Old 10-13-2013, 01:38 PM   #1
qqzj
Drives: MDX, Camry
Are your valve stem caps safe?
I bought these nice looking Subie valve stem caps:
http://www.ebay.com/itm/Genuine-OEM-...-/151085019145
While I was putting them on, it suddenly occurred to me that it might be easily stolen. Has this happened to anybody here? Just curious.
qqzj is offline   Reply With Quote
Old 10-13-2013, 01:41 PM   #2
ZionsWrath
Thanks
ZionsWrath's Avatar
Yes my old car all the time lol
If you have anything that isn't a standard plastic one a scum bag will probably take them.
Old 10-13-2013, 01:48 PM   #3
mkiisupra
mkiisupra's Avatar
Drives: 83 Toyota Supra, 16 FR-S RS2.0
Yup, lost my sweet Rays caps that came with the Nismo TE37 bronze wheels on my old 350z. Cost about $70 for another set, since they aren't sold one at a time. Keep the plastic ones and swap out for shows/meets, etc.
Eric G
mkiisupra is offline   Reply With Quote
Old 10-13-2013, 02:42 PM   #4
Abenaki
Curmudgeon@gezzer.com
Abenaki's Avatar
http://www.walmart.com/ip/Slime-Tire...s-Red/16879930
Try these... Walmart - $2.48 for 4 aluminum caps in various colors. If someone steals them, your it will probably cost more in gas than the cost of the caps, to get new ones. :-)
Abenaki is offline   Reply With Quote
The Following User Says Thank You to Abenaki For This Useful Post:
Wolfking (10-17-2013)
Old 10-13-2013, 02:58 PM   #5
ZionsWrath
Thanks
ZionsWrath's Avatar
Cheap and ugly lol
They don't even look the proper shape
I gave up on replacing mine, if someone takes mine that came with my enkei ill just put plastic ones i find in the gutter
Old 10-13-2013, 04:35 PM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
use grease with those!!!!
i had a set on a previous car, and they got seized on. i had to use a dremel to cut them off just to check my tire pressure.
Grymm86 (10-13-2013)
Old 10-13-2013, 06:07 PM   #7
Grymm86
Grymm86's Avatar
Drives: BRZ Limited DGM
i am employed at firestone, every few weeks we get someone in who has metal valve caps on, seized up. they may look good, but unless you maintain them properly they will corrode onto your tpms sensors and more than likely cost you a new sensor. plastic caps wont seize, ever, and are pennies. if not free.
Grymm86 is offline   Reply With Quote
The Following User Says Thank You to Grymm86 For This Useful Post:
Old 10-13-2013, 06:13 PM   #8
qqzj
Drives: MDX, Camry
How about oem caps? Do I also need to put grease on? thanks.
Old 10-13-2013, 06:13 PM   #9
Kyle106
Kyle106's Avatar
Drives: 2013 WRB BRZ Limited
I have had mine on since March (I live in PHX) and have had no problem with anyone messing with them *knock on wood
Kyle106 is offline   Reply With Quote
Old 10-13-2013, 07:23 PM   #10
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
Someone is not checking their tire pressure. If this would be done, say, once a month, for instance, and not tighten them as is they might loose pressure if not tightened securely. Just check tire pressure frequently and don't tighten them beyond 'snug'. They will not thread themselves off.
BRZfan is offline   Reply With Quote
Old 10-13-2013, 07:51 PM   #11
bestwheelbase
Drives: 1985 P-Type
One time, at a dyno day, I saw an aftermarket stem cap fly off and nail a girl square in the forehead.
The Following 7 Users Say Thank You to bestwheelbase For This Useful Post:
akyp (10-18-2013), Anthonytpt (10-17-2013), DAMotorsports (10-18-2013), FrX (10-18-2013), ftc~brz (10-17-2013), Spartan65 (10-17-2013), TwoChicksOneSTI (08-20-2017)
Old 10-13-2013, 08:44 PM   #12
cnk
Drives: '13 DGM BRZ Limited
On my old WRX I had just put on SSR Comps and within a week someone had taken 2 of them while the car was parked at the mall. I purchased some replacement caps that had an exterior body that would freely turn and you needed a 2-prong cylindrical key that fit in the top of the cap to remove them. Never had a cap stolen after that.
Old 10-13-2013, 08:48 PM   #13
soundman98
soundman98's Avatar
no, because the oem caps are plastic.
the caps in that link are made of a metal that is different than the metal in the oe valve stems. that is where the corrosion comes from.
Old 10-13-2013, 08:57 PM   #14
buckets
buckets's Avatar
Drives: infiniti g37x
omg. this made me chuckle
buckets is offline   Reply With Quote
Works Valve Stem & RS-R Lug Nuts xDBOYx Wheels and Tires 7 11-29-2014 06:23 PM
Center Cap Trades? My Scion caps for your Subaru caps? ubersoph Wheels and Tires 0 07-10-2013 01:28 PM
DIY Antenna Stem Removal ninjasaurusrex DIY (Do-It-Yourself) Guides 18 01-29-2013 11:35 PM
Can this valve stem be rebuilt? ayau Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 12-24-2012 03:57 AM
FS/FT: OEM FRS Center Caps (Trade for Subaru Center Caps) Meeners Wheels and Tires 4 11-20-2012 05:47 PM
