Old 10-15-2013, 01:54 PM   #477
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by lbroskee View Post
bc the intercooler outlet. if it was designed with a reg 2 side outlet it wud require a washer bottle delete
I have a reg 2 side outlet and a factory washer bottle, so do the AVO kits.
Sportsguy83 (10-15-2013)
Old 10-15-2013, 01:55 PM   #478
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Originally Posted by Frs300 View Post
i would run a remote washer bottle before i cut crash beam
Is your kit running a different piping route than the other FA20Club kits?
Old 10-15-2013, 01:56 PM   #479
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
My bad i was thinking intake. Now I'm curious y this weird IC LOL
lbroskee is offline   Reply With Quote
Old 10-15-2013, 01:57 PM   #480
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Making the pipe run as short as possible.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
lbroskee (10-15-2013)
Old 10-15-2013, 01:59 PM   #481
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Yep. I have to say that I do admire the shorter piping routing of the kits that run the outlet of the turbo over the top of the radiator versus going through the headlight areas.
Old 10-15-2013, 02:04 PM   #482
lbroskee
lbroskee's Avatar
Tru. Jus boils down to radiator compatibility after that
Old 10-15-2013, 02:12 PM   #483
Frs300
Frs300's Avatar
Drives: Pile of junk
Not sure about routing but I know its different sizes due to inlet/outlet being different on the 6266. On the ic pics toni threw up in the thread there was only one inlet/outlet on the ic itself if i remember correctly. So I don't know if its same routing
Frs300 is offline   Reply With Quote
Old 10-15-2013, 02:16 PM   #484
sid3way5
Drives: 13 wrb brz greddy evo3 catback.....
Hmm ok the guys at mr performance are installing my kit now they said they have to make their own piping bc toni told them to cut the hid box so the ic pipes would fit but they don't want to do that
sid3way5 is offline   Reply With Quote
Old 10-15-2013, 03:32 PM   #485
bgibbsunc
bgibbsunc's Avatar
Drives: Firestorm Scion FR-S
Thats when you say well Ill be taking it somewhere else to be installed. lol
Its really not as serious as it looks. its a 4-6 inch notch out. Me personally I like it because the piping from the turbo to the IC is literally maybe a foot. Only thing i wish is that the filter location could be different, but there really isnt a lot of room. Im going to try and get mine down in front of the wiper fluid and run the fog light cut out that APR makes.
FA20 club 60 trim + flex fuel
467 whp 356 ft lbs @ 19 lbs
Owner of Sidewinders Auto LLC.
San Antonio TX
bgibbsunc is offline   Reply With Quote
Old 10-15-2013, 03:38 PM   #486
sid3way5
My kit should be the standard ic piping with the fa20 kits I didn't request special piping
Old 10-15-2013, 03:41 PM   #487
sid3way5
Lol to late to take it some where else its almost complete now
Old 10-15-2013, 03:52 PM   #488
bgibbsunc
bgibbsunc's Avatar
So how the hell are they mounting the IC? Or are they using a different IC? Only thing I can think is mount it lower but depending on your suspension that would be way too low.
San Antonio TX
Old 10-15-2013, 09:27 PM   #489
sid3way5
they want to make their own ic pipes
Old 10-16-2013, 12:06 AM   #490
bgibbsunc
bgibbsunc's Avatar
I understand that but don't really see how they are going to make piping that works with that front mount. It can only really mount under the crash bar. Well post pics when its done.
San Antonio TX
0-60 in 22million sec, beam, best of all, doyen done done it again!, fa20club header, fa20club.com, fa20crap, fa20crud.com, frs turbo kit, i like turbos, turbo frs, turbo kit, turbocharged brz, visconti 2.0?, welding4noobs, www.p&lclub.com, you'llneedamuletoride
FA20CLUB TURBO KIT T3/T4 60 86pro Forced Induction 50 07-26-2014 11:48 AM
Fa20club turbo install issues Mikegraves777 Forced Induction 8 07-25-2013 12:56 AM
FA20CLUB 60 Trim Turbo 16 PSI Results Are In FA20Club.com Forced Induction 148 07-22-2013 08:00 PM
FA20CLUB V2 Turbo Kit Progress FA20Club.com Forced Induction 40 05-17-2013 01:26 PM
