Old 10-15-2013, 05:18 PM   #1
chickdigger802
Drives: 1997 Geo Prizm
is it possible to rejigger the auto manual mode shifter to flip gear up/down?
maybe i just like the setup better in mazdas and bmws (or was it benz) in which shift up is pull shifter down, was just wondering if its possible to reverse it?
probably not a simple diy, but is it possible?
chickdigger802 is offline   Reply With Quote
Old 10-15-2013, 07:40 PM   #2
bdbx18
Drives: Present MDX, Civic Hybrid, BRZ
I had that issue with my past bimmers when they switched it between models. To me, the BRZ is correct now, push up to Upshift, pull down to Downshift. Mess with it and I'll be bouncing off the redline on every shift :o
Current: 07 MDX, 06 Civic Hybrid, 13 BRZL
Past: 03 M3 SMG, 99 540i, 01 X5 4.4, 01 X5 3.0, 03 MDX, 92 NSX, 89 Maxima, 86 Integra, 88 Odyssey, 88 Legend, Supra, MR2T, Pathfinder, MirageT, Accord
bdbx18 is offline   Reply With Quote
Old 10-15-2013, 07:43 PM   #3
Gunman
Drives: 2019 Mazda Miata RF
BRZ/FR-S is backwards. Every race car I've been involved with, you pull back to go up in gear, and push fwd to go down in gear. Basically using inertia to help you shift, acceleration moves you backwards, braking moves you forward.
The Following 3 Users Say Thank You to Gunman For This Useful Post:
Evil Jesus (10-15-2013), Luis_GT (10-15-2013), Turbowned (10-15-2013)
Old 10-15-2013, 09:31 PM   #4
kevman_101
Drives: 2013 Scion FRS
Exactly.
kevman_101 is offline   Reply With Quote
Old 10-15-2013, 09:43 PM   #5
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
Thought is had the shifters on the steering wheel?
ericmpena is offline   Reply With Quote
Old 10-15-2013, 09:48 PM   #6
Turbowned
Turbowned's Avatar
Not everyone wants to use the paddles, though.
Old 10-15-2013, 11:00 PM   #7
mezdup
#1362
mezdup's Avatar
Drives: 2014 Ice Silver WRX
http://www.ft86club.com/forums/showthread.php?t=21741
mezdup is offline   Reply With Quote
Old 10-15-2013, 11:13 PM   #8
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Jeez, just get used to it. There's nothing logical about either method.
A manual gearbox uses both directions for both depending on the gears and shift pattern.
When you drive a particular car you just adapt.
Suberman is offline   Reply With Quote
The Following User Says Thank You to Suberman For This Useful Post:
Prog (10-15-2013)
Old 10-16-2013, 10:04 AM   #9
Frostyman
Drives: 2013 Raven FRS
Rude... Don't tell someone who is asking if something is possible to just get used to it. He's not fucking with your car, so stand-off.
Originally Posted by Don@Accelerated
For the sake of argument I went and cut my factory filter housing up.
Frostyman is offline   Reply With Quote
Old 10-16-2013, 10:36 AM   #10
atledreier
Drives: GT86 DGM
I saw a kit on ebay a while back that changed the markings on the console and did the wires too. Looked pretty neat. The backwards thing has become the industry standard for manual autos, and it bugs me to no end....
atledreier is offline   Reply With Quote
Old 10-16-2013, 09:10 PM   #11
hushypushy
ビーアールゼット
hushypushy's Avatar
Drives: WRB BRZ '18
Gunman already said it: the shift motion should reflect the momentum of the car. As you slow down, your momentum continues forward--so you press the lever forward to shift down. As you speed up, you get pushed back in the seat--hence pulling back for upshifts.
That makes perfect sense to me. What's illogical is why so many street cars continue to have it reversed...
hushypushy is offline   Reply With Quote
Old 10-17-2013, 07:43 AM   #12
Gunman
In this case, the auto is being used like a sequential box, not an "H" pattern.
Old 10-17-2013, 10:07 AM   #13
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
Because most cars aren't pushed like they are on a race track is my guess really. No need to factor in the inertia if there isn't any from the driving style.
Mad1723 is offline   Reply With Quote
Old 10-17-2013, 10:46 AM   #14
2013GTRNate
2013GTRNate's Avatar
I bet that if the tuners really wanted to they could figure something out that would accommodate changing the shifting on the AUTO. It would have to be like the SYVECS in the GT-R community. The only issue is demand.
2013 Nissan GT-R Premium
2014 Subaru BRZ Limited
2014 Forester XT Touring
My BRZ's thread: http://www.ft86club.com/forums/showthread.php?t=47467
2013GTRNate is offline   Reply With Quote
Question about A/T using it in Manual mode Oburn Engine, Exhaust, Transmission 46 07-07-2022 06:40 PM
Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? soulstice Cosmetic Modification (Interior/Exterior/Lighting) 52 01-24-2016 09:20 PM
More MPG in manual mode (AT) aceangel BRZ First-Gen (2012+) — General Topics 11 03-27-2013 02:12 PM
AT Manual Mode Easter Egg? whataboutbob Engine, Exhaust, Transmission 2 12-14-2012 12:03 PM
AT Manual Mode Downshifting Reprobate Scion FR-S / Toyota 86 GT86 General Forum 2 07-23-2012 12:40 PM
