Old 10-23-2013, 06:18 PM   #2381
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Originally Posted by Sojhinn View Post
The snorkel is the tube right behind the bumper it feeds "cold air" into the intake.
Got ya. While we're (or I'm) on the subject of the airbox, I was thinking "what is the purpose of plugging the hole that is exposed by removing the resonator?" The hole is before the filter so any air that it does suck in will be filtered before it enters the intake. It seems to me that it is a way of allowing additional air into the system.
Any of the other beta's run without the plug in the airbox?
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 10-23-2013, 06:23 PM   #2382
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Interesting idea. I think that resonator is actually a potential air box. (Is there such a thing) Where the intake will suck in extra air when needed. Since the intake hole is fairly small. Maybe opening that up would allow more air flow. No worse then what I'm doing right now with no snorkel.
Installed Mods:
Old 10-23-2013, 06:23 PM   #2383
fenton
I'm at my car right now. Let's get this code triggered. Tell me what to do.
Just turn it to on... Not running.... Then arm the system.... Then go wot for 3 to 4 seconds. After that once again u Starr the car you will probably have the cel.
Also do you hear it running when wot. It should be quite loud.
Sent from my HTC One using Tapatalk
fenton is offline   Reply With Quote
Old 10-23-2013, 06:27 PM   #2384
fenton
I don't see why you want to trip the cel though lol. How does it feel when driving it?
Old 10-23-2013, 06:31 PM   #2385
Sojhinn
Sojhinn's Avatar
While driving or when the engine is off? While driving I don't hear it. When the engine is off I hear it easily.
Installed Mods:
Old 10-23-2013, 06:32 PM   #2386
fenton
While driving or when the engine is off? While driving I don't hear it. When the engine off I hear it easily.
Well that's good... I thought for a minute it wasn't working at all for you.
The tq250 you don't really hear.... The tq300 however makes quite a bit of noise.
Old 10-23-2013, 06:45 PM   #2387
Sojhinn
Sojhinn's Avatar
No cel.
Installed Mods:
Old 10-23-2013, 06:58 PM   #2388
jpit
Drives: Subaru BRZ
I've been trying to figure out how to wire the arming switch to turn off and on with the ignition. Not having much luck. Five wires go to the arming switch and it appears the red wire carries the voltage info (18v-28V) and the yellow wire reads 12V when the switch is off and very little when it is on. I think Rob is working on doing this. I thought it might be easy but not sure now how to do it.
jpit is offline   Reply With Quote
Old 10-23-2013, 07:01 PM   #2389
fenton
No cel.
Maybe you aren't getting full boost. I think that happened to @Bu-Tang when a cable came loose on the controller to motor. If everything is tight get ahold of Rob to troubleshoot. It should be quite loud when its off.
Does it feel faster ?
Old 10-23-2013, 10:24 PM   #2390
Gary in NJ
Gary in NJ's Avatar
You will need a 100A continuous duty 24V Contactor (relay) like this model from White-Rogers, model 124-114111
[ame="http://www.amazon.com/124-114111-Solenoid-Isolated-Continuous-Normally/dp/B003JJ8FCY"]White Rodgers 124-114111 Solenoid, SPNO, 24 VDC Isolated Coil, Continuous Duty, Normally Open Continuous Contact Rating 100 Amps, Inrush 400 Amps - Amazon.com[/ame]
You would put this on the positive from the 24V battery pack to the controller. This is an active low device so you would need to find a circuit that goes low (-) when the ignition is active.
With this in place you can leave the ESC in ARM without fear of discharging the battery.
Old 10-23-2013, 10:27 PM   #2391
Gary in NJ
Gary in NJ's Avatar
Even with the car in motion (even with my aftermarket exhaust) I can clearly hear the ESC spooling up. If you don't hear it, and you don't see a drain on the voltmeter, you may have an issue.
Old 10-23-2013, 10:31 PM   #2392
Sojhinn
Sojhinn's Avatar
Yea rob and I worked it out. Bad battery. Seems like I'm destined to run into issues right now. Obviously I did something to earn some bad karma. And now you guys probably think I'm an idiot in installing things or that my students may have f'd things up. But it was just a bad battery delivered. Yay....
Installed Mods:
Old 10-23-2013, 10:35 PM   #2393
silent runner
Drives: 93'Camry, 82'Corolla, 76' Celica
Technically it does work at 80% physical throttle, which is 100% throttle to the ECU (Depending on where you install the pedal switch).
Boost under part throttle runs into a whole bunch of new tuning scenario's.
For what its worth the DR does boost(1psi) when you want a little more. It gives a nice bump in torque as it pulses even when at partial throttle.
I've given some thought to the idea of multiple stage/level activation as well, but it really does introduce alot of new tuning scenarios. (and cost/complexity) Think about added a separate TPS, or tapping the stock TPS, and adding a module to the controller to translate it. Thats just the beginning! It's not easy or simple to make a controller thats slinging around this much DC current in multiple, smooth stages. It would add so much cost to the system, that it would lose its charm as an economical way to beef-up the FRS's performance and that would be a real shame.
silent runner is offline   Reply With Quote
Old 10-24-2013, 06:22 AM   #2394
bfrank1972
Drives: 2013 FR-S Argento
Man don't take it so hard! You'll be up and running in no time.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
