Old 10-16-2013, 11:01 PM   #1
autoCAR
Drives: 5/2013 scion frs
DIY Gold Foil heat wrap intake box
C3PO Intake setup complete, (cusco inlet)
Hey club ft 86,
I thought, hmm what can i do to lower intake temps without buying a whole intake box? Gold Foil heat barrier came to mind, i saw people covering ej20/25 intake manifolds with it, so why not the stock intake box? Im waiting on an intake tube too, thatll get wrapped too.
I bought 3 feet (3'x24") from Pegasus Racing, cost $105.xx shipped.
https://www.pegasusautoracing.com/pr...p?Product=1838
took me about 3 hours to do both peices of the intake box, i took my time.
Tips:
* cover up ur intake tube with tape, so no buggers get in while ur wrapping
* clean the intake box with alcohol
* strands of fiber glass may get inside the intake box while wrapping, wipe it down when done and if you have an air hose, blow it off.
* cut the material with a SHARP razor blade down to the end not tacked, dont cut from the untacked end to the adheared section.
* when you get to angles, cut a pie cut, and cover it over & overlap. It all blends in pretty nice once ur done.
* YOU DONT NEED A SQUEEGIE! this stuff lays down really nicely, and u can peel it off n retack with no problem. no waste with this expensive stuff
* around the edge of the box, use the side thats factory cut, or a side with as little fiber glass strands, so those dont go into the box when ur changing air filters.
* there are 2 TINY holes in the air box add on thing, DONT COVER THESE OR THE FOIL MAY GET SUCKED IN (there is 2, about 1/8th in diameter)
all you need is, screw driver, 10mm socket, alcohol, rags, razor blades, & time. oh and $105 for the material
Ill post pics of the intake tube covered. Ill let uk how the car feels after driving for a while w the motor getting hotttt at 7k
autoCAR is offline   Reply With Quote
The Following 3 Users Say Thank You to autoCAR For This Useful Post:
JMon85 (08-28-2018), Pekingduck (10-21-2013), Tristor (03-04-2019)
Old 10-16-2013, 11:25 PM   #2
wootwoot
Drives: FRS
Any ability to do data logs to record intake temps?
Old 10-16-2013, 11:40 PM   #3
autoCAR
not yet, im waiting a bit to get an ecutek datalogger. ill prob have one in the next 30 days.
Old 10-17-2013, 11:40 AM   #4
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
I did it similarly to mine a couple months back. It does keep the plastic from soaking in the heat from the header and radiator. I did however leave the top bare.
Also to the OP thanks for shopping with Pegasus ( I work there).
2superblus is offline   Reply With Quote
Old 10-17-2013, 03:20 PM   #5
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
looks like it's heat insulation.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 10-17-2013, 04:20 PM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Nice job wrapping the material. It looks nice. And reminds me of C3PO a little...
The Following 3 Users Say Thank You to Leonardo For This Useful Post:
autoCAR (10-17-2013), Diode Dynamics (10-17-2013), diss7 (03-05-2014)
Old 10-17-2013, 04:38 PM   #7
kakarot1657
kakarot1657's Avatar
Drives: 2013 Subaru BRZ (Galaxy Blue)
LMAO
this came to mind when I saw the pics lol
kakarot1657 is offline   Reply With Quote
The Following 4 Users Say Thank You to kakarot1657 For This Useful Post:
autoCAR (10-17-2013), Braxton... (10-28-2013), MFB (12-07-2013), wbradley (10-17-2013)
Old 10-17-2013, 04:53 PM   #8
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I love Pegasus Racing. How about an FT86club discount hookup?
Old 10-17-2013, 05:00 PM   #9
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
Nicely done! I'll be looking forward to see the difference in intake temps.
G_Ride is offline   Reply With Quote
Old 10-17-2013, 05:26 PM   #10
kanundrum
Drives: 2013 Whiteout FR-S
The Following 2 Users Say Thank You to kanundrum For This Useful Post:
Diode Dynamics (10-17-2013), Laika (10-29-2013)
Old 10-17-2013, 05:27 PM   #11
autoCAR
hahahha true. I wrap trailers as a day job so I do have some experience
Old 10-17-2013, 05:47 PM   #12
Diode Dynamics
Diode Dynamics's Avatar
Hahaha dang you! That's what I was going to post
I think OP should take this a step further:
Nick C.
John C.
Diode Dynamics
The Following 3 Users Say Thank You to Diode Dynamics For This Useful Post:
ftc~brz (02-20-2014), kanundrum (10-17-2013), roddy (11-07-2013)
Old 10-17-2013, 07:22 PM   #13
kodyo
Drives: Scion FR-S
Data aside, do you feel any difference?
kodyo is offline   Reply With Quote
Old 10-17-2013, 07:26 PM   #14
RYU
RYU's Avatar
Drives: really slow...
For those planning to do this. There's no need to wrap the helmholtz resonator box on the passenger side of the assembly. That is a sound trap, not a source for airflow.
RYU is offline   Reply With Quote
Planning to vinyl wrap the hood, how much vinyl wrap to buy? retrosmiths Cosmetic Modification (Interior/Exterior/Lighting) 2 08-12-2013 10:32 AM
Car Wrap / Foil Wrap : Pros and Cons? LeBryan Cosmetic Modification (Interior/Exterior/Lighting) 0 06-25-2013 09:13 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 09:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
