Old 10-20-2013, 07:59 PM   #2325
Bu-Tang
Drives: 2013 Scion FR-S, Nissan Pathfinder
Originally Posted by NYCsubaruBRZ View Post
is the kit available soon?
Not yet sir. The release still is TBD. Still lots of testing to be done.
Sent from my SGH-I337M using Tapatalk
Bu-Tang is offline   Reply With Quote
Old 10-20-2013, 08:10 PM   #2326
fenton
Originally Posted by Bu-Tang View Post
Not yet sir. Not release still is TBD. Still lots of testing to be done.
I think it is getting close though. I know Rob currently has 8 FRS/brz in the testing phase. This is going to be a lot of data and should help him get to market sooner
Sent from my HTC One using Tapatalk
fenton is offline   Reply With Quote
Old 10-20-2013, 09:08 PM   #2327
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Originally Posted by fenton View Post
Ya my ESC was hitting 160 gs down low. I'll take some datalogs again to confirm with the new charger.
Hitting that high of g/s down low really makes the tuning problematic.
I don't think it's actually hitting those values, but the MAF is interpreting the turbulent airflow as those values.
BTW, you said about 20 pages back that there is calculation of boost and g/s to determine horsepower. What is that formula?
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 10-20-2013, 11:47 PM   #2328
fenton
I think @Robftss knows it.... I don't remember it anymore. Ya we thought it was weird too but the readings were very consistent which doesn't usually happen when the readings are false. Anyways.... Definitely more testing and analysis required especially on the tq300... 250 doesn't seem to have that problem unless under 2000 rpm.
Old 10-21-2013, 12:18 PM   #2329
mid_life_crisis
Drives: FR-S 10 #103 AT
All this talk about turbulence, has anyone tried a straightener? One of those things that looks like a honeycomb or a bunch of straws or are those considered to be snake oil?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 10-21-2013, 12:23 PM   #2330
fenton
The stock airbox does have the straighteners.... Not the honey comb type however. Not sure where that would even go in our setup.
We don't know yet if that is the issue however it does seem suspect.
Rob said that he is going to attempt a blow through maf design which should help everything should he be able to implement it properly.
Oh BTW... The tq300 system really whines when you get on it down low. Its a very unique sound, I like it.
Old 10-21-2013, 12:37 PM   #2331
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Curious if whoever has the Perrin intake has this same issue.
Installed Mods:
Old 10-21-2013, 12:48 PM   #2332
mid_life_crisis
Doh! I forgot where the sensor is located. You could only do it with an aftermarket intake.
That would be cool, but as I questioned earlier, should this system use a different maf and recalibrate for it to make sure all that air is properly accounted for?
Old 10-21-2013, 01:22 PM   #2333
fenton
This system does not need the maf to be rescaled because it uses the stock airbox and the MAF is in its stock location.
If we move the maf then yes, we would have to rescale.
Old 10-21-2013, 01:27 PM   #2334
fenton
ThaTruth has the perrin. To be honest i didnt have a problem with the 3.5kw unit so i wouldnt expect anyone to have problems with the current system.
The one that i am testing uses a different impeller design with more blades for higher top end flow.
Old 10-21-2013, 03:02 PM   #2335
fenton
In the name of science here are the results of the 4.5kw unit.
Old 10-21-2013, 09:26 PM   #2336
Sojhinn
Sojhinn's Avatar
Just received the FTS. Looks freaking incredible. Very tempted to install this tonight but I promised my students they would help tomorrow. I was wondering if you guys wanted me to create a step by step instruction with pictures maybe video etc. I have access to student a who can write things down and take a ton of photos. Should be easy to make this an assignment.
Installed Mods:
Old 10-21-2013, 10:27 PM   #2337
Sojhinn
Sojhinn's Avatar
Also @fenton maybe you could help. I sent a message to Toma about the tune. I was hoping he could output the file as an Open Flash Tablet compatible file type. The new BRzedit software version supports outputting to the OFT file type. Im hoping to get it by tomorrow.
Installed Mods:
Old 10-21-2013, 10:29 PM   #2338
fenton
Email Rob. He has direct contact with him... He doesn't come on here that much as of late.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
