Old 10-09-2013, 10:30 PM   #15
Turbo_FRS
Turbo_FRS's Avatar
Drives: Scion FR-S
First of all, i want to clear some stuff up; this post isnt to troll. Ive never really gotten into the engine itslef, ive been researching popular performance mods and seeing what people think is good and bad with the car as a whole, and it seems that the car could use some more power, so i found these mods which will supposedly make it much better for performance (aside from bodykits). If you feel offended that i am asking such a question and dont know much about the engine itself, then thats your problem. I guess i'll just research the 2013 engine, but that probably wont answer my question in the OP anyways.
Turbo_FRS is offline   Reply With Quote
Old 10-09-2013, 10:39 PM   #16
Wo6M
Keep Calm And Drift On~
Wo6M's Avatar
Drives: Scion FR-S WhiteOut 6 Speed Manual
2013 Scion FR-S White Out Six Speed Manual
Mods:
Wo6M is offline   Reply With Quote
The Following User Says Thank You to Wo6M For This Useful Post:
Shagaliscious (10-10-2013)
Old 10-09-2013, 10:47 PM   #17
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
No. It has a gallo 24. Or was it a gallo 12? I forget which is better.
The Following 6 Users Say Thank You to finch1750 For This Useful Post:
BlaineWasHere (10-11-2013), husker741 (10-10-2013), jkr (12-15-2013), ntron1 (10-10-2013), Wise (10-09-2013), wrb (10-10-2013)
Old 10-09-2013, 10:51 PM   #18
thill
Originally Posted by Turbo_FRS View Post
So basically i am certain that i will get an FRS, and i will also mod it with things like the GReddy x Rocket Bunny widebody body kit, GReddy evo 3 exhaust, and most importantly a GReddy Tuner Turbo Kit along with alot of other stuff. I know these parts were made for the 2013 FRS, but i really want the 2014 model, not the 2013 10 Series. So will these parts fit the 2014 model as well? I assume the engine will be the determining factor for most of the performance upgrades like the turbo kit i mentioned. Also, is the body the same? I want to make sure that all these aftermarket things will fit and be compatible with the 2014 model. Any help? Thanks!
OP, I don't understand the rude responses. To answer your questions the only difference between the 2013 and 2014 are minor. The base headunit has been upgraded, kneepads have been added to the interior. Body, engine, etc are identical, so none of the mods you mentioned should have any problem.
That said, you might save a few thousand dollars if you buy a 2013 which could allow you to put the savings towards mods.
Good luck and welcome to the forum!
The Following 11 Users Say Thank You to thill For This Useful Post:
Anthony (10-10-2013), armythug (10-11-2013), Braces (10-10-2013), humfrz (10-10-2013), mav1178 (10-10-2013), Porsche (10-10-2013), Rio (12-16-2013), roddy (10-10-2013), sc0urge (10-14-2013), tr1x5tuh (10-10-2013), whaap (10-10-2013)
Old 10-09-2013, 11:25 PM   #19
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
They also fixed some of the first run problems like chirping, and whatever else people were complaining about on here a year ago.
Regardless, any model you buy should have the same engine bits.
And I kinda get the troll responses in this thread. If we're on this forum we're probably all sick of hearing the 2013 vs 2014 rumors lol
campy is offline   Reply With Quote
Old 10-09-2013, 11:31 PM   #20
onefitz
Drives: 13 GBS BRZ
Seriously?
onefitz is offline   Reply With Quote
The Following User Says Thank You to onefitz For This Useful Post:
Wo6M (10-10-2013)
Old 10-09-2013, 11:50 PM   #21
Frstorm
Drives: 2013 Firestorm
Ok I haven't dived into the engine at all and haven't done any research to improve performance on the engine and I knew it was the same engine. That is why people called it a troll.
Frstorm is offline   Reply With Quote
Old 10-09-2013, 11:58 PM   #22
WillBRZ
WillBRZ's Avatar
Drives: 2013 BRZ Limited 6MT GBS
are you even of age to own a car? lmfao
2014 infiniti Q50 Daily 1996 Mazda Miata Racecar
SOLD -> Galaxy Blue Silica Subaru BRZ Limited 6MT
SOLD -> 2003.5 Infiniti G35 Sedan Emerald Mist
WillBRZ is offline   Reply With Quote
The Following User Says Thank You to WillBRZ For This Useful Post:
Mikem53 (10-10-2013)
Old 10-10-2013, 12:22 AM   #23
First of all, i want to clear some stuff up; this post isnt to troll...........
DANG, Turbo_FRS, it appears that you got to a rough start here on ye ol forum ....
Like mentioned somewhere above the 2014 is about the same as the 2013 (except some padding and a different head unit).
Before you start ordering a bunch of "power mods" I'd suggest you wait until you get your car and drive it for a while, then decide what you want it to do best (DD, track, autox or just go faster).
You may find out it is pretty stable and scoots along quite nicely right out of the box....
whaap (10-10-2013)
Old 10-10-2013, 12:24 AM   #24
thill
Great advice.. And I am not a fan of the Rocket Bunny kits... But that is just me.
Old 10-10-2013, 12:31 AM   #25
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Truth and wisdom
The car is fast enough to have fun in easily. It'll never be fast enough for highway drags but it wasn't built for that. My friend drove mine through some twisty roads on the weekend and commented that even though he wasn't driving as hard as he would in his STI he was having way more fun.
IMHO This car just needs an exhaust, intake and tune to become a really peppy little sportscar with barrels of fun.
If this is your first car that you're considering modifying I would also suggest you don't go with a turbo kit. It's never as simple as bolting on a turbo. There are tons of additional costs and different factors to consider. Like humfrz said, buy the car and drive it first before you go nuts modifying it.
Wise is offline   Reply With Quote
Old 10-10-2013, 12:33 AM   #26
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
It shouldn't require a person to be a rocket scientist to look to the left column and see at the time of the op it was post number one and he joined our forum perhaps a little over a week ago. Because of the car we all enjoy there are a lot of first time car buyers here who have plenty of time in front of them to learn what they need to know about cars. Taking the first step on a car forum seems perfectly natural. We're getting an increasing number of members who need to lighten up a little bit.
whaap is offline   Reply With Quote
The Following 4 Users Say Thank You to whaap For This Useful Post:
Braces (10-10-2013), jonboy99 (12-17-2013), LeeMaster (10-10-2013), Porsche (10-10-2013)
Old 10-10-2013, 12:37 AM   #27
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
I hope you still go through with the performance mods and I can't wait to see it brother!
Kelbyat07 is offline   Reply With Quote
Old 10-10-2013, 03:17 AM   #28
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Lol, the OP wants to spend as much on Greddy parts as he will/did on the car, but clearly needs to do a LOT of research if he can't figure out the differences (or lack there of) between the '13 and '14.
So why Greddy exactly?
brain damage
**New 2013 XXR 531 & 535**OZ Racing Formula**2013 Enkei**Unique New Models JoeBoxer Wheels and Tires 49 04-04-2013 05:28 AM
thoughts on waiting for the 2014 models? pr086 Scion FR-S / Toyota 86 GT86 General Forum 52 01-24-2013 10:17 AM
Subaru Starlink for 2014 Models Bristecom Electronics | Audio | NAV | Infotainment 1 01-08-2013 04:25 AM
Any Idea When 2014 Models Will be Arriving? tez2013 Scion FR-S / Toyota 86 GT86 General Forum 29 11-30-2012 10:33 PM
