Old 10-21-2013, 08:02 PM   #407
no chrome
She said member
Drives: fr-s firestorm
Originally Posted by shiv@vishnu View Post
If the OFT is stuck in a endless calibration request loop, it's because you are probably using your fingers which, if they are like mine, are too dull for calibration purposes. To sort things out, just plug the OFT into your car (unplug from laptop first) and use a stylus to calibrate. That should sort it out. If you don't have a stylus, you can use a ballpoint pen but press very gently to avoid scratching the screen.
Update: this worked perfectly. And then I finally updated the program, flashed ecu.
No more issues.
The tune is great, most noticeable to me was the mid range rpm improvement
Can't wait for stage 2 and bolt my borla uel header on
I guess you also recommend popping off the stock front snorkel at the same time?
Does the computer I use to write files to the tablet need to be online while I am writing to the tablet?
no chrome is offline   Reply With Quote
The Following User Says Thank You to no chrome For This Useful Post:
Shiv@Openflash (10-21-2013)
Old 10-21-2013, 09:55 PM   #408
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
And with the snorkel/duct removed, it performs just as well as any aftermarket intakes.
Which snorkel/duct are you referring to? This?
http://imageshack.us/scaled/large/34/sv0y.jpg
And what is the reason/benefit for removing the snorkel/duct?
Fizz is offline   Reply With Quote
Old 10-21-2013, 10:01 PM   #409
sierra
Drives: Skoda Yeti DSG diesel 4x4
That's a resonator. The snorkel feeds the airfilter box from the front.
sierra is offline   Reply With Quote
Old 10-22-2013, 12:20 AM   #410
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Originally Posted by ztan View Post
Hi Shiv,
Have you had a chance to look at any ZA1J___G ROMs yet?
Any major differences with XDF defs, etc?
Zeke
Have you emailed it to me yet (shiv@vishnutuning.com)? Id love to look at it tomorrow when I get to the office
Shiv do you think there are 'country-specific' ROM versions for these cars? If there is such a thing, then would there be any risks for Aus market cars running your tunes?
Old 10-22-2013, 12:37 AM   #411
cnk
Drives: '13 DGM BRZ Limited
If that's a concern, I believe Shiv has offered to look over the ROM file if you just use the OFT to read your ECU and email it to him.
Old 10-22-2013, 12:42 AM   #412
Hanni_0176
Hanni_0176's Avatar
Drives: 2013 Scion FR-S 10 Series MT
There are too many intakes on the market (and some not very good) for us to support with customized mapping. So going forward, our maps will be intended for stock airboxes. And with the snorkel/duct removed, it performs just as well as any aftermarket intakes. But without the MAF signal misreadings. So unless you need underbood bling, it really makes most sense to stick with the stock airbox (with a decent panel filter). I ended up removing the airraid intake on my car and went back to the stock box
Does that include tunes with the stock box and a drop in air filter like a K&N? Just curious, cause that's all I have done to my car right now, and will likely be purchasing an OFT next month.
Hanni_0176 is offline   Reply With Quote
Old 10-22-2013, 01:07 AM   #413
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
Just picked this up over the weekend at 86 Fiesta, running only the K&N drop-in filter with Works AB-R exhaust. You can definitely feel a difference, car feels so much more alive now.
Thanks @shiv@vishnu for getting my car setup!
*edit* I think I'll be removing the snorkel/duct you mentioned. Does it make a difference?
.ck
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
Old 10-22-2013, 01:11 AM   #414
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Yes I appreciate that he's offering to look over the ROM file, but that means purchasing the OFT first in order to read the stock ROM. Hence my question about the possibility of country-specific versions and whether he thinks there's going to be any risks/issues or not....as I'd like to be sure before I commit to any purchase
Old 10-22-2013, 01:16 AM   #415
cnk
I understand your situation. . pretty much a catch 22. Unless someone else in Australia has already purchased the OFT and pulled ROM files to send over, your only options would require you to be the first to do that or to just use the OFT to read your ROM and then get it locally tuned.
Old 10-22-2013, 01:25 AM   #416
akyp
Drives: 2012 86
I have ordered OFT and will post my experience as soon as I finally get it. It is still stuck in a post office somewhere in HK.
akyp is offline   Reply With Quote
Old 10-22-2013, 01:28 AM   #417
sierra
Here's my email to them and their reply.
Just to clarify.
It's the map I'm wondering about. Our 86's and BRZ's have probably
got the same ECU settings as yours in the US but if there is a difference
then that might cause problems if say it's related to RHD instead of LHD
or differences in the car's hardware?
I'm assuming the map that is flashed to the car is a complete US modified
version?
No ecu and rom file are exactly the same between FRS/BRZ in the US. The same ROM file will also work with jdm ft86, its the same ROM. Looks the same. RHD and LHD works the same. No difference there. US and JDM version doesn't matter they work the same. I have sold a OFT to Japan and its works.
The Following User Says Thank You to sierra For This Useful Post:
Fizz (10-22-2013)
Old 10-22-2013, 01:31 AM   #418
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Indeed it is. Yes getting the OFT and then having it tuned locally would be an option, but so far I've contacted 3 local tuners....the first 2 would only sell and tune using ecutek. The 3rd place I called offered to dyno tune using brzedit (for only about $100 more than the OFT in fact) but although he's tuned countless other wrx's before, he's only tuned maybe a couple of 86's so far. Doesn't really inspire confidence in me....or maybe it shouldn't really matter...
Edit: Just saw your post Sierra....thanks for that.
Old 10-22-2013, 01:36 AM   #419
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Hurry up already
Old 10-22-2013, 01:10 PM   #420
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
For those asking about snorkel removal...
2URGSE
JPxM0Dz is offline   Reply With Quote
The Following User Says Thank You to JPxM0Dz For This Useful Post:
ck-GT86 (10-22-2013)
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
