Old 10-17-2013, 12:24 AM   #99
redsuns03
Originally Posted by vinh View Post
what happens if the vents let water get on to the air filter of the turbo?
Worry more about the map sensor getting wet. I'm still looking for a solution for that.
Sent from the Underground Lair of Arizona 86 HQ
Old 10-17-2013, 01:33 AM   #100
Hawk77FT
Drives: GTS 86
i am quite sure that the hood will come vented in the future!
Hawk77FT is offline   Reply With Quote
Old 10-17-2013, 07:30 AM   #101
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Originally Posted by wallace03 View Post
I guess i should have been more specific. Would it be similarly beneficial on a SC as it would be to a turbo?
It is equally beneficial on NA, TC, and SC motors. Some turbo setups may require it more than others though due to turbo placement and the added exhaust heat being dumped in the engine bay.
The down side to vents, and the reason OEM's don't put them, is the exposure to the elements on a DD.
kask2_6.0 is offline   Reply With Quote
The Following User Says Thank You to kask2_6.0 For This Useful Post:
wallace03 (10-17-2013)
Old 10-17-2013, 08:33 AM   #102
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
Some OEMs use vented hoods on performance cars...
Sellout is offline   Reply With Quote
Old 10-17-2013, 11:01 AM   #103
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Wrap the entire throttle body pipe, MAF, and wiring in some form of heat protectant either one of those intake sleeves or some gold foil tape.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
Mathewgzlz (10-17-2013), redsuns03 (10-17-2013)
Old 10-17-2013, 01:49 PM   #104
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Most that do either have them ducted or in a location that water can get through and not cause any issues (ex. the GT500 duct sits between the belt and radiators w/ almost nothing underneath). Just saying it is definitely beneficial but thats just something to considered if you are going vented. Will be venting mine as well eventually.
Old 10-22-2013, 05:52 PM   #105
mike the snake
Looking at the different vented hoods, I'm wondering which one would be most effective is drawing hot air out from the engine compartment?
Where would be the best placement/positions for the vents?
I'm planning on cutting the "mouthpiece" off of my BRZ front which should open the front up quite a bit, but at the same time I'm pretty sure I'm going to need to vent that extra air out of the engine bay.
Old 10-23-2013, 08:54 AM   #106
Frostyman
Drives: 2013 Raven FRS
Aerodynamically, I'm leaning strongly towards the VS style hood from seibon. It has a leading edge lip to create a dramatic high pressure area directly in front of, and subsequently, a low pressure area directly over the vent area. That will cause a lot of engine bay air to be drawn out.
Originally Posted by Don@Accelerated
For the sake of argument I went and cut my factory filter housing up.
Frostyman is offline   Reply With Quote
Old 10-23-2013, 08:30 PM   #107
joergasm
joergasm's Avatar
Drives: Subaru BRZ 2013 - SWP 6MT
Would making the fake side vents functional by cutting into the frame help with cooling?
Sent from my SGH-I317M using Xparent Skyblue Tapatalk 2
joergasm is offline   Reply With Quote
Old 10-23-2013, 11:00 PM   #108
mike the snake
That hood looks like it is very functional. I agree the "trip-lip" should help pull air up and out from under the hood.
Old 10-23-2013, 11:15 PM   #109
Frs300
Frs300's Avatar
Drives: Pile of junk
If I get my car back next week I'm still going to log temps with the oem hood then the ts vented hood.
Frs300 is offline   Reply With Quote
Old 10-24-2013, 12:19 PM   #110
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Then you are going to sell me the hood. amirite?
Old 11-16-2013, 05:32 AM   #111
SuperGTS
FOXTROT-ONE Founder
SuperGTS's Avatar
Drives: 12 Toyota 86 GTS,13 Subaru Forester
anyone know how i can put vents on the... fender garnish... on a gt86?
Sent from my iPod touch using Tapatalk - now Free
Proud owner of a Satin White Pearl 2013 Subaru Forester and a Pegasus White 2012 Toyota 86 GTS. --> **Garage**
Previous: '05 Evo 9, '05 S2000, '00 Civic, '02 VX HSV, '04 Z HSV, '08 E HSV, '90 EXA Coupé
SuperGTS is offline   Reply With Quote
Old 11-16-2013, 06:17 AM   #112
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
I'd REALLY like to see someone come out with nice Fender Garnishes with a few vents , angled back lovers if you will. I've now seen a few folks that drilled these and amount of engine bay heat that releases even static was very surprising! Something color coded with still having the pistons badge position etc would be hot patatoe IMO!!
snails and turbos carbonBLUE Off-Topic Lounge [WARNING: NO POLITICS] 10 12-27-2012 04:44 PM
Turbos making less power down low? subatoy Forced Induction 40 10-03-2012 02:30 AM
Carbon Fiber Hoods. Asterisked Accolade Cosmetic Modification (Interior/Exterior/Lighting) 17 09-25-2012 04:44 PM
Why does the aftermarket love turbos? Why not superchargers? ahausheer Other Vehicles & General Automotive Discussions 43 07-22-2012 10:27 AM
For those crying about turbos Mari0 Off-Topic Lounge [WARNING: NO POLITICS] 2 06-15-2012 09:57 PM
