Old 09-26-2013, 01:29 PM   #85
mtscaletta
mtscaletta's Avatar
Drives: Ultramarine MT Fr-s
Great write up, I used this last night. I did notice, however, that you have the tail light and brake light power wires reversed in the write up. I only wanted to hook up as a fog light and not as a brake light, I was a little weary about cutting through the reflector, and attached my power to the green cable as stated. This added brake light functionality instead of fog light. I don't know if the BRZ is different from the FR-S, I would assume not but you never know. It was a simple fix but I just wanted to put that out there in case anyone wanted to only do fog lights. Zilla, thanks for the great step by step though!
mtscaletta is offline   Reply With Quote
Old 09-26-2013, 08:07 PM   #86
DrDuquette
DrDuquette's Avatar
Drives: 2013 Premium White, 2006 TL
The 8th picture where things are soldered. Look in the background. You'll see more wires with white tape. Disconnect them from the light and you will get more room. Take the tape off of them and you will find a place where you don't have to splice the wires. A place where 3 wires where joined together. One set of these wires is positive and one negative. You could attach both there or one to the positive and one to the ground, I soldered both of mine. Use your multi meter to figure out which one is positive. A hell of a lot easier. Then re-tape when you are done. No splicing or stripping=no fuss.
DrDuquette is offline   Reply With Quote
Old 10-19-2013, 01:09 AM   #87
Chinadian
Chinadian's Avatar
Drives: FRS Whiteout
Originally Posted by Gunman View Post
Well, there is on the BRZ, that's where I grounded mine.
Not my pic, but this shows it.
Just to confirm, the yellow "light bulb" the (positive) is going to the Green or Red wire on the bottom of the picture (2) and the other wire from the bulb (negative) is to be attached to the area on the top (1)?
Also how do we do the attachment to the "ground"?
Thanks
Chinadian is offline   Reply With Quote
Old 10-19-2013, 01:13 AM   #88
mtscaletta
mtscaletta's Avatar
For the ground you need to crimp/solder an eyelet onto the wire you are using for a ground remove the bolt and add the eyelet to that group of existing ones. As for the positive, are you doing a fog light or a brake light? Or both?
Sent from my SCH-I545 using Tapatalk
Old 10-19-2013, 01:20 AM   #89
mtscaletta
mtscaletta's Avatar
I'm gonna make this easy. This is the picture from page 1 of this write up. The red is tail light green is brake light(at least they were on my car). You want to tap in at this socket, the one going to the back of the light itself. Easiest way to do it.
Old 01-17-2014, 07:55 AM   #90
Hachiroku14
Drives: 2014 BRZ World Rally Blue
is that yellow wire from the harness too? coz in the JDM ones, the yellow wire is (+) for the rear fog light switch. hmmm....
Hachiroku14 is offline   Reply With Quote
Old 05-12-2014, 02:10 PM   #91
Thongpocket
Master Troll
Thongpocket's Avatar
Drives: 2013 BRZ Limited
Would you need a dual intensity LED and a relay to make this flash with your brakes like some of the kits i've seen? I wanted to order the below bulb and do this but I would like it to flash with my brakes.
https://www.superbrightleds.com/more...ower/633/1908/
Thongpocket is offline   Reply With Quote
Old 05-13-2014, 12:09 PM   #92
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
That or just run 2 bulbs. One to the brakes and a ground, the other to driving lights and a ground. That's what I did.
FRSfan111 is offline   Reply With Quote
Old 07-10-2014, 01:22 AM   #93
Trphotomediadotcom
Thanks for the DIY! Name:  uploadfromtaptalk1404966151556.jpg
Size:  20.4 KB did mine today.
Trphotomediadotcom is offline   Reply With Quote
Old 07-10-2014, 01:44 PM   #94
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
how would we make this flash like the mugen SI's?
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 07-12-2014, 12:21 AM   #95
Blizzard86
I must do this. I was just thinking today about how to do this. My hub is a electrician so I hope I can get him to do this.
Blizzard86 is offline   Reply With Quote
Old 07-12-2014, 12:31 AM   #96
Candlejack
Ignorance Intolerant
Candlejack's Avatar
Drives: '13 WRB BRZ Limited
Brake Light Strobe Module
And to switch the bulbs over to LEDs. Filament bulb wouldn't dim fast enough to flash well.
I'm probably going to end up doing this mod. But I'm going to use a dual-wired LED (two brightness settings, can also be found at the link I shared).
Candlejack is offline   Reply With Quote
Old 07-12-2014, 02:09 PM   #97
nickmerronesucks
Ned flanders
AWESOME!!!! im stoked now. haha
797Performance.com
Old 07-21-2014, 12:17 PM   #98
Trphotomediadotcom
Heres another pic
custom, fog, fog light, foglight, rear fog light
How-To: Remove Rear Deck & Third Brake Light Moshpit37 DIY (Do-It-Yourself) Guides 63 08-01-2020 10:48 PM
Third brake light...(top mount) Slide Cosmetic Modification (Interior/Exterior/Lighting) 103 02-22-2017 03:47 PM
Third brake light out? Longhorn248 BRZ First-Gen (2012+) — General Topics 21 11-23-2015 04:23 PM
The third brake light looks like a car! Longhorn248 BRZ First-Gen (2012+) — General Topics 12 06-06-2012 08:14 PM
FR-S Rear brake light... MF_DEUCE FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 05-05-2011 04:53 PM
