Old 10-18-2013, 05:57 PM   #15
y2janz2
Drives: Whiteout
should have waited...
for us that bought the tuner kit early, $3195 + $1195 = $4390 =(
Anyway, are those curves with the CARB tune?
y2janz2 is offline   Reply With Quote
Old 10-18-2013, 06:04 PM   #16
cantholdanymore
cantholdanymore's Avatar
Drives: FR-S Very Hot Lava
What's the weight of the itercooler system?
cantholdanymore is offline   Reply With Quote
Old 10-18-2013, 06:30 PM   #17
1010110
Drives: 2013 Scion FR-S Manual in Whiteout
Do you have to pull the whole intake manifold and blower or can you just pull the blower to install the intercooler?
1010110 is offline   Reply With Quote
Old 10-18-2013, 07:02 PM   #18
xjohnx
Grip>Slip
xjohnx's Avatar
Pretty sure they said somewhere that it's just the blower that has to come off.
Old 10-18-2013, 07:36 PM   #19
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
The box with all the intercooler contents for shipment is at most 20lbs, which means it will be less than that.
CounterSpace Garage is offline   Reply With Quote
Old 10-18-2013, 07:50 PM   #20
Frostyman
Drives: 2013 Raven FRS
Install instructions require you to remove the entire thing, but a motivated individual could likely do it without removing.
Originally Posted by Don@Accelerated
For the sake of argument I went and cut my factory filter housing up.
Frostyman is offline   Reply With Quote
Old 10-18-2013, 08:29 PM   #21
mtimney
mtimney's Avatar
Drives: 2013 BRZ Limited
How similar or different is this IC compared to the one being offered by FA20Club?
mtimney is offline   Reply With Quote
Old 10-18-2013, 08:36 PM   #22
rusty959
Drives: DGM BRZ limited
Not necessarily, it doesn't ship with the fluid.
rusty959 is offline   Reply With Quote
Old 10-18-2013, 08:41 PM   #23
xjohnx
Grip>Slip
xjohnx's Avatar
I was wondering the same thing. after looking at the photos, it appears the same intercooler core is used (at least, they have the same numbering cast into the top of them.)
Old 10-18-2013, 09:00 PM   #24
CSG David
CSG David's Avatar
Based on a loose calculation of oil density, each liter of oil weighs roughly 2lbs.
Old 10-18-2013, 09:55 PM   #25
1010110
FA20Club's site says:
Upgraded reservoir tank with ice capacity
40% more coolingcapacity than standard Innovate Intercooler kit
Larger front mounted heat exchanger.
Old 10-18-2013, 11:28 PM   #26
Kostamojen
Get this CARB approved ASAP!!!
Old 10-19-2013, 01:38 AM   #27
Unicorn
Drives: GT86
Originally Posted by Calum View Post
Seconded.
Also, I'd like to see IAT's read after the intercooler, while at wide open throttle, and the system fully heat soaked.
Dear Calum,
There's some 'strange shit' going on with all the intercooler jive. Sprintex released their charge cooler kit with a Bosch 2.5 bar MAP sensor. This MAP sensor also had an integrated air temperature sensor. This sensor has the same linearisation curve as the temp sensor in the OE MAF sensor (Unicorn Tested (tm)). For some reason Sprintex didn't want to, or be smart enough, to do a one-wire change to enable usage of this on-a-plate feature. Unicorn spec does.
Rumour on the rainbow has it that Sprintex have stopped supplying the 2.5 bar MAP sensor and are recommending use of the OE sensor. This may or may not be due to strategy issues in the ECU.
Who knows what Innovate are doing.
Yours knowingly,
Unicorn
Unicorn is offline   Reply With Quote
Old 10-19-2013, 11:15 AM   #28
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
so i still have to get my fueling and tune correct? this is only SC and IC?
lbroskee is offline   Reply With Quote
Innovate Motorsports Twin Screw Supercharger System, NOW SHIPPING! Innovate Motorsports Forced Induction 577 10-15-2014 12:49 AM
Innovate Motorsports BRZ/FR-S/GT86 Supercharger System Available from Moto-East! Xero-Limit Forced Induction 12 03-10-2014 08:56 PM
Innovate Motorsports FR-S/BRZ traction control state modifier module... mines13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 09-13-2013 01:06 PM
Innovate Motorsports Twin Screw Supercharger Kit for FR-S/BRZ Innovate Motorsports Forced Induction 1987 03-13-2013 09:14 PM
FS: Innovate Motorsports OT-2 pixel67 Engine, Exhaust, Bolt-Ons 0 01-05-2013 10:13 AM
