Garstang CANADA 26 11-15-2013 10:14 AM
summer or all-season tires? freezing temps? rainmonkey Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 04-07-2013 01:11 PM
Alright to tint windows in winter (cold)? Chinadian CANADA 19 03-21-2013 02:31 PM
Windows freezing? L3P47 Scion FR-S / Toyota 86 GT86 General Forum 11 12-22-2012 12:49 PM
Windows 8 Khalis Off-Topic Lounge [WARNING: NO POLITICS] 33 10-17-2012 10:20 PM
