Old 10-13-2013, 08:28 AM   #15
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
Originally Posted by Kostamojen View Post
Exactly. See the SYMs wagons for an excellent example:
"Built at a reported cost of $250,000 each, these Impreza wagons were powered by a normally aspirated 2-liter EJ20 engine featuring roller barrel throttle bodies fed by a carbon fiber airbox and dry sump system. Internals were a closely guarded secret, but output was 300 hp at 8,200 rpm. Moved back for better weight distribution, the FR layout was mated to a sequential transmission, with a BMW diff driving the rear wheels."
http://superchargercalculators.blogs...on-to.html?m=1
That number seems a little suspect to me, even for a racing engine - they'd need to be making 192ft-lb at 8200 to pull that off, which seems too high for a n/a 2L. Sure, you can absolutely make a 300hp n/a 2L racing engine, but I'd expect it to make less torque than that and rev a bit higher instead.
Sent from my SCH-I545 using Tapatalk 2
chrisl is offline   Reply With Quote
Old 10-13-2013, 09:28 AM   #16
ft_sjo
Drives: GT86
On pump fuel I'd agree, but may be possible with race fuel.
Old 10-13-2013, 09:53 AM   #17
wparsons
wparsons's Avatar
Originally Posted by Anthony View Post
It would be nice if someone released an intake manifold and throttle body that was both effective and affordable. HKS can keep theirs.
Why is everyone bringing up the TB?? The stock TB on these engines is already huge (bigger than most people upgrade other 2L engines to!), you won't see gains from going bigger until you're making a lot more HP.
flickr
Old 10-13-2013, 10:04 AM   #18
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Because a hypothetical throttle body that would be effective would be effective.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 10-13-2013, 11:04 AM   #19
Kostamojen
Old 10-13-2013, 09:59 PM   #20
wparsons
wparsons's Avatar
TB's aren't magical black boxes, they just let air through. If the hole is big enough for the air the engine needs going bigger won't do anything to increase performance.
A bigger TB will feel faster at part throttle because it will let more air in at a given throttle plate angle, but at WOT it won't make a difference.
flickr
Old 10-17-2013, 12:42 PM   #21
Nitro_FRS
Drives: sexy
I guess ill just have my buddy build a tubular intake for me if it isnt available.
Nitro_FRS is offline   Reply With Quote
exhaust, intake, manifold, performance
all season high performance or winter performance tires? Aloxi NY / NJ / CT / PA 29 03-24-2015 09:23 PM
Bullet Performance supercharger by Mercury Performance mastertech86 Forced Induction 219 10-24-2012 06:01 AM
Lutz Performance | Performance parts SALE Diego@lutzperformance Engine, Exhaust, Bolt-Ons 8 10-08-2012 10:09 AM
