Old 10-19-2013, 09:38 AM   #1
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
low end torque question
I'm sure im not the only 1 here asking this question. But what's the best route for low end torque. Torque LOW in the power band like a diesel. FI graphs look like poop torque wise below like 5000rpm for torque yet I hear that's the way to go for more usable torque. Uh, confused. Fuck whp, up top I think stock actually feels pretty good. Below 4500 not so much (duh). Is there a way to add LOW end torque and get the best of both worlds (NA or FI)? Just trying to get unconfused and start a performance path after I get my SP Elite next month. Dyno plots please!!
Old 10-19-2013, 09:54 AM   #2
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Stroker kit or very quick spooling turbo. Nothing else is going to make a night/day difference at least nowhere near diesel/more displacement territory.
Old 10-19-2013, 09:54 AM   #3
roddy
roddy's Avatar
Drives: '13 Ultramarine
A twin screw/roots blower. Turbos can be set up to favor the low end as well. Displacement, but that one won't be easy.
Old 10-19-2013, 09:55 AM   #4
BlueDubbinTDI
Ok realized this may have been a dumb thread. Look what I found:
Electric Supercharger dyno
Does any other route look similar torquey down low?
The Following User Says Thank You to BlueDubbinTDI For This Useful Post:
DAEMANO (10-20-2013)
Old 10-19-2013, 10:00 AM   #5
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Originally Posted by BlueDubbinTDI View Post
Ok realized this may have been a dumb thread. [/IMG]
Diesel swap
The Following 2 Users Say Thank You to Andrew025 For This Useful Post:
arghx7 (10-19-2013), IAmNotTheDriftKing (10-20-2013)
Old 10-19-2013, 10:39 AM   #6
SloS14
SloS14's Avatar
If you are talking about WOT power, yes - that'll do. But rarely are you just going to stab it off idle.
Old 10-19-2013, 10:47 AM   #7
mrk1
Drives: Sterling BRZ Ltd
A turbo could be set up to help out. Most turbo kits outs there are geared more towards high end power. There is no reason why you couldn't choose a smaller turbo to work when you want it to.
Im a fan of the VW 2.0 turbo engines, they have great low end power for a 4 banger. On the street who cares if it falls off up top, how often are you actually up there.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 10-19-2013, 11:01 AM   #8
BlueDubbinTDI
I'm getting the 2015 GTI (addition not replacement) but yeah exactly my point. This is not a complaint thread because I love what the car has already. Just want to see what can be added down the road. Are there any small turbo kits out there focused on low end power for these cars? I want an entire powerband of beastmode..not just the last 30%
Old 10-19-2013, 11:12 AM   #9
vgi
Drives: frs
Base Innovate kit seems to be what you want for DD for $
vgi is offline   Reply With Quote
Old 10-19-2013, 11:40 AM   #10
BlueDubbinTDI
I think you're right. Hoping for a little more up front torque but the dyno plots look so smooth its rediculous.
Old 10-19-2013, 10:33 PM   #11
jflogerzi
jflogerzi's Avatar
If your gonna go S/C, A header+Tune is a good place to start IMO. Also consider replacing the overpipe while your in there
Old 10-20-2013, 03:53 AM   #12
mfbmike
Drives: 2013 FRS, 2008 R32
Former VW owner here too.
I owned a mk5 r32 with a vr6. Low end torque for days. We got my mom-in-law a newer TDI recently and the low end torque delivery was similar (although it absolutely dies up top).
I've seen header + tune combos that get rid of the torque dip early in the rpm range on these cars.
Even with the lack of low end torque in this car (in comparison to what I previously drove), it's still a blast.
mfbmike is offline   Reply With Quote
Old 10-20-2013, 10:28 AM   #13
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
what about a tune? Have you seen the dyno Shiv posted for the "nip the dip" thread? it appears that changing the VVT really helped pick up some low end tq. Also, after reviewing a lot of dyno's with after market headers that low end tq dip has been drastically reduced. I would go with headers in a tune 1st.. then, if you really need to go boost you already have a solid setup.
Its not going to compete with something as radical as a turbo/supercharger but its a lot cheaper of an alternative and much more safer for your car.
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 10-20-2013, 10:50 AM   #14
RedLeader
RedLeader's Avatar
Drives: 2013 Firestorm FR-S
This is the difference between my stock dyno and after the innovate kit. There's not a ton of difference below 3k, but that's where the curve changes noticeably. It's torquey enough that I have trouble keeping traction on dry pavement if I'm not careful.
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 04:53 PM
The Torque Dip. Ozzman Engine, Exhaust, Transmission 25 09-06-2013 02:32 PM
500 hp & 550 lb/ft torque ? yes please LS13 Scion FR-S / Toyota 86 GT86 General Forum 3 06-17-2013 12:48 PM
torque mrnibbs Scion FR-S / Toyota 86 GT86 General Forum 21 05-13-2013 09:37 PM
What torque dip? pdreams Engine, Exhaust, Transmission 44 11-12-2012 06:56 PM
