Old 10-14-2013, 11:56 AM   #1
dro
Drives: Fr-S Asphalt '13
Why does it stutter when I accelerate?
I am at a red light or the car is stopped and it stutters. It is close to 3k miles and been 4 months since Ive had the car. I don't go too hard on it, I am gentle most of the times except when I let others test drive it. Also recently it has been rattling when I turn it on, is the response since its getting cold?
dro is offline   Reply With Quote
Old 10-14-2013, 12:02 PM   #2
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
I don't have either of those issues at 13,000 miles. I also don't let other people 'test drive' my car.
whaap is offline   Reply With Quote
Old 10-14-2013, 12:08 PM   #3
Steve201brz
Need a little more clarity, there might be other topics on this type of issue already.
It happens when you're stopped and then start to accelerate? Or just when stopped? I'm assuming your talking about your RPM fluctuating
Steve201brz is offline   Reply With Quote
Old 10-14-2013, 12:41 PM   #4
dro
It happens when I am stopped and I accelerate. Its not smooth and its not natural, I have never had a car do this before.
Old 10-14-2013, 01:01 PM   #5
thill
Auto or manual transmission? Are you seeing your RPM's drop?
Old 10-14-2013, 01:02 PM   #6
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
Dat sig.
husker741 is offline   Reply With Quote
Old 10-14-2013, 01:09 PM   #7
Carsten
Drives: Matrix
I felt like this was happening to me while I was test driving an a/t. But it only happened in the paddle shifter mode and when I was decelerating to a stop. But I think it was caused by the rpm drop
Carsten is offline   Reply With Quote
Old 10-14-2013, 01:12 PM   #8
Steve201brz
When you hit the gas off the line, the RPM's will raise to 1000 then drop to 600 then jump to 1100+? Not these exact numbers but basically the tach looks erradic. Does is stop stuttering and smooth out once you get up to speed?
Old 10-14-2013, 01:48 PM   #9
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
I think you're experiencing the idle dip? You're talking about when you are completely stopped and your RPMs just suddenly drop a bit? If so, you might want to check with your dealership to get your ECU updated (There was a TSB)
Books is offline   Reply With Quote
Old 10-14-2013, 02:29 PM   #10
thill
That was where I was going as well.. OP may want to read up on this:
http://www.ft86club.com/forums/showthread.php?t=15577
Hearing a squeak whenever I accelerate and shift gears slowbrz Issues | Warranty | Recalls / TSB 7 05-29-2022 09:52 PM
Is it true I have to wring out the motor if I want to accelerate? autobrz BRZ First-Gen (2012+) — General Topics 41 05-30-2013 12:03 PM
