#2241 | |
I am so pumped for tomorrow because I know there is more HP up top.... Just can't wait to see what it does when it isn't running so rich. Sent from my HTC One using Tapatalk 4 |
#2242 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#2243 |
Drives: Subaru BRZ
Just installed the Phantom on my BRZ. Some initial thoughts: extremely high quality and very east to install. Getting the harness through the firewall was probably the hardest part and that didn't take very long. Only went into boost once and it certainly wakes the car up. Torque app registered a 4.1 psi boost and immediately threw an intake manifest pressure code. Heading down to Drift Office on Friday to get it tuned. Really didn't notice any difference in normal operation with the drag reduction operating. I opted for the Odyssey PC925 battery and it fits fine with a new battery tray. I am going to try to find a way to have the arming switch turn on with the ignition switch. I know that I will be forgetting to turn it off quite often.
#2244 | |
Drives: GTS 86
#2245 |
Drives: Raven FR-S
still slowly waiting for this to come out...... been keeping an eye on this thread for a while now. loving this new generation of technology.
#2246 | |||
Drives: WR Blue BRZ, 240Z
I haven't left my system armed by accident...yet. I think it's just a matter of time. I'm thinking of using a 24V contactor between the battery pack and the controller.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
#2247 | |
See graph below(dotted line): top AFR is Stock, bottom AFR is phantom ESC with stock tune. Keep in mind this is a tailpipe reading and is actually leaner than what is in the combustion chamber. In the end though you are right, at 4000 rpm there is still about 4 pounds of boost running on a NA tune.
#2248 |
Drives: Raven FR-S
jpit stick around tomorrow after your tuning session with Bob. If all goes as planned, I should be up there for 86 nights tomorrow.
#2249 |
Drives: Ultramarine 86 - 6MT
So basically, when it is turned ON it acts as a NOS-like Electric Supercharger and when it is turned OFF it acts as a cold air intake inlet tube? From there you can toggle whether it is in full use or not?
#2250 | |
Drives: Raven FR-S
Ready through the posts. Yes on question 1 and no on question 2. Additionally the unit is on or off there is no in-between mode at the moment. |
#2251 |
I tried reading through as much as I could, but when there is over 100 pages its kind of hard to narrow it down. So when it is turned off and not in use how is the throttle bottle inhaling air from the stock CAI?
#2252 |
Full throttle Electric Supercharger Build Thread
The newer models offer a more aggressive drag reduction but the system needs to be armed in order for it to work. And from my understanding it works great. I'll tell you next week how it feels. As for when the system is off? It will lower power to your car. But it still gets air. ( there's a dyno about 8 pages back.)
| The Following User Says Thank You to Sojhinn For This Useful Post: | forzajuve (10-17-2013) |
#2253 |
Right I understand that power wont be gained when it is off, but it basically replaces the inlet tube. So when it is off is it still inhaling air into the throttle body but doesn't provide boost/power?
#2254 |
Yup. But it loses power. But if the system is armed there is no power loss. And it will only create boost when you are at 70% wot.
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
