Old 10-19-2013, 12:57 PM   #2311
jpit
Drives: Subaru BRZ
Took my BRZ to Drift Office yesterday and had a tune done with the electric supercharger. This is the TQ 25024V compressor and not the one that Fenton is currently testing. Working with Bob and Bill is very easy and they answer any questions you may have - which in my case were many. It was also 86 night and Bob bought 240 chicken wings to share with everyone. Back to the tune. They didn’t want to run a baseline as I have just added a Borla header with the supercharger and they didn’t want to run a risk of running too lean. However, the first run was done without the arming switch on and resulted in a hp measurement of app. 150. Low figure was due to drag from the blades in the supercharger. Bob did say that a normal BRZ (FT-S) without mods will average about 162 without a tune. The next five runs were very similar all showing 196 hp and torque between 176-180. Boost was a maximum of 5.1 trailing off as the rpms climbed. Bob thinks that this is because battery power starts dropping off almost immediately and gets down to 19v by the end of the run. I thought it was because at the higher rpms the boost just can keep up with the increased air flow. Perhaps Fenton and Rob can comment on this. I can say that when the boost kicks in it does push you back in the seat and makes the car much more enjoyable to drive. Graph is below with one of the typical runs and one done in second gear just to determine that it was shifting at 8000 rpms (second gear only).
jpit is offline   Reply With Quote
The Following 6 Users Say Thank You to jpit For This Useful Post:
Bu-Tang (10-20-2013), DAEMANO (10-20-2013), fenton (10-19-2013), Robftss (10-21-2013), SloS14 (10-19-2013), Thatruth2001 (10-19-2013)
Old 10-19-2013, 01:12 PM   #2312
Thatruth2001
Drives: Raven FR-S
Get ready for some overtime Rob.... I think your going to receive a few new orders......
Thatruth2001 is offline   Reply With Quote
Old 10-19-2013, 01:12 PM   #2313
fenton
Originally Posted by jpit View Post
Took my BRZ to Drift Office yesterday and had a tune done with the electric supercharger. This is the TQ 25024V compressor and not the one that Fenton is currently testing. Working with Bob and Bill is very easy and they answer any questions you may have - which in my case were many. It was also 86 night and Bob bought 240 chicken wings to share with everyone. Back to the tune. They didn’t want to run a baseline as I have just added a Borla header with the supercharger and they didn’t want to run a risk of running too lean. However, the first run was done without the arming switch on and resulted in a hp measurement of app. 150. Low figure was due to drag from the blades in the supercharger. Bob did say that a normal BRZ (FT-S) without mods will average about 162 without a tune. The next five runs were very similar all showing 196 hp and torque between 176-180. Boost was a maximum of 5.1 trailing off as the rpms climbed. Bob thinks that this is because battery power starts dropping off almost immediately and gets down to 22v by the end of the run. I thought it was because at the higher rpms the boost just can keep up with the increased air flow. Perhaps Fenton and Rob can comment on this. I can say that when the boost kicks in it does push you back in the seat and makes the car much more enjoyable to drive. Graph is below with one of the typical runs and one done in second gear just to determine that it was shifting at 8000 rpms (second gear only).
Attachment 54687
Great results jpit. The reason the boost trails off is due to the static rpm of the compressor. This means more boost down low and as the engine gains efficiency and requires more air flow you get less boost.
It is not a function of battery power. I'd you are going up a hill down low in the rpm in a tall gear you will see that you get 5psi all the time even if the battery power reads 22v.
Boost is rpm dependent. 2000 rpm equals 5psi, 7000 is usually 2 psi no matter what. Another way to prove that is to let the battery charge all the way up and hit the gas at 6000 rpm.... You won't get 5psi because the engine needs more airflow at that rpm and boost can't build.
What engine is that for a base line because I have never seen a fa20 with less than 125 tq for the whole run and have never seen a na brz make peak power above 7500 rpm. That looks like a Honda high reving engine or something like that.
Sent from my HTC One using Tapatalk
fenton is offline   Reply With Quote
Old 10-19-2013, 01:58 PM   #2314
fenton
What mods do you have @jpit? What did your boost curve look like?
Old 10-19-2013, 04:32 PM   #2315
jpit
Drives: Subaru BRZ
Mods are the Borla UEL and a Perrin over pipe. Bob thinks that EL headers may be better for this set-up. Didn't look at the boost graph maybe they still have it. That isn't a baseline but my car dynoed in second gear. They were making sure that second gear was reving up to 8000. Fenton do you know at what voltage the compressor will start to fade?
Old 10-19-2013, 05:33 PM   #2316
fenton
I think the shutoff is at 16v. Trust me you will never get there. I have done 1 min plus pulls...... Do you know how fast you can get going in 1 minute?? About 250km/h lol.
As soon as you hit wot the voltage will drop to 22, that's completely normal.... It will put out full boost until it hits 16ish v on the read out.
Something that caters the top end will be best with this setup. People have had good luck with the rev works up top so I think that is what I will try.
The Following User Says Thank You to fenton For This Useful Post:
Old 10-19-2013, 06:00 PM   #2317
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Should be interesting to compare jpit and myself. Since we should have the same kits. Just some mod differences.
Installed Mods:
Old 10-19-2013, 07:06 PM   #2318
jpit
Drives: Subaru BRZ
Actually the Borla did very well up top.
Old 10-19-2013, 07:34 PM   #2319
fenton
Oh that's good. I was just referring to a innovate dyno I saw. He swapped out the borla for revworks and got another 10 HP on the top end before tuning.
Old 10-20-2013, 06:22 PM   #2320
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
@fenton
In the name of science I went out this morning a beat the crap out of the ESC, getting data from the ECU for MAP. Getting consistent reading below, or even at 3000 proved to be problematic. I really wanted to get a consistent reading @ that point, so I was engaging the ESC @2500, allowing for a 500 rpm ramp-up. For the most part I'd get readings in the 80 g/s range, with a few hits right on 82 g/s. Engaging the ESC at 2000 produced wild results; any thing from 60 to 140 g/s at 2500 rpm, but then stabilizing around 80 g/s as I passed through 3000 rpm. These are my results through the rpm band:
3000 rpm ~ 78 to 82 g/s
4000 rpm ~ 90 to 94 g/s
5000 rpm ~ 108 to 111 g/s
7000 rpm ~ 151 to 155 g/s
Is this data useful?
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 10-20-2013, 07:00 PM   #2321
fenton
Originally Posted by Gary in NJ View Post
@fenton
Ya my ESC was hitting 160 gs down low. I'll take some datalogs again to confirm with the new charger.
Hitting that high of g/s down low really makes the tuning problematic.
Old 10-20-2013, 07:18 PM   #2322
Sojhinn
Sojhinn's Avatar
@fenton
In the name of science. I thank you!
Installed Mods:
Old 10-20-2013, 07:28 PM   #2323
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
is the kit available soon?
NYCsubaruBRZ is offline   Reply With Quote
Old 10-20-2013, 07:52 PM   #2324
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
The Following User Says Thank You to SloS14 For This Useful Post:
zc06_kisstherain (10-21-2013)
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
