Old 10-05-2013, 02:39 AM   #183
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
Originally Posted by Dan@AWD View Post
Thanks. I just ordered 4 255/35/18 Hankook R-S3 for square setup.
Nice let us know. +38 thats the right offset right? Might order work kiwami soon
hanabie is offline   Reply With Quote
Old 10-05-2013, 02:53 AM   #184
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
255/35/18 definitely a safe choice for sure.
Old 10-11-2013, 01:48 AM   #185
GROOV3
Drives: GTS
figured I would share mine as these threads are a huge help
18x9.5 +38
235/40/18 all around
just lowered on sportline springs (1.2-4" drop)
about 3-4mm clearance on the inside of the front wheel between spring and wheel but no rubbing front or back at all.
GROOV3 is offline   Reply With Quote
The Following 3 Users Say Thank You to GROOV3 For This Useful Post:
A-RS (03-13-2014), manonastick (10-11-2013), SoCal909 (12-26-2013)
Old 11-07-2013, 11:47 PM   #186
BrunoM
Drives: GT86
18x9.5 +38
Juste wondering it wouldn't be OK.
My Eibach Sportline springs are arriving very soon and I have already installed Rota Grid 18x9.5 ET38 on 235/40/18 all around
I will post pictures when done.
It's hard to find people who tried this setup without coilovers, only wheeldudes (that has put KW after so we don't know if there was any issue without) and 1 other guy on this forum. You are the 3rd I see doing it.
I will post my picture and experience too when I will have it installed, so it will be found when you google it.
Thank you for your post. It's very useful.
BrunoM is offline   Reply With Quote
The Following 2 Users Say Thank You to BrunoM For This Useful Post:
LT (03-14-2014), manonastick (11-08-2013)
Old 11-18-2013, 05:14 PM   #187
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Merged @funcheung's topic about the same wheel/same spec.
Old 11-18-2013, 07:49 PM   #188
DarrenDriven
NW Region Moderator
Merged @SliverBrz's topic: same wheels with same specs
Old 11-18-2013, 08:58 PM   #189
DarrenDriven
NW Region Moderator
Merged @Dan@AWD's topic: same wheels w same specs
Old 11-26-2013, 03:48 AM   #190
Hiros86
Hiros86's Avatar
Drives: whiteout FR-S
Originally Posted by SliverBrz View Post
I have 255/35/18 all around, same set up except with swifts, no rubbing anywhere.
However i will be getting coilovers soon.
Also have camber bolts and front is about -1.4
I think any bigger and front spring perch will rub tire
More pics
Hiros86 is offline   Reply With Quote
Old 01-07-2014, 07:29 PM   #191
bildo
Drives: FT86 ZN6
Buying used wheels- will this work?
Hi guys
Im looking at buying some second hand wheels with rubber included, before I get them I just want to know if they will fit. So they are:
Enkei Rpf1 18x9.5 +38 on all fours.
Fronts 235/35/18
Rears 255/35/18
I only have stock suspension, but i plan to get Eibach Sportline springs to drop the height a bit.
Ive seen on the forums some cars with similar setup sit pretty nicely but the rubber is different.
What do you guys think?
Sent from my GT-I9505 using Tapatalk
bildo is offline   Reply With Quote
Old 01-07-2014, 07:30 PM   #192
B L U E S L A T E
Drives: BMW E84
bolt pattern?
B L U E S L A T E is offline   Reply With Quote
The Following User Says Thank You to B L U E S L A T E For This Useful Post:
mav1178 (01-07-2014)
Old 01-07-2014, 07:41 PM   #193
hanabie
hanabie's Avatar
I had Swift springs on stock struts with similar specs 18x 9.5 +38.
It will work without rubbing the front perch. I'm assuming you were talking 0 cambers.
Now, are you comfortable with poke and 5-7mm clearance from the perch?
If you want something that aggressive, I suggest you to get coils and a set of camber bolts for your front poke if you don't have any camber plates.
Old 01-07-2014, 08:45 PM   #194
bildo
Drives: FT86 ZN6
5X100 of course lol.
When u guys say poke do you mean the front wheel will stick out by 5-7mm?
Old 01-07-2014, 09:30 PM   #195
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
Sportlines drop you 1.4".
That drop with 0deg front camber, running 9.5" +38 offset wheels is going to have approximately 10mm of poke, wheel sticking out. To tuck that in, you'll need almost -3deg camber up front for a flush fit, which would require camber top plate coilovers.
mwjcyber is offline   Reply With Quote
Old 01-08-2014, 07:57 AM   #196
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Guys... you're giving him horrible information.
Baseball bat fender roll and you're good to go.
slicktop is offline   Reply With Quote
ft-86 speedfactory
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 06:31 AM
Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 GuerillaRacing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 221 08-01-2019 10:30 AM
Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel Infamous Performance Wheels and Tires 122 02-13-2014 11:34 AM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 04:53 PM
F/S Enkei RPF1 5x114.3 18x9 +35 18X9.5 +38 with track tires SsmoothyMonster Wheels and Tires 17 09-24-2012 01:52 AM
