Old 10-10-2013, 05:46 PM   #1
Evasive Motorsports
Evasive Motorsports's Avatar
Drives: 2012 FR-S and BR-Z
Send a message via AIM to Evasive Motorsports
JRZ Pros, Cusco, Moonface, HKS and Volks Suspension Tuning by Evasive Motorsports
Evasive Motorsports Service For Customers
Our philosophy at @Evasive Motorsports is minimizing track times by improving the handling and aerodynamics on the FR-S/BRZ. But the biggest part having a balance car is the suspension, brakes, aero, wheels and tires. The combination of the suspension and aero components allows the car to be consistent at the track with better handling
Installing
JRZ Pro Coilover Systems
Cusco Lower Control Arm
Moonface Roll Centers Front
Bridgestone RE-11
RT TE37 17x9.5 +40 Square
Project Mu Club Racers
RT TE37 17x9.5 +40 Square with Bridgestone RE-11
JRZ RS Pro Coilover
The RS Pro damper allows for external adjustment of both the rebound and compression functions of the damper. In addition to the same precise and accurate rebound adjustment as in the single adjustable race damper, the RS Pro are double adjustable. The compression adjustment technology is the same as that of the race version. The RS does not utilize a separate canister. The RS Pro has both the rebound and compression adjustments on the damper itself. The RS Pro takes the RS one step further with the addition of an external reservior canister. The RS Pro utilizes the external reservior to house the precise compression adjustment mechanism.
(JRZ Pro with Hyper Co Springs
JRZ Reservior allow easy adjustments with out laying on the floor at the track!
Mounted JRZ Reservior to the Cusco Rear Strut Bar for clean and easy access!
Custom Alignment Specs (Evasive Specs)
Done on our own Hunter Alignment Machine.
[IMG]http://img.photobucket.com/albums/v693/Randizzle8/photo2_zps5ad7b***.jpg[/IMG]
10-30-13
We just finished adding a HKS oil cooler for the temps at the track.
UPDATE 2-23-14
UPDATE 2-23-14
Adding a new OS Giken rear differential and final drive will better help with the lack of power for this car. We are also using the new Cusco differential cover to keep the diff cooler! This will help by not having to change fluids ever so often. For the install you will need to replace the bearings, seals, and shims so the teeth can make perfect contact.
Evasive Motorsports is offline   Reply With Quote
Old 10-10-2013, 05:53 PM   #2
Hanakuso
Hanakuso is offline   Reply With Quote
The Following User Says Thank You to Hanakuso For This Useful Post:
Evasive Motorsports (10-11-2013)
Old 10-10-2013, 06:01 PM   #3
kanundrum
Drives: 2013 Whiteout FR-S
The Following User Says Thank You to kanundrum For This Useful Post:
Old 10-11-2013, 01:09 AM   #4
xsuperbeex
Drives: Toyota Galaxy Blue Silica 86
WANT! Whats the price & spring spec for the coilover thanks..
xsuperbeex is offline   Reply With Quote
The Following User Says Thank You to xsuperbeex For This Useful Post:
Old 10-11-2013, 01:54 PM   #5
Chee-Hu
Chee-Hu's Avatar
Ballin!!!!
Chee-Hu is offline   Reply With Quote
The Following User Says Thank You to Chee-Hu For This Useful Post:
Old 10-11-2013, 02:09 PM   #6
Evasive Motorsports
If you really want to know shoot me a pm lol
The Following User Says Thank You to Evasive Motorsports For This Useful Post:
CSG Mike (10-11-2013)
Old 10-11-2013, 02:21 PM   #7
Chee-Hu
Chee-Hu's Avatar
If you didn't already know, I think it would be wise to not know as it might case health issues.
The Following 2 Users Say Thank You to Chee-Hu For This Useful Post:
CSG Mike (10-11-2013), wparsons (10-11-2013)
Old 10-11-2013, 03:03 PM   #8
Evasive Motorsports
lol this is one bad ass fr-s tho that we got to touch our hands with.
Old 10-11-2013, 03:05 PM   #9
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Right? Makes KW and Ohlins look like cheap knock-offs.
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
Chee-Hu (10-11-2013), Evasive Motorsports (10-11-2013)
Old 10-11-2013, 03:07 PM   #10
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Where did you bring in the rear res lines? I haven't looked closely but I don't recall an easy (ie, non drilling) location.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-11-2013, 03:38 PM   #11
Evasive Motorsports
@Dave-ROR
We drilled two holes behind the rear tubs which the oem tools are that was the best place we saw.
-Randy
Old 10-11-2013, 03:44 PM   #12
Evasive Motorsports
-alex
We still got love for KW and Ohlins lol
How you liking your Ohlins? @mav1178
Old 10-11-2013, 04:01 PM   #13
mav1178
mav1178's Avatar
Haven't installed yet but will do soon. Have to throw (Toyo) tires on the (Work) wheels first.
Will be reaching out to Daryl when I'm ready, might have you guys align for me as I simply don't have enough time to go down to West End Alignment...
-alex
Old 10-12-2013, 04:47 AM   #14
xsuperbeex
You were right.. i almost had a heart attack
evasive, evasive motorsports, jrz, te37rt
Rogue Motorsports U.K. Rocking Evasive Motorsports GT AERO! Evasive Motorsports FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 65 12-05-2014 04:22 PM
JRZ, Cusco, Tomei, Moonface, HKS, Volks, and OSgiken, UPDATE 2/23/14 Evasive Motorsports FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 32 04-01-2014 12:47 AM
FT86 Suspension- D2/BC/Cusco/Megan/Tanabe/Tein/KW/Cusco/Ksport/Eibach/Perrin JM Auto Racing Brakes, Suspension, Chassis 271 03-22-2014 01:17 PM
Evasive Motorsports now offering Dyno/Ecu Tuning Service Evasive Motorsports Southern California 9 12-19-2012 10:58 PM
**EVASIVE MOTORSPORTS CUSCO** Evasive Motorsports Brakes, Suspension, Chassis 18 11-21-2012 07:15 PM
