Old 10-11-2013, 03:48 PM   #1
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
What tape do you use to protect your front end on track days?
I've got a track day coming up and I'd like to protect my front end. What tape do you guys suggest?
post_break is offline   Reply With Quote
Old 10-12-2013, 01:15 AM   #2
Pokeguyjai
Pokeguyjai's Avatar
Drives: 2013 GBS BRZ (AT)
Might be a little overboard but:
http://www.roadwarriorplus.com/default.asp
Pokeguyjai is offline   Reply With Quote
Old 10-12-2013, 02:51 PM   #3
Gearhead23
Autoxer
Drives: 2024 BRZ tS / 2005 WRX Sedan.
http://www.autozone.com/autozone/lan...der-spray-film
http://www.ft86club.com/forums/showthread.php?t=38009
Gearhead23 is offline   Reply With Quote
Old 10-13-2013, 11:10 AM   #4
aCab
aCab's Avatar
Drives: FR-S & S2k
I run mine naked...and it shows
Bilstein Damptronic Prototypes | Other silly bits
aCab is offline   Reply With Quote
Old 10-14-2013, 04:56 AM   #5
TSY
TSY's Avatar
Drives: 2013 BRZ Limited SWP
i use this:
http://www.trakktape.com/
Easy to put on and take off. clear so your car doesn't have all that blue painter's tape all over and looks better. My car is white so orange cone stains don't come out easily so this stuff is great.
Past Subarus: 08 STI, 05 Legacy GT, 98 Legacy L wagon, 97 SVX LSi
Daily Driver: 2013 Acura MDX
TSY is offline   Reply With Quote
Old 10-14-2013, 09:13 AM   #6
Stevo22
Stevo22's Avatar
Drives: GR86
Has anyone ever tried using plasti dip like this video shows:
[ame]http://youtu.be/Pz6tO2Ggdrk[/ame]
Stevo22 is offline   Reply With Quote
Old 10-14-2013, 09:18 AM   #7
aCab
aCab's Avatar
Drives: FR-S & S2k
I've never had orange cones leave orange marks :curious:
Old 10-14-2013, 09:23 AM   #8
Stevo22
Stevo22's Avatar
Drives: GR86
Is this because you don't hit them ? I have had them leave marks, but it is more like a film that rubbed out with some detail spray.
Old 10-14-2013, 12:47 PM   #9
aCab
aCab's Avatar
Drives: FR-S & S2k
Not at all. Im usually on trial for cone murder at the end of an autox event. Cones, in my experience, leave black/grey marks. Never had orange residue. I usually have to use a clay bar and lots of elbow grease.
Old 10-14-2013, 12:51 PM   #10
TemeCal
Drives: 86
This is what I use. Been using it for the past 10 track events, and my front-end still looks great. It's expensive, unless you buy it by the gallon. I figured it's about $7 per track day, with the amount I use.
TemeCal is offline   Reply With Quote
The Following 2 Users Say Thank You to TemeCal For This Useful Post:
MightyMeeple (10-14-2013), Pokeguyjai (10-14-2013)
Old 10-14-2013, 04:17 PM   #11
Pokeguyjai
Pokeguyjai's Avatar
Do you do one layer of it or do you layer it on? How easy is it to remove?
The Following User Says Thank You to Pokeguyjai For This Useful Post:
Old 10-14-2013, 04:19 PM   #12
ModBargains.com
ModBargains.com's Avatar
Blue painters tape usually works for me. Takes some time to do, but it'll save you from rock chips
ModBargains.com is offline   Reply With Quote
Old 10-14-2013, 04:25 PM   #13
mrk1
Drives: Sterling BRZ Ltd
my car just wears the scares of cone contact, more of the blemishes are from tire clag
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 10-14-2013, 04:44 PM   #14
TemeCal
Drives: 86
I always put on 2 layers. First layer takes about 5-10min to put on, second layer takes even less. It goes on much quicker than tape (what I used to do). I'm not sure I could go back to tape now.
As for removing it, it takes a little longer. If you peel up a corner, you can usually get it 90% off in a single sheet. It peels up like saran wrap...kind of a plastic/rubber feel to it. The remaining 10% are typically small areas. I've found that spraying a little ONR/water mist over the entire area helps remove the protectant. I'd say it takes me 20min to remove it all.
Thermal tape to protect wheel/suspension components? ayau Tracking / Autocross / HPDE / Drifting 4 07-15-2013 09:14 AM
Track Days... anybody going here? chjno86 Southern California 1 05-31-2013 05:45 AM
Little insurance for track days jdzumwalt Tracking / Autocross / HPDE / Drifting 0 03-21-2013 12:27 AM
Best way to protect front of new car when driving back FastLap Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 21 08-04-2012 04:48 PM
