Old 10-14-2013, 07:36 PM   #421
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Originally Posted by Ny Brz View Post
How much psi you running?
Boost plot is the 3rd pic. 7.5psi
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 10-14-2013, 07:43 PM   #422
Ny Brz
Hella Flush
Ny Brz's Avatar
Drives: 2013 SWP BRZ
Opppps should have looked closer, good stuff.
Ny Brz is offline   Reply With Quote
Old 10-14-2013, 08:30 PM   #423
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Originally Posted by Dan@AWD View Post
Do all installs require the front bar to be cut like this?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 10-14-2013, 08:31 PM   #424
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Yes
Old 10-14-2013, 08:35 PM   #425
DriftEightSix
Pegasus White
Drives: 86
Why?
Old 10-14-2013, 08:35 PM   #426
Skorov
Skorov's Avatar
Drives: 86 GTS White
Excuse my ignorance. I'm quite new to boost game. But why does it take so long to reach max boost? Is it tuned that way?
Skorov is offline   Reply With Quote
Old 10-14-2013, 08:37 PM   #427
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Why?
You're asking the wrong one buddy. No clue, I just follow the instructions. Maybe @FA20Club.com can chime in with their design process?
Old 10-14-2013, 08:38 PM   #428
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
4th gear pull
Old 10-14-2013, 08:39 PM   #429
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Why?
bc the intercooler outlet. if it was designed with a reg 2 side outlet it wud require a washer bottle delete
lbroskee is offline   Reply With Quote
Old 10-14-2013, 08:42 PM   #430
DriftEightSix
Pegasus White
Drives: 86
4th gear pull
In a 2nd or 3rd gear pull when does full boost occur?
Old 10-14-2013, 08:44 PM   #431
DriftEightSix
Pegasus White
Drives: 86
damn either of these options would mean the car couldn't be driven on the streets where im from...
Old 10-14-2013, 08:44 PM   #432
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
FA20Club Turbo Kit Owners Topic
Much quicker in lower gears. I can't give you an accurate answer because I have flogged it. I'm still breaking in my new clutch.
Old 10-14-2013, 09:02 PM   #433
Skorov
Skorov's Avatar
Why is cutting the bar an issue? Surely if you round off the sharp edges it'll be ok...
Or is it something different in Queensland?
Old 10-14-2013, 09:19 PM   #434
DriftEightSix
Pegasus White
Drives: 86
ROFL You can't touch your crash bars at all!!! Not having sharp edges being the issue but touching something that is so critical to its precious ANCAP/Safety rating is what makes it illegal.
By the look of how that thing is cut, you have now made it crumple in a away it was not designed too.
I guess with the washer bottle delete would it completely remove it... could you put a smaller one in its place?.. I guess that would be an option.
0-60 in 22million sec, beam, best of all, doyen done done it again!, fa20club header, fa20club.com, fa20crap, fa20crud.com, frs turbo kit, i like turbos, turbo frs, turbo kit, turbocharged brz, visconti 2.0?, welding4noobs, www.p&lclub.com, you'llneedamuletoride
FA20CLUB TURBO KIT T3/T4 60 86pro Forced Induction 50 07-26-2014 11:48 AM
Fa20club turbo install issues Mikegraves777 Forced Induction 8 07-25-2013 12:56 AM
FA20CLUB 60 Trim Turbo 16 PSI Results Are In FA20Club.com Forced Induction 148 07-22-2013 08:00 PM
FA20CLUB V2 Turbo Kit Progress FA20Club.com Forced Induction 40 05-17-2013 01:26 PM
