Old 10-14-2013, 09:42 PM   #435
Frs300
Frs300's Avatar
Drives: Pile of junk
Originally Posted by DriftEightSix View Post
ROFL You can't touch your crash bars at all!!! Not having sharp edges being the issue but touching something that is so critical to its precious ANCAP/Safety rating is what makes it illegal.
By the look of how that thing is cut, you have now made it crumple in a away it was not designed too.
I guess with the washer bottle delete would it completely remove it... could you put a smaller one in its place?.. I guess that would be an option.
i would run a remote washer bottle before i cut crash beam
Frs300 is offline   Reply With Quote
Old 10-14-2013, 09:46 PM   #436
Dan@AWD
Drives: 2013 Argento FR-S
It sounds like you need to go into the Innovative Supercharger thread.
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
Dan@AWD is offline   Reply With Quote
Old 10-14-2013, 10:03 PM   #437
Skorov
Skorov's Avatar
Drives: 86 GTS White
Well that's an issue then... =S
Damn. And I really wanted this kit too. I guess I'll wait and see if a smaller washer bottle is an option.
Cheers for the info.
Skorov is offline   Reply With Quote
Old 10-14-2013, 10:12 PM   #438
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Ahhaha why? I Dont like superchargers.
I've seen plently turbo kits not need to cut the beam.
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 10-15-2013, 12:18 AM   #439
FAER
Drives: Silver BRZ
Originally Posted by SmsAlSuwaidi View Post
took 30 days between to get our headers after the turbo and pipes, but we had an issue with our headers being "lost". Now its a wait for the IC
sounds like my situation..
FAER is offline   Reply With Quote
Old 10-15-2013, 12:20 AM   #440
FAER
Drives: Silver BRZ
well this isn't one of them..
the solution is to cut the beam and box in whats removed with a tube or beam...
or just remove the beam entirely, after all these kits are not approved for "on road use"
Old 10-15-2013, 01:27 AM   #441
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Old 10-15-2013, 01:40 AM   #442
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
yet ur running this kit?
lbroskee is offline   Reply With Quote
Old 10-15-2013, 04:07 AM   #443
DriftEightSix
Pegasus White
Drives: 86
The funny thing is we can get them engineered approved that will allow us to run them on the street.
Yes it appears its one of the kits that requires a beam cut. Didn't know this till now.
Old 10-15-2013, 05:11 AM   #444
rskdsk
Drives: series 10 FR-S (2361)
Are you guys fXXing crazy ... that has to be the stupidest design I have every seen for an intercooler!
What were they thinking ... lets reduce the weight by cutting off some needless safety stuff since we are adding the weight of an intercooler?!?
yikkes
rskdsk is offline   Reply With Quote
Old 10-15-2013, 06:54 AM   #445
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
Originally Posted by ecko04 View Post
Congratulations @ecko04! Looks very nice. I am assuming these were on 93. Are you looking to add e85? That should get you very close to 300whp.
pixel67 is offline   Reply With Quote
Old 10-15-2013, 06:55 AM   #446
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
FA20Club Turbo Kit Owners Topic
This thread isn't the one for you to complain about the design of the kit. This is an owners thread which means, we already have it and it wasn't a deal breaker for us so your complaints fall on deaf ears here.
@FA20Club.com doesn't follow this thread as it's not their own. If you want to give feedback or have questions about the design then go to their thread to do so: http://www.ft86club.com/forums/showthread.php?t=34291
Lastly, the entire crash beam is not being cut. You notch out the back of the crash bar to allow enough clearance for a coupler. The front of the crash bar is still completely in-tact. The inside of the crash beam is hollow to begin with. Some people are giving the impression that the end of the world is near because you notched a 3 inch section on the back of a beam that isn't made of solid steel.
At the end of the day if this is a deal breaker for you, there are other kits available. Your wagon isn't hitched to something you haven't bought.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
The Following 3 Users Say Thank You to ecko04 For This Useful Post:
lbroskee (10-15-2013), mikeTee (10-15-2013), natedogg86 (10-15-2013)
Old 10-15-2013, 06:58 AM   #447
natedogg86
Drives: 2013 Toyota 86 GT 6M
yikkes
Actually genius, its pretty smart. As Toni described his reasons for shortening the pipes in V2 of his kit resulted in significantly reduced spool times since most people are purchasing it with a journal bearing turbo which is slower in comparison to BB turbos wrt spool times.
It has nothing to do with weight saving although shorter pipes do save prob a few pounds in weight.
natedogg86 is offline   Reply With Quote
Old 10-15-2013, 07:00 AM   #448
Dan@AWD
Originally Posted by pixel67 View Post
Congratulations Dan! Looks very nice. I am assuming these were on 93. Are you looking to add e85? That should get you very close to 300whp.
These are not my dyno #'s, unless @ecko04 name is Dan also.
I hit my goals. See my sig.
0-60 in 22million sec, beam, best of all, doyen done done it again!, fa20club header, fa20club.com, fa20crap, fa20crud.com, frs turbo kit, i like turbos, turbo frs, turbo kit, turbocharged brz, visconti 2.0?, welding4noobs, www.p&lclub.com, you'llneedamuletoride
FA20CLUB TURBO KIT T3/T4 60 86pro Forced Induction 50 07-26-2014 11:48 AM
Fa20club turbo install issues Mikegraves777 Forced Induction 8 07-25-2013 12:56 AM
FA20CLUB 60 Trim Turbo 16 PSI Results Are In FA20Club.com Forced Induction 148 07-22-2013 08:00 PM
FA20CLUB V2 Turbo Kit Progress FA20Club.com Forced Induction 40 05-17-2013 01:26 PM
