86 Racer
Drives: 86GT
Proper Intake for 86/BRZ
Not a vend - just showing a new way of thinking. An intake that does away with the MAF having the factory ECU run in Speed Density, and an intake that actually reduces pressure drop (negative boost) in the inlet and increases power.
![]() It works....as you might expect. Prototype version only to get baseline pressure drop logs |
#2 |
86 Racer
Drives: 86GT
Oh yes, there is a K&N panel filter that goes into the front of the intake for normal use
![]() No bogging, no stalling, no flat spots, no weird fuel trims, just sharp throttle response and good - actual - power gains from 5500rpm onwards. |
#3 |
Kouki-Monster
So if I want to buy this ...
Rich Anderson
EMPOWER AUTO |
#4 |
Bang Bang
Drives: 2013 Raven FR-S
Looks nice. Not sure where it would pull air from with the hood closed.
Raven 6MT//Injen CAI//VDS UEL//Invidia N1//OFT//ST Coilovers |
#5 |
Drives: Raven FR-S 6M
HOOD DELETE BABY!!^%^%
“The World is Flat”
[||•]=(86)=[•||] |
#6 |
Bang Bang
#7 |
Senior Addict
Drives: 86 GT
Nice...and since you'd need a tune to run this intake, will you be selling the intake only or will you be offering any intake + tune package?
I remember awhile back you had a mail-order/canned tune for the forester xt....is that right? Any similar tunes for the 86? |
#8 |
Drives: Passat
Hot air and speed density? Oh my word...
#9 |
Looks okay, but the stock box is already perfect for this car. I wish I knew what I know back then about this car
#10 |
86 Racer
Drives: 86GT
Log the pressure drop in the inlet manifold on a fourth gear pull to redline. You will see a 5kpa drop. Far from perfect
#11 | ||
Drives: brz
That metal box will just soak up heat like a mother fucker IMO. Especially when stopped. This looks no different than the HKS short ram intake that uses the mushroom filter with the metal plate to direct air into it. Agency Power has one similar also and those 2 intakes are worse designed intakes for this car IMO. The intake boxes all out perform those 2 SRI intakes that just use a straight tube to filter to the TB. In the end true CAI, not the intake boxes like AFE/Greddy/Injen, are the best aftermarket intakes you can get if you want a cone type filter. Then the best is the OEM air box.
Tunes are the best gains you can get for the cost and you get a free baseline so when you do future mods you get an idea of what your mods altogether gain if you care about such things. Quote:
The stock box is more than enough for this car. Anyone who gets an intake for power are getting it for the wrong reasons. A drop in filter gets just as much of gains as other intakes and according to the D-sport article and some dyno's on these forums by independent shops/owners the drop ins are better than 80% of the intakes available. Cars with well designed air boxes shouldnt be touched. You dont touch things that are already working/designed well. Subaru/Scion spent millions in R&D on this engine and I am sure they spent a good amount of time designing the air box with the gains the aftermarket drop ins/ducts/tubes get when used along with it. |
#12 | |
Drives: brz
Almost all intakes get around the same gains as a drop in and this shouldnt perform any different IMO. |
| Had my car taken away for a proper detailing. | Nourdmrolnmt1 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 8 | 04-15-2013 11:43 PM |
| Proper way to Rev Match | pinoyplaya | Engine, Exhaust, Transmission | 46 | 09-05-2012 01:09 PM |
| Proper way to shine your tires | skoodge | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 22 | 05-28-2012 04:35 PM |
| A proper test of the FR-S | Vanguard | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 03-19-2012 10:58 PM |
| Proper Roll Cage | CyberFormula | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 04-12-2010 03:51 PM |
