Old 10-16-2013, 10:11 PM   #1
SilverSkyline210
SilverSkyline210's Avatar
Drives: WRB BRZ
Whiteline Rear LCA finally arrived!
Waited 8 months for these but totally worth it quality is awesome and car feels more direct in the rear
-2.0 camber in front, -0.08 toe front, -1.5 camber in rear, 0.1 toe rear
SilverSkyline210 is offline   Reply With Quote
The Following 2 Users Say Thank You to SilverSkyline210 For This Useful Post:
RenaissanceBoy (04-01-2014), whataboutbob (10-18-2013)
Old 10-17-2013, 02:55 AM   #2
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Wonder how the bushings at the connect point will hold up with the elements and time? Kinda my only concern on these...
The Following User Says Thank You to OICU812 For This Useful Post:
Squishy86 (01-10-2014)
Old 10-17-2013, 05:41 AM   #3
SurfAndSand
8SiX
Drives: FRS 10series
Anyone have a DIY for LCA install?
SurfAndSand is offline   Reply With Quote
Old 10-17-2013, 06:31 AM   #4
FR-S Matt
Jack up the rear, unbolt and remove the LCA's.
Install the new LCA, insert the bolts but do not tighten.
Lower the car, then tighten the bolts.
Go get an alignment.
Done. Yes, its that simple.
The Following 2 Users Say Thank You to FR-S Matt For This Useful Post:
B L U E S L A T E (11-12-2013), SurfAndSand (10-17-2013)
Old 10-17-2013, 07:48 AM   #5
FR-S Matt
Just make sure you properly torque the bolts. There is a guide on here that someone posted the torque specs for each bolt. I can't remember if my SPC LCA's came with the torque specs or else I printed off the page. I want to say I saw someone post the torque specs in their guide.
Old 10-17-2013, 10:01 PM   #6
Rue
Rue's Avatar
Drives: Shoe Leather Limousine
Whiteline makes good quality parts. I imagine the bushings will be comparable to every other polyurethane bushing on the market. You can always replace the bushings with heim joints. Just make sure to buy a quality heim joint (Aurora) and not something intended for industrial use.
Rue is offline   Reply With Quote
Old 10-18-2013, 09:31 AM   #7
koevasi
koevasi's Avatar
Drives: 1
And they are gold so you know they are better lol
koevasi is offline   Reply With Quote
The Following User Says Thank You to koevasi For This Useful Post:
Old 10-18-2013, 10:31 PM   #8
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
How much these going for?
Hows NVH?
Old 10-18-2013, 11:12 PM   #9
koevasi
koevasi's Avatar
Drives: 1
Weight compared to stock or other brands anyone?
Old 10-19-2013, 02:43 PM   #10
Stealth Gt86
Stealth Gt86's Avatar
Drives: silver scion 10 series frs
they look really good up under that blue car.
2013 10 Series
2013 Raven FRS-sold
my old FRS boosted build http://www.ft86club.com/forums/showthread.php?t=31900
follow me on instagram- WeaponsFree86
Stealth Gt86 is offline   Reply With Quote
Old 10-19-2013, 02:59 PM   #11
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Can you use any of those holes for mounting the strut tower and swaybar?
F1point4 is offline   Reply With Quote
Old 10-19-2013, 06:01 PM   #12
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
Yup they provide multiple mounting holes so you can "tune" the mounting point of the dampers and the swaybar links. Pretty nifty.
Circuit Motorsports is offline   Reply With Quote
The Following 2 Users Say Thank You to Circuit Motorsports For This Useful Post:
F1point4 (10-20-2013), whataboutbob (11-28-2013)
Old 10-20-2013, 12:04 AM   #13
SilverSkyline210
Drives: WRB BRZ
Hows NVH?
about $476, and for the past few days i havent noticed much additional NVH
Old 11-09-2013, 03:21 PM   #14
cto424
Does anyone know the torque specs for the LCA?
I found the specs to the hub/LCA and strut/LCA, which are 59 ft/lbs. Does anyone know the specs to the frame/LCA?
cto424 is offline   Reply With Quote
JDL UEL Headers finally arrived! stockysnail Northwest 11 10-18-2013 12:07 AM
Finally, my BRZ has arrived (WRB) wrb BRZ Photos, Videos, Wallpapers, Gallery Forum 24 07-24-2013 03:02 AM
June Order 86 Finally Arrived! lokvo AUSTRALIA 3 02-04-2013 04:40 AM
She Has Finally Arrived truenosan CANADA 26 12-07-2012 06:23 PM
Rusty's GTS finally arrived Rusty86 AUSTRALIA 26 09-28-2012 06:25 AM
